efssc 5th Gear February 10, 2015 Share February 10, 2015 The same old question 2015 Will you choose Sorento or Santa Fe in Singapore? Santa Fe. A year ago I would have chosen Sorento, I simply adore the Tiger Nose thing Kia had going and the old Sorento in red looked simply fierce. Now the new Sorento, instead of a Tiger Nose, has a Dog Nose, now this is purely personal POV, just I'm just not feeling it. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 10, 2015 Share February 10, 2015 any of it that comes with turbo diesel. 1 Link to post Share on other sites More sharing options...
Lycanthrope 4th Gear February 10, 2015 Share February 10, 2015 not yet i think , at least for sorento and if they are priced really competitively Link to post Share on other sites More sharing options...
Quantum 5th Gear February 10, 2015 Share February 10, 2015 The same old question 2015 Will you choose Sorento or Santa Fe in Singapore? simply same Engine, same GB, same performance, whose safety, price better choose whom Link to post Share on other sites More sharing options...
Quantum 5th Gear February 10, 2015 Share February 10, 2015 any of it that comes with turbo diesel. US version got turbo, unfortunately Singapore will not import, due to Singapore hot weather is not suitable for turbo, or even c/w turbo, performance also compromised a lot Link to post Share on other sites More sharing options...
Soya Supersonic February 10, 2015 Share February 10, 2015 US version got turbo, unfortunately Singapore will not import, due to Singapore hot weather is not suitable for turbo, or even c/w turbo, performance also compromised a lot juz curious.....how many turbo cars hv u owned to be able to come to such a sweeping conclusion? 2 Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 10, 2015 Share February 10, 2015 US version got turbo, unfortunately Singapore will not import, due to Singapore hot weather is not suitable for turbo, or even c/w turbo, performance also compromised a lot while i agree that local weather is not exactly cooling, turbo will still run well but with less efficiency. Link to post Share on other sites More sharing options...
Karu 6th Gear February 10, 2015 Share February 10, 2015 Santa Fe looks better. Plus the Sorrento is more expensive. Only thing is Santa Fe is 4wheel drive & only toggle to Front wheel drive above 60km/h... Think will be more thirsty. 1 Link to post Share on other sites More sharing options...
Quantum 5th Gear February 10, 2015 Share February 10, 2015 juz curious.....how many turbo cars hv u owned to be able to come to such a sweeping conclusion? Before we explain why turbochargers perform better at lower air temperatures, it’s important to understand how a turbocharger works. Essentially, the aim of a turbocharger is to increase the density of the air inside each cylinder of the engine. By compressing the air, more oxygen enters each cylinder, and proportionally more fuel can also enter each cylinder, meaning that more power is generated with each explosion inside the cylinders. As air temperature increases, the density of the air, and the amount of oxygen it holds decreases. This means that the turbocharger has to work harder, spin faster and compress more air to produce the same amount of boost it would at lower temperatures. As the temperatures inside the turbocharger gets higher, the turbocharger can no longer increase it’s speed efficiently, meaning that knock on effect of this is that engine performance, acceleration and top speed are also reduced. In addition, hotter air also has a secondary affect on the turbocharger, by naturally increasing the operating temperature inside the turbo. Usually, the intercooler works to cool the air from the hot air intake, but in warmer temperatures, the intercooler becomes less efficient, as it is also exposed to the warmer temperatures. 4 Link to post Share on other sites More sharing options...
Soya Supersonic February 10, 2015 Share February 10, 2015 (edited) Before we explain why turbochargers perform better at lower air temperatures, its important to understand how a turbocharger works. Essentially, the aim of a turbocharger is to increase the density of the air inside each cylinder of the engine. By compressing the air, more oxygen enters each cylinder, and proportionally more fuel can also enter each cylinder, meaning that more power is generated with each explosion inside the cylinders. As air temperature increases, the density of the air, and the amount of oxygen it holds decreases. This means that the turbocharger has to work harder, spin faster and compress more air to produce the same amount of boost it would at lower temperatures. As the temperatures inside the turbocharger gets higher, the turbocharger can no longer increase its speed efficiently, meaning that knock on effect of this is that engine performance, acceleration and top speed are also reduced. In addition, hotter air also has a secondary affect on the turbocharger, by naturally increasing the operating temperature inside the turbo. Usually, the intercooler works to cool the air from the hot air intake, but in warmer temperatures, the intercooler becomes less efficient, as it is also exposed to the warmer temperatures. Errrrr....this only explains u know how to use Google search and cut&paste but still doesn't answer the question. Edited February 10, 2015 by Soya Link to post Share on other sites More sharing options...
Quantum 5th Gear February 10, 2015 Share February 10, 2015 Errrrr....this only explains u know how to use Google search and cut&paste but still doesn't answer the question.Haha, forgot to answer your question, I only own one small turbo car, 2.0T 240bhp/350Nm,Do you agree hot weather affect TC performance? Cheers Link to post Share on other sites More sharing options...
