Mydotcom 1st Gear November 24, 2010 Share November 24, 2010 Hi all, I'd just changed my 2 front wheel's brake rotor and brake pads 2 weeks ago. Encountered something weird today... Was travelling along ECP when I suddenly needs to jam brake (Not e-brake kind of jam brake, but the step hard on brake kind of jame brake). I can hear a sharp screeching sound, but car managed to slowed down as per expected. When I reached the carpark shortly after that, I realised that 1 of my front wheel has smoke coming out of it. could it be due to the semi-hard braking I just did ? Or could it be something more ? ↡ Advertisement Link to post Share on other sites More sharing options...
SimonTan 2nd Gear November 24, 2010 Share November 24, 2010 Could be the caliper jammed!! Constant rubbing untill smoke!! Link to post Share on other sites More sharing options...
Kiadaw 6th Gear November 24, 2010 Share November 24, 2010 Brake rotors seldom need to replace one, if I am not wrong? How old is your car? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear November 24, 2010 Share November 24, 2010 Hi all, I'd just changed my 2 front wheel's brake rotor and brake pads 2 weeks ago. Encountered something weird today... Was travelling along ECP when I suddenly needs to jam brake (Not e-brake kind of jam brake, but the step hard on brake kind of jame brake). I can hear a sharp screeching sound, but car managed to slowed down as per expected. When I reached the carpark shortly after that, I realised that 1 of my front wheel has smoke coming out of it. could it be due to the semi-hard braking I just did ? Or could it be something more ? No mention brand/model of car No mention mileage travelled by car after brake repair No mention travelling speed No mention if road wet while braking Have another Mechanic check your car Link to post Share on other sites More sharing options...
Silver_blade Turbocharged November 24, 2010 Share November 24, 2010 Was the road near your MSCP wet? If so, that the cause of the smokes you saw. Link to post Share on other sites More sharing options...
Stinky Neutral Newbie November 24, 2010 Share November 24, 2010 did you drive in the rain / over puddles if so then yes it's perfectly normal. Link to post Share on other sites More sharing options...
Mydotcom 1st Gear November 24, 2010 Author Share November 24, 2010 Sorry... seems like i missed out alot of info. I'm driving a 4 yrs old Nissan Latio, Road was dry at that time (was on Benjamin Sheares Bridge towards Tuas direction downslope section). I only noticed the smoke after I parked, which is about 3 mins after I stepped hard on brake. Speed I reckon is around 80-90km/h, braked till ard 30-40 km/h. My old brake rotor was 'spoilt', resulting in the steering wheel vibrating whenever i step on brakes. That's why I need to change it together with the brake pad. Mileage after changing is ard 1000km. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear November 24, 2010 Share November 24, 2010 "I can hear a sharp screeching sound" In all the recent cars with ABS i drove.....there is no tyre screeching sound when hard braking. The screeching sound must come from your rotor rubbing against pad. better check properly! Link to post Share on other sites More sharing options...
Kilatz 1st Gear November 24, 2010 Share November 24, 2010 Sorry... seems like i missed out alot of info. I'm driving a 4 yrs old Nissan Latio, Road was dry at that time (was on Benjamin Sheares Bridge towards Tuas direction downslope section). I only noticed the smoke after I parked, which is about 3 mins after I stepped hard on brake. Speed I reckon is around 80-90km/h, braked till ard 30-40 km/h. My old brake rotor was 'spoilt', resulting in the steering wheel vibrating whenever i step on brakes. That's why I need to change it together with the brake pad. Mileage after changing is ard 1000km. Err... brake rotor seldom spoilt... could be your brake pads in the first place. Anyway first time i heard Latio brake got smoke... Link to post Share on other sites More sharing options...
Buffy November 24, 2010 Share November 24, 2010 Sorry... seems like i missed out alot of info. I'm driving a 4 yrs old Nissan Latio, Road was dry at that time (was on Benjamin Sheares Bridge towards Tuas direction downslope section). I only noticed the smoke after I parked, which is about 3 mins after I stepped hard on brake. Speed I reckon is around 80-90km/h, braked till ard 30-40 km/h. My old brake rotor was 'spoilt', resulting in the steering wheel vibrating whenever i step on brakes. That's why I need to change it together with the brake pad. Mileage after changing is ard 1000km. Sound like yr dise wraps. could happen when its still hot n water comes into contact. Can skim the rotor aka level it back, but can be done only once on the rotor. Link to post Share on other sites More sharing options...
Mydotcom 1st Gear November 24, 2010 Author Share November 24, 2010 replies sounds like bad news.... :( guess i'll probably send it back to tan chong for servicing + checkup Link to post Share on other sites More sharing options...
Aimnfire 4th Gear November 24, 2010 Share November 24, 2010 replies sounds like bad news.... :( guess i'll probably send it back to tan chong for servicing + checkup get a 3rd party mechanic for opinion note it down then head for tan chong cause usually agents will say 'its like that one' Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 24, 2010 Share November 24, 2010 Sorry... seems like i missed out alot of info. I'm driving a 4 yrs old Nissan Latio, Road was dry at that time (was on Benjamin Sheares Bridge towards Tuas direction downslope section). I only noticed the smoke after I parked, which is about 3 mins after I stepped hard on brake. Speed I reckon is around 80-90km/h, braked till ard 30-40 km/h. My old brake rotor was 'spoilt', resulting in the steering wheel vibrating whenever i step on brakes. That's why I need to change it together with the brake pad. Mileage after changing is ard 1000km. From this view,most likely your brake calipers are jammed,your old brake rotor 'overheated' so it warp & cause vibration....your mechanic never checks your brake calipers.. Link to post Share on other sites More sharing options...
Icekitten Clutched November 24, 2010 Share November 24, 2010 1000km ur new brake rotors and pads would not be run in yet.... Recommended 2000km at least Link to post Share on other sites More sharing options...
Showtime Neutral Newbie November 24, 2010 Share November 24, 2010 Brake rotors seldom need to replace one, if I am not wrong? How old is your car? this really depends on the brake pad compound. ↡ Advertisement Link to post Share on other sites More sharing options...
Smoking will be banned at some parks, beaches, gardens from July onwards
All about smoking
All about smoking
Cancer cases on the rise in Singapore
Change Disc Rotors
Change Disc Rotors
Join the Quit Smoking Club!
FORCE Big Brake Kit promotional Price
Smoking cabins to be set up in Clementi
