Kb27 Supersonic September 15, 2017 Share September 15, 2017 what is your review of this water flosser huh? powerful enough to blast stubborn kangkong/bah kwah pieces from the gaps? the Panasonic one need to get from 3rd party, so have to use v-post to ship Thinking of getting the waterpik one which can potentially be shipped under the 125usd free shipping deal. I use this one https://www.amazon.com/Panasonic-EW-DJ10-Portable-Operated-Collapsible/dp/B0027LSEPS/ It's powerful enough to remove stick-on powder on battery terminals. And of cuz, knock out some loose foodbits stuck in between teeth. It has 2 level of power. I use lower power only, good enough. ↡ Advertisement Link to post Share on other sites More sharing options...
Ender Hypersonic September 15, 2017 Share September 15, 2017 thanks! will look at taobao for it!Be prepare for bloody gums for your first few days of usuage. HahahaThose panasonic looks good if they are AA operated. One thing about the h2ofloss built in battery is it gets weak in less then a week of everyday use. Charging takes around 12 hrs. I opened before, seem like it is 4 AA rechargeable soldered in series. I may swapped them out for the 2400mah panasonic AA eneloop. Link to post Share on other sites More sharing options...
Kb27 Supersonic September 15, 2017 Share September 15, 2017 Be prepare for bloody gums for your first few days of usuage. Hahaha Those panasonic looks good if they are AA operated. One thing about the h2ofloss built in battery is it gets weak in less then a week of everyday use. Charging takes around 12 hrs. I opened before, seem like it is 4 AA rechargeable soldered in series. I may swapped them out for the 2400mah panasonic AA eneloop. The Panasonic I mentioned use 2 AA. I play around with the batteries also. If using 2 NiMH (2.4V), not so powerful. If using lithium 3.9V ( 14500 + a shorting connector ), it really shoots out the water. Link to post Share on other sites More sharing options...
Mustank Hypersonic September 15, 2017 Share September 15, 2017 I was thinking of this: https://www.amazon.com/Waterpik-Cordless-Advanced-Flosser-Brilliant/dp/B01GNVF8BK/ref=sr_1_7_s_it?s=beauty&ie=UTF8&qid=1505472219&sr=1-7&refinements=p_76%3A1249134011%2Cp_n_shipping_option-bin%3A3242350011&th=1 110-240V one No good oneMust mannual turn off charger if not battery spoil You see the review Didnt face such problem with Panasonic Link to post Share on other sites More sharing options...
Neutrino Supercharged September 15, 2017 Share September 15, 2017 (edited) I use this one: https://www.superdrug.com/Electrical-Gifts/Philips-Sonicare-HX8222-02-AirFloss-Interdental-Clean-Pink/p/488701?gclid=CjwKCAjw9O3NBRB3EiwAK6wPTyqIx1J9QArXazekT5PI-HWf-CbjMG700i-faOVVgm4VuvHWv6j6JRoCg4IQAvD_BwE&gclsrc=aw.ds&dclid=CLeaxuWTp9YCFcGJ7QodxF8L1w Bought it in UK haven't seen it in Singapore. Bought the first one 4 years ago. Earlier model and only lasted about a month before it jammed. Took it back to Boots and got it replaced. But over 3 years it kept on jamming and lucky I was in UK annually because I always got it replaced foc. Had maybe 4 or 5 but they always jammed. Finally I got upgraded to the model above again foc Worked perfectly now for a year ( I should't have said that ) I kept getting it replaced because when it worked it was so good. I recommend it to everyone although no one else has bought one. ha ha. These are the interdental brushes I use: https://www.superdrug.com/Toiletries/Dental/Interdental-Brushes/SuperdrugTotalcare-Interdental-Brushes/p/975057 They can each last a few months but depends on if you get a piece of meat jam packed between your teeth and have to really force. Edited September 15, 2017 by Neutrino 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic September 15, 2017 Share September 15, 2017 No good one Must mannual turn off charger if not battery spoil You see the review Didnt face such problem with Panasonic Yeah hor, just saw the reviews about the battery. Link to post Share on other sites More sharing options...
DACH Supersonic September 15, 2017 Share September 15, 2017 Don't know an iPhone thread can bring up an electric toothbrush thread... Link to post Share on other sites More sharing options...
Vratenza Supersonic September 15, 2017 Share September 15, 2017 Ohh so it's the sonicare Airfloss. Had been thinking about getting it last year but kiv it as i read about reliability problems. Sg has, can see it on the Philips online website at 199...very expensive. Will seriously consider it if can find good online deals. I use this one: https://www.superdrug.com/Electrical-Gifts/Philips-Sonicare-HX8222-02-AirFloss-Interdental-Clean-Pink/p/488701?gclid=CjwKCAjw9O3NBRB3EiwAK6wPTyqIx1J9QArXazekT5PI-HWf-CbjMG700i-faOVVgm4VuvHWv6j6JRoCg4IQAvD_BwE&gclsrc=aw.ds&dclid=CLeaxuWTp9YCFcGJ7QodxF8L1w Bought it in UK haven't seen it in Singapore. Bought the first one 4 years ago. Earlier model and only lasted about a month before it jammed. Took it back to Boots and got it replaced. But over 3 years it kept on jamming and lucky I was in UK annually because I always got it replaced foc. Had maybe 4 or 5 but they always jammed. Finally I got upgraded to the model above again foc Worked perfectly now for a year ( I should't have said that ) I kept getting it replaced because when it worked it was so good. I recommend it to everyone although no one else has bought one. ha ha. These are the interdental brushes I use: https://www.superdrug.com/Toiletries/Dental/Interdental-Brushes/SuperdrugTotalcare-Interdental-Brushes/p/975057 They can each last a few months but depends on if you get a piece of meat jam packed between your teeth and have to really force. Link to post Share on other sites More sharing options...