GoodCar 4th Gear February 10, 2015 Share February 10, 2015 Sorento? Really hard to decide, but I do like Sorento a bit more..just a bit :) Link to post Share on other sites More sharing options...
Soya Supersonic February 11, 2015 Share February 11, 2015 Haha, forgot to answer your question, I only own one small turbo car, 2.0T 240bhp/350Nm, Do you agree hot weather affect TC performance? Cheers Wah sei...ur Touran 1.4T can pump out 240bhp and 350Nm??? My T5 2.5L onli does 220bhp and 320Nm.....muz be lousy wowo turbocharging tech. To cut a long story short, high temp affects both NA and TC. But it doesn't mean TC is "not suitable" and "compromise a lot". 1 Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged February 12, 2015 Share February 12, 2015 Brought a friend to check out both cars on the same morning. Current car 2008 GS300 but needed more seats for family. SantaFe looks much better, has on-call 4WD and a $10K price advantage, but the Sorento has more equipment, seemed better built, has a nicer dashboard and comfier seats (really nice), more effective brakes, and slightly more room in the last row. Both engines and transmission feels about the same despite the SantaFe being GDI while the Sorento test car is non-GDI. About the same meaning gutless unless revved hard, and by then it turns strained and noisy. Ride and handling seemed better than expected given the tall and heavy body, but both still feels cumbersome and big. There is no other 7-seater SUV in this price bracket. Next one up is Mazda CX-9 at another $40-50k more. My friend came away sighing, cos it dawned on him that catering for family needs comes with a big sacrifice in driveability and performance compared to his current saloon. 3 Link to post Share on other sites More sharing options...
Tohto Hypersonic February 12, 2015 Share February 12, 2015 Brought a friend to check out both cars on the same morning. Current car 2008 GS300 but needed more seats for family. SantaFe looks much better, has on-call 4WD and a $10K price advantage, but the Sorento has more equipment, seemed better built, has a nicer dashboard and comfier seats (really nice), more effective brakes, and slightly more room in the last row. Both engines and transmission feels about the same despite the SantaFe being GDI while the Sorento test car is non-GDI. About the same meaning gutless unless revved hard, and by then it turns strained and noisy. Ride and handling seemed better than expected given the tall and heavy body, but both still feels cumbersome and big. There is no other 7-seater SUV in this price bracket. Next one up is Mazda CX-9 at another $40-50k more. My friend came away sighing, cos it dawned on him that catering for family needs comes with a big sacrifice in driveability and performance compared to his current saloon. With such a heavy body, need a Turbo engine or Turbo diesel to move it. Link to post Share on other sites More sharing options...
Banz86 5th Gear February 12, 2015 Share February 12, 2015 Brought a friend to check out both cars on the same morning. Current car 2008 GS300 but needed more seats for family. SantaFe looks much better, has on-call 4WD and a $10K price advantage, but the Sorento has more equipment, seemed better built, has a nicer dashboard and comfier seats (really nice), more effective brakes, and slightly more room in the last row. Both engines and transmission feels about the same despite the SantaFe being GDI while the Sorento test car is non-GDI. About the same meaning gutless unless revved hard, and by then it turns strained and noisy. Ride and handling seemed better than expected given the tall and heavy body, but both still feels cumbersome and big. There is no other 7-seater SUV in this price bracket. Next one up is Mazda CX-9 at another $40-50k more. My friend came away sighing, cos it dawned on him that catering for family needs comes with a big sacrifice in driveability and performance compared to his current saloon. That I totally agree. Even now I don't have a large family yet but already have to slowly save up in case need to change to a bigger car. Just my plus one and own family already a full car, not factoring in future an additional family member. Don't really wanna drive an MPV therefore also looking at these 2 cars. But I mentioned in another thread, with the size and weight of the car after a full load, I would think a turbo diesel would be better. Esp for an SUV 7 seater. 1 Link to post Share on other sites More sharing options...
Chelsea901 1st Gear February 12, 2015 Share February 12, 2015 The same old question 2015 Will you choose Sorento or Santa Fe in Singapore? wa, sibeh rich sia, no wonder they say all sg all sibeh rich. now you change to what car? Wah sei...ur Touran 1.4T can pump out 240bhp and 350Nm??? My T5 2.5L onli does 220bhp and 320Nm.....muz be lousy wowo turbocharging tech. To cut a long story short, high temp affects both NA and TC. But it doesn't mean TC is "not suitable" and "compromise a lot". wa, ppl will cry sia, you go downgrade for ppl 1 Link to post Share on other sites More sharing options...
Invigorated Supercharged February 13, 2015 Share February 13, 2015 There is no other 7-seater SUV in this price bracket. Next one up is Mazda CX-9 at another $40-50k more. My friend came away sighing, cos it dawned on him that catering for family needs comes with a big sacrifice in driveability and performance compared to his current saloon. Has your friend considered the new Nissan xtrail and mitsubishi outlander? ↡ Advertisement Link to post Share on other sites More sharing options...
Kia K5
Kia K5
KIA K3 Owners check-in!
New Kia Niro Hybrid
New Kia Niro Hybrid
