  • Search this thread
  • Reply to this topic
46 replies to this topic | 0 praises
#1
Posted 12 August 2010 - 09:33 AM
Ahtong
  • THREAD STARTER
  • Ahtong
    Supercharged
    Author Image
    5,848
Yesterday, I recieved a 7th month shock in my own toilet. Wanted to take a piss and found a centipede inside the toilet bowl. I got rid of it by flushing and spent the next 30 mins inspecting the toilet and saturating the place with insecticide. I also flushed the toilet a kazillion times to make sure the centipede doesn't come back.
I wonder where the centipede came from and how to prevent a future incident? The scary part is it made a run for underside of the toilet bowl rim when I was about to flush. What if there is another one lurking there ready to crawl up somebody's butt? ph34r.gif
#2
Posted 12 August 2010 - 09:37 AM
Carer
  • Carer
    4th Gear
    Author Image
    980
i see it at least twice a week at the ground floor toilet.
somtimes upstairs also have. i have a small enclosed fenced up area in my back garden to protect my plants.
once every 3 months or so, there will be a fruit bat that is stucked in between the fence. at night can see, the sound they produce also will not reflect from the fence. poor fruit bats.
#3
Posted 12 August 2010 - 09:50 AM
Jman888
  • Jman888
    Moderator
骑白马的不一定是王 ,可能是唐僧;带翅膀的也不一定是天使,有时候是鸟人。
#4
Posted 12 August 2010 - 09:51 AM
Chewbacca
  • Chewbacca
    5th Gear
    Author Image
    1,911
It's.....just a centipede.
#5
Posted 12 August 2010 - 09:57 AM
Jman888
  • Jman888
    Moderator
1. cut the water flow into the flush tank and drain it empty.
2. buy a can on bygone and spray the whole can into the toilet bowl.
3. cover the bowl and seal it up overnight.
#6
Posted 12 August 2010 - 10:12 AM
Ahtong
  • THREAD STARTER
  • Ahtong
    Supercharged
    Author Image
    5,848
Bro, do you want a centipede crawling up your backside when you are bombing? sweatdrop.gif
#7
Posted 12 August 2010 - 10:27 AM
Mike1234
  • Premium member
    Mike1234
    Supercharged
    Author Image
    5,253
A centipede can waste 30mins plus of ur time inspecting the toilet???? sweatdrop.gif
Edited by Mike1234, 12 August 2010 - 10:27 AM.
#8
Posted 12 August 2010 - 03:07 PM
Premsingh
  • Premsingh
    Banned
i used to have this problem for ground level mansionettes...
irritating
#9
Posted 12 August 2010 - 03:10 PM
Sosaria
  • Sosaria
    NOS-ed
    Author Image
    12,042
#10
Posted 12 August 2010 - 03:23 PM
SimonTan
  • SimonTan
    Banned
Centipede inside the bowl?
How the hell it survived submerged in the toilet bowl full of s--t and water logged? Almost impossible.
Unless it could be surviving in the dry air lock portion of the U-shape bend of the toilet bowl for a long long time?
Maybe I should dump whole roll of toilet paper and flush it away using pails of water to 'scrub' that U-shape bend of such dangerous creatures.
#11
Posted 12 August 2010 - 03:56 PM
Ahtong
  • THREAD STARTER
  • Ahtong
    Supercharged
    Author Image
    5,848
Just to clarify, that thing was lounging inside the dry part of the toilet bowl very near the rim and my toilet is not ground level.
#12
Posted 12 August 2010 - 04:03 PM
Carer
  • Carer
    4th Gear
    Author Image
    980
thing is this is so common.... why so kan chiong centipede
#13
Posted 12 August 2010 - 04:13 PM
Cheesepiekia
  • Premium member
    Cheesepiekia
    4th Gear
    Author Image
    640
This happen rather common in my ground floor toilet as well. Luckily all those centipedes were small, short and thin.
#14
Posted 12 August 2010 - 04:21 PM
Ahtong
  • THREAD STARTER
  • Ahtong
    Supercharged
    Author Image
    5,848
Problem is my toilet is not on the ground floor. In fact this is the first time I have seen a centipede inside the toilet. If it was crawling on the floor, I don't mind. But this one was lurking inside the toilet bowl. unimpressed.gif
#15
Posted 12 August 2010 - 04:33 PM
Carer
  • Carer
    4th Gear
    Author Image
    980
u stay hdb? which level? which area? usually near those forested area will have
#16
Posted 12 August 2010 - 04:34 PM
SimonTan
  • SimonTan
    Banned
Wait. If it's crawling on the floor from the toilet to your bed when you are sleeping.
Hey centipede leh, the bite can be deadly leh.
I am going to spray baygon and flushed my toilets when I go home tonight. 7th month creepy crawlies are not play play one leh.
#17
Posted 12 August 2010 - 04:42 PM
Ahtong
  • THREAD STARTER
  • Ahtong
    Supercharged
    Author Image
    5,848
Moi stay on 3rd floor. The surrounding area is not forested at all. I suspect the centipede got into a drainage pipe and did an epic crawl. Probably came out the basin ......
#18
Posted 12 August 2010 - 04:44 PM
Ahtong
  • THREAD STARTER
  • Ahtong
    Supercharged
    Author Image
    5,848
Since this is 7th month, I give you a nightmare scenario. What if you wake up one morning with a nose bleed and there are these 2 antennae wriggling out from your nostril? ph34r.gif
#19
Posted 12 August 2010 - 04:47 PM
Carer
  • Carer
    4th Gear
    Author Image
    980
yes it is possible.
usually ground floor to 4th floor will experience more bugs
#20
Posted 12 August 2010 - 04:54 PM
Zyrofillica
  • Premium member
    Zyrofillica
    6th Gear
    Author Image
    4,741
ps: if u arent offended with cartoon nudity, u can browse the rest of her comics at http://oglaf.com/archive/
Quick Reply
Tags: Centipede, toilet
