Chrispie 5th Gear December 17, 2010 Share December 17, 2010 Hi to all the experts here.. im contemplating upsizing my rims. So wanna know more about the implications. Hope you guys can share some wisdom. Kindly use the format: Pros: Cons: thanks a lot! ↡ Advertisement Link to post Share on other sites More sharing options...
Andylau1177 Neutral Newbie December 17, 2010 Share December 17, 2010 (edited) Pros: definitely looks better than original smallish rims! Cons: heavier, increase fc speedometer accuracy might be affected ride comfort is compromise if you changed to lower profile tyres to reduce inaccuracy in speedometer extra money spent tyre change will be mre expensive due to bigger size Edited December 17, 2010 by Andylau1177 Link to post Share on other sites More sharing options...
Chrispie 5th Gear December 17, 2010 Author Share December 17, 2010 so if i kept the overall circumference to be the same, the gauges' accuracy wont be affected right? And as for heavier, what if i get a 18' that is actually lighter than my 17'? Link to post Share on other sites More sharing options...
Andylau1177 Neutral Newbie December 17, 2010 Share December 17, 2010 thats right, thats why you have to sacrifice on comfort by getting lower profile tyres. and there are lighter 18 rims than 17 rims around but the tyres would be heavier i think due to more materials. Link to post Share on other sites More sharing options...
Forte3737 5th Gear December 17, 2010 Share December 17, 2010 thieves may steal as bigger wheels are more expensive Link to post Share on other sites More sharing options...
Cybernation Neutral Newbie December 17, 2010 Share December 17, 2010 The in cabin noise become noisier as well.. Link to post Share on other sites More sharing options...
D3badge 6th Gear December 17, 2010 Share December 17, 2010 (edited) so if i kept the overall circumference to be the same, the gauges' accuracy wont be affected right? And as for heavier, what if i get a 18' that is actually lighter than my 17'? Bro tyre weight spec can be seen in the website http://www.tirerack.com/tires/tires.jsp?ti...tremeContact+DW generally conti and michelin are lighter..... Bridgestone is HEAVY Edited December 17, 2010 by D3badge Link to post Share on other sites More sharing options...
Chrispie 5th Gear December 17, 2010 Author Share December 17, 2010 so the ONLY good points are : 1. looks better 2. better handling coz lower profile tyres flex lesser when cornering (provided the overall weight is lighter, if not moving off is more difficult) Link to post Share on other sites More sharing options...
Acerchan2002 Clutched December 17, 2010 Share December 17, 2010 Depends, I sat in my friend civic with 18 low-profile and coilovers. I still find it comfortable. Link to post Share on other sites More sharing options...
Ninafrost 1st Gear December 17, 2010 Share December 17, 2010 so the ONLY good points are : 1. looks better 2. better handling coz lower profile tyres flex lesser when cornering (provided the overall weight is lighter, if not moving off is more difficult) 3. FC can remain the same provided your upsize rims are lighter then the original ones. Cons 1. You feel more of the bumps on the road as the profile is lower. 2. Should your rims be light and expensive, you probably have to invest in a set of lock lug nuts. Have you considered lessening the offset figure? Nina Link to post Share on other sites More sharing options...
Chrispie 5th Gear December 17, 2010 Author Share December 17, 2010 errmm.... simi si offset? i only know i need to get rims with same pcd (which i also dont know what it really is)... Link to post Share on other sites More sharing options...
Ninafrost 1st Gear December 17, 2010 Share December 17, 2010 errmm.... simi si offset? i only know i need to get rims with same pcd (which i also dont know what it really is)... It is like widening the "stance" of the car, means your tyres will protrude out more if the offset figure is less.... say i go from +45 to +40 means, that my rims will flush out more... you can ask more about the offset from the rim sellers.... see my example about offsets... http://ll.speedhunters.com/u/f/eagames/NFS.../snap/road1.jpg PCD is the spec for the lug nut holes on your rims. See this. =) http://www.matey-matey.com/alloy-wheels.shtml regards Nina Link to post Share on other sites More sharing options...
Watwheels Supersonic December 17, 2010 Share December 17, 2010 so the ONLY good points are : 1. looks better 2. better handling coz lower profile tyres flex lesser when cornering (provided the overall weight is lighter, if not moving off is more difficult) Point No2. is more prone to drifting when tires flex less, the grip is compromised. Just look at drifting competition they like to use large sized rims & low profile tires to drift. On the other hand if you look at WRC they use small rims with high profile tires for more grip over off road terrain & even on tarmac. Although high profile tires dun look nice they offer better grip on road conditions as they able to flex more and less prone to drift. Link to post Share on other sites More sharing options...
Ncss Clutched December 17, 2010 Share December 17, 2010 (edited) so if i kept the overall circumference to be the same, the gauges' accuracy wont be affected right? And as for heavier, what if i get a 18' that is actually lighter than my 17'? Normally total weight with tyre will be heavier... dun forget that you also increase the width on the tyre Dun tell me that you have a 18" wheel with 195 width Edited December 17, 2010 by Ncss Link to post Share on other sites More sharing options...
Chrispie 5th Gear December 17, 2010 Author Share December 17, 2010 Normally total weight with tyre will be heavier... dun forget that you also increase the width on the tyre Dun tell me that you have a 18" wheel with 195 width thats the thing.. i was lookg at some of the tyre specs, a 225/50/17 is actually heavier than 225/40/18. so based on this, i actually saved some weight. Link to post Share on other sites More sharing options...
C-K 2nd Gear December 17, 2010 Share December 17, 2010 If you go for forged rims, then bigger rims might be slightly lighter than the smaller ones. However, with increase in contact on the road (wider tyres), lighter rims might not be translated into better FC for your car and if it really helps a little to save more petrol, the price you pay for forged rims and light-weight tyres still doesn't justify the saving. Link to post Share on other sites More sharing options...
Fierydog2002 Neutral Newbie December 17, 2010 Share December 17, 2010 Hi to all the experts here.. im contemplating upsizing my rims. So wanna know more about the implications. Hope you guys can share some wisdom. Kindly use the format: Pros: Cons: thanks a lot! pros : it will look much more nicer. if you want to go for the looks then dun care about the FC and etc. cons: tires are more expensive. will affect FC but you cant have the best of both world. so either go for looks or go for FC. Link to post Share on other sites More sharing options...
Sky_vinz Clutched December 17, 2010 Share December 17, 2010 Also, consider the factor whether will you be driving up north often. Too many potholes are bad for big rims + low profile tyres. ↡ Advertisement Link to post Share on other sites More sharing options...
Benefits of having bigger population in our day to day life.
Formula 1 Wheels Look Way Different for 2022. Here's Why. . .
DIY Curbed Wheel Fix - Was It Worth It?
BBS wheels reportedly files for bankruptcy in Germany
The optional wheels for the Mac Pro cost almost S$600
New Mid Size Sedan All Comes with Bigger Rims/Wheels?
BBS....RI-A Rims.
BBS....RI-A Rims.
Forged brand rims... anyone know where this brand is from?
