Kazuo Neutral Newbie December 31, 2010 Share December 31, 2010 Possible? ↡ Advertisement Link to post Share on other sites More sharing options...
Rx100 Clutched March 8, 2011 Share March 8, 2011 what do you think?? Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie March 8, 2011 Author Share March 8, 2011 Don't know, seriously.... Tell me leh! Haha Link to post Share on other sites More sharing options...
Chenoire Neutral Newbie March 8, 2011 Share March 8, 2011 Don't know, seriously.... Tell me leh! Haha Hi Bro Kazuo, Highly unlikely. The head would need to be skimmed extensively to get the correct compression ratio. This is assuming the 3E and 1E engine have the same bore. I know the 1E engine had a 70.5mm bore, and the 2E had a bore of 73mm. Not sure what the 3E bore is, but likely to be bigger, so the combustion chamber will be oversized for the 1E block. This is my theoretical ramblings. Any other more experienced brothers care to share? I prepare to stand corrected. Anyone know if the steering boss kit of our Starlet will fit Corolla AE101? Link to post Share on other sites More sharing options...
Rx100 Clutched March 29, 2011 Share March 29, 2011 change whole engine should be better right?? Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie March 29, 2011 Author Share March 29, 2011 Wah fierce... Link to post Share on other sites More sharing options...
Indiandrivesdotcom Neutral Newbie March 29, 2011 Share March 29, 2011 To change parts with the part of another model. Its better to change whole engine. Link to post Share on other sites More sharing options...
Starletgt Neutral Newbie May 20, 2011 Share May 20, 2011 Hi Bro Kazuo, Highly unlikely. The head would need to be skimmed extensively to get the correct compression ratio. This is assuming the 3E and 1E engine have the same bore. I know the 1E engine had a 70.5mm bore, and the 2E had a bore of 73mm. Not sure what the 3E bore is, but likely to be bigger, so the combustion chamber will be oversized for the 1E block. This is my theoretical ramblings. Any other more experienced brothers care to share? I prepare to stand corrected. Anyone know if the steering boss kit of our Starlet will fit Corolla AE101? 3E is having the same bore as a 2E but the stroke is different. Link to post Share on other sites More sharing options...
Starletgt Neutral Newbie May 20, 2011 Share May 20, 2011 Possible? It is possible if you wann go low compression.... but no point cause carb turbo is definately a wrong technology. Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie May 20, 2011 Author Share May 20, 2011 Oh... So should be reverse? 3E with 1E head to achieve high compression? Link to post Share on other sites More sharing options...
Starletgt Neutral Newbie May 24, 2011 Share May 24, 2011 Oh... So should be reverse? 3E with 1E head to achieve high compression? Yup your right... but beware of the valve clearance and changing the cams to the 3E ones. ↡ Advertisement Link to post Share on other sites More sharing options...
Suu Kyi detained
Suu Kyi detained
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
