  • Search this thread
  • Reply to this topic
513 replies to this topic | 542 praises
#1
Posted 03 September 2010 - 10:07 AM
Bluepica
  • THREAD STARTER
  • Bluepica
    5th Gear
    Author Image
    1,528
Set aside car talk....
My home ceiling fan dunno what brand... apache...sounds like can fly... LOL... but it's rotating slower and slower... time to change.
Any brand that is windy enough and suitable for low ceiling HDB? My flat ceiling is so low until if u stand and raise ur hand, ur finger sure kena the fan blades.
Am looking at KDK...
#2
Posted 03 September 2010 - 10:19 AM
Galantspeedz
  • Premium member
    Galantspeedz
    2Fast2Furious
    Author Image
    47,406
your ceiling as low as mine...... i know of this shop selling lights and fans in malaysia... near sentosa.... quite cheap.... he mentioned that... for ceiling fan... the important thing is how strong is the motor..... for it to be windy..... hope this helps
MCF PS3 Gang
MCF Hamsup Tiko Ranger
#3
Posted 03 September 2010 - 10:28 AM
Topaz
  • Topaz
    2nd Gear
    Author Image
    173
Elmark is good
#4
Posted 03 September 2010 - 10:38 AM
Tigerwoods
  • Premium member
    Tigerwoods
    2Fast2Furious
    Author Image
    21,476
KDK is the only brand I trust...
Toothiewabbit praised this
#5
Posted 03 September 2010 - 10:40 AM
Mazdaowner
  • Mazdaowner
    2Fast2Furious
    Author Image
    69,853
No need to change fan, either it's inside the fan motor casing, (ceiling) or in the speed switch,
either place, there is a small black box, it's a speed regulator, that one is damaged. Got o Sim Lim Tower,
basement shops, and ask, one is like no more then $5-10 bucks, turn off all power or have a electrician do it for you,
all will be back to normal. Only that is damaged. I changed mine on my own, fairly simple job.
Kenny Nia & Georgie Pai are MCF's biggest hypocrites:)
The idiot who do unto others first, is a insecure prick. :D
#6
Posted 03 September 2010 - 10:44 AM
Bluepica
  • THREAD STARTER
  • Bluepica
    5th Gear
    Author Image
    1,528
Yes, mine got a regulator near the switch, turn to max also slow, turn to min lagi worst... the fan itself also got another speed controller, but always set to high...
#7
Posted 03 September 2010 - 10:47 AM
Mazdaowner
  • Mazdaowner
    2Fast2Furious
    Author Image
    69,853
Remove cover, and you will see the little box inside, some are inbuilt in, best bring the whole thing down to avoid double trips.
they will have spare for you. (shop next to the staircase looking towards the canal.) I bought a few extras, so no need go down when got this problem.
Not very often, but having 5 fans, this one kana, rest just not yet. Forgot, if fan also got speed regulator, could be either or, bring both. Fan one as mentioned, is inside the motor casing, (ceiling) remove cover and you will see the box there. best if you can just do this, Direct contol on fan or box alone, best fan, so if problem, you know which one. My guess is your wall switch worn liow, if you turn on speed via there.
Edited by Mazdaowner, 03 September 2010 - 10:49 AM.
#8
Posted 03 September 2010 - 10:51 AM
Floweradvisor
  • Floweradvisor
    3rd Gear
    Author Image
    302
FlowerAdvisor is an International Florist that does Worldwide Flower Delivery. We are a consortium of Florists that delivers to over 140 countries.
Visit us for the best Singapore Florist - FlowerAdvisor
#9
Posted 03 September 2010 - 10:58 AM
Mazdaowner
  • Mazdaowner
    2Fast2Furious
    Author Image
    69,853
Even if you buy KDK, the same SHEET will happen. There's no running away from the problem.
Aircon no need servicing? Compressor no need fill up with gas? Come on man, if donno, best don't say lah hor.