Voodooman Supersonic September 16, 2017 Share September 16, 2017 I was thinking of this: https://www.amazon.com/Waterpik-Cordless-Advanced-Flosser-Brilliant/dp/B01GNVF8BK/ref=sr_1_7_s_it?s=beauty&ie=UTF8&qid=1505472219&sr=1-7&refinements=p_76%3A1249134011%2Cp_n_shipping_option-bin%3A3242350011&th=1 110-240V one The Q&A said this is 110V or this is like the Oral B? I have been buying Oral B electric toothbrush from Amazon USA, much cheaper, and although the voltage stated is 110V, it works on our 220v. Link to post Share on other sites More sharing options...
Vratenza Supersonic September 16, 2017 Share September 16, 2017 Cut and paste from the Amazon product page description itself. Also read deeper into the Q&A, i think I saw some others replied that it is travel compatible. The Easy and More Effective Way to Floss! Healthier Gums and Brighter Teeth in Just a Minute a Day! New magnetic rapid-charge system, LED battery charge indicator, electronic pressure control, and 360 Degree Tip Rotation 4 Water Flossing Tips, 3 Pressure Settings, and 45 Seconds of Water Capacity Compatible With 100-240/VAC 50/60Hz voltage for global use The Q&A said this is 110V or this is like the Oral B? I have been buying Oral B electric toothbrush from Amazon USA, much cheaper, and although the voltage stated is 110V, it works on our 220v. 1 Link to post Share on other sites More sharing options...
Rayleigh 6th Gear September 16, 2017 Share September 16, 2017 (edited) For me, my daily routine is a combo cleaning ritual. 1. Flossing with satin tape 2. Using Panasonic water pick to remove more trapped food. 3. Thereafter will rinse the mouth thoroughly to flush out the food. It ends with electric toothbrush to clean the remaining. However, i would simply spit out the toothpaste without further rinsing my mouth. I actually believe a dentist advise to leave the toothpaste on the teeth to maximise protection and cleanliness. Anyway its a nice aftertaste for me. For toothpaste, i like Colgate Total Professional Clean series. Edited September 16, 2017 by Rayleigh 1 Link to post Share on other sites More sharing options...
Neutrino Supercharged September 16, 2017 Share September 16, 2017 Ohh so it's the sonicare Airfloss. Had been thinking about getting it last year but kiv it as i read about reliability problems. Sg has, can see it on the Philips online website at 199...very expensive. Will seriously consider it if can find good online deals. Make sure you get the pink model. That's the upgraded one and doesn't jam. The first one I bought in UK, the one that jammed, cost me S$85. As I said I had it replaced 4 or 5 times and then got upgraded to the Pink Model all FOC. Wouldn't have happened in Singapore. And it's like I always say on here we get stiffed on price for eveything. 1 Link to post Share on other sites More sharing options...
Kopites Supersonic September 16, 2017 Share September 16, 2017 Just came back from Watson. They don't carry Philip brand. Only oral and collgate. Link to post Share on other sites More sharing options...
Ender Hypersonic September 16, 2017 Share September 16, 2017 Just came back from Watson. They don't carry Philip brand. Only oral and collgate. Philip brand usually at those big eletrical retailer like best denki, courts, harver norman.. You can check out Qoo10, lazada and shopee. Usually cheaper especially when there's coupon. 1 Link to post Share on other sites More sharing options...
Voodooman Supersonic September 16, 2017 Share September 16, 2017 Just came back from Watson. They don't carry Philip brand. Only oral and collgate.Buy from Amazon Prime. Cheaper and free delivery. Link to post Share on other sites More sharing options...
Nlatio Turbocharged September 16, 2017 Share September 16, 2017 I am using this head currently, best one to date: helps to flush out whatever tiny stuff that I loosen while doing the initial prebrushing floss. So am I right to say the above will fit any Philip electric brush model?? Or specific brush for specific model like shaver?? Thinking of ordering from Amazon Prime? Still not sure whcih model?? HX8911 + HX9003?? 1 Link to post Share on other sites More sharing options...
Still2016 Twincharged September 16, 2017 Share September 16, 2017 how many times do you use each one on average? or single use? Luckily everyone here know I don't sell toothbrush for a living.... Doc tomorrow I am collecting my Philips Sonicare HX9332/04 cost $186 this is a very expensive toothbrush hope my teeth deserve it 6 Link to post Share on other sites More sharing options...
Nlatio Turbocharged September 16, 2017 Share September 16, 2017 Doc tomorrow I am collecting my Philips Sonicare HX9332/04 cost $186 this is a very expensive toothbrush hope my teeth deserve it Wah Bro, high end model!!! ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone has toothbrush lobangs?
How to brush with those ultrasonic (vibrating) toothbrush?