Kumsia many, many, and please send a bunch of flowers to yourself, from me, have a nice day. biggrin.gif
#10
Posted 03 September 2010 - 11:01 AM
Bluepica
  • THREAD STARTER
  • Bluepica
    5th Gear
    Author Image
    1,528
Ok I try to by pass the regulator and see how first...
#11
Posted 03 September 2010 - 11:04 AM
Mazdaowner
  • Mazdaowner
    2Fast2Furious
    Author Image
    69,853
Mine was the exact same problem, removed wall regulator, use fan direct.
No point having two, when one is the main one controlling. (wall)
You have to bypass the whole (wall) unit, direct into a normal power switch.
Then when connected, turn on power switch, and activate fan speed regulator,
some via a pull chain, some remote. If all fine, no need waste money and time.
#12
Posted 03 September 2010 - 11:05 AM
Bluepica
  • THREAD STARTER
  • Bluepica
    5th Gear
    Author Image
    1,528
yeah mine is chain.... I saw the fan own regulator yesterday when I open up everything see how to change the whole fan if needed to biggrin.gif
#13
Posted 03 September 2010 - 11:07 AM
Kangadrool
  • Premium member
    Kangadrool
    2Fast2Furious
    Author Image
    40,667
My table top KDK fan also conked off. Twice liao! The motor refused to turn. What's the problem?
#14
Vroomtattat
  • Vroomtattat
    Supercharged
    Author Image
    7,093
Hi brudders,
OT a bit, sorry arhh.
Can I do something to the speed control switch of the ceiling fan to slow down the motor?
Normally I will set the speed to 1 and max would be 2 out of 5, can I toggle the controller so that speed 1 is slow down to maybe 30-60 rpm, this would be good for night time use in the bed room.
#15
Mazdaowner
  • Mazdaowner
    2Fast2Furious
    Author Image
    69,853
Now you just bypass direct to a power switch can liow.Sure the fan one still ok, since never use.
#16
Posted 03 September 2010 - 11:09 AM
Mazdaowner
  • Mazdaowner
    2Fast2Furious
    Author Image
    69,853
#17
Posted 03 September 2010 - 11:10 AM
Mazdaowner
  • Mazdaowner
    2Fast2Furious
    Author Image
    69,853
Nothing much you can do, speed regulator is set one for how many RPMs.
Hi brudders,
#18
Posted 03 September 2010 - 11:12 AM
Kangadrool
  • Premium member
    Kangadrool
    2Fast2Furious
    Author Image
    40,667
Used to be good loh, as good as Toyota last time. But, now most Jappy goods quite crappy also leh. laugh.gif
VCD players dunno changed how many already!
Edited by Kangadrool, 03 September 2010 - 11:13 AM.
#19
Posted 03 September 2010 - 11:13 AM
Tigerwoods
  • Premium member
    Tigerwoods
    2Fast2Furious
    Author Image
    21,476
Actually Ceiling fan is good enough, no need aircon. I half year Aircon (Mar~Sep) half year fan (Oct~Feb).
Last time my children always On Aircon 21C and cover blanket.
I slowly adjust 21,22,23,24,25, and now 26C they still cover blanket.
For me, If I on Aircon this is what I do :
1. On Dehumidifier 1st
2. just before sleep, change to 27C Aircon. I still cover blanket as the Blower is directly facing me.
Mine is Mitsubishi - better than Daikin.
#20
Posted 03 September 2010 - 11:14 AM
Mazdaowner
  • Mazdaowner
    2Fast2Furious
    Author Image
    69,853
Now those cheap cheap fans, sort of ball shape, with a simple V stand, $20-30-40 +
I'm using one inside my kitchen, blowing from ground up. Quite the tahan, $45, use it when I'm in the kitchen cooking,
already 2yrs ok still. Fan all same, same, no need go buy branded, end of the day also MIC. (Made In China)
use liow, throw and buy new one. Not like last time, got bakelite switches, iron casing etc.. can last donkey years,
now where got?
Quick Reply
Tags: Ceiling
