markw12 3rd Gear January 2, 2016 Share January 2, 2016 Hello, I'm not sure where / what this sound is (I think its 'rattling') and I think its coming from the gearbox. It happens when the car is idling http://picosong.com/EF7u/ Anyone know what is it? ↡ Advertisement Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear January 2, 2016 Share January 2, 2016 Hi Mark, your Axio what is the mileage? I had some noise issues last time on my Axio- mileage about 140K there about, my workshop drain out the oil engine oil - btw was the Toyota Lexus full syn oil. Fill up with ELF Semi Syn oil - then noise disappeared, the mech told me this mileage use semi syn oil is better. Just sharing my experience - you can ask your car mech on this... Link to post Share on other sites More sharing options...
markw12 3rd Gear January 2, 2016 Share January 2, 2016 Car mileage at approx, 212,000K Hi Mark, your Axio what is the mileage? I had some noise issues last time on my Axio- mileage about 140K there about, my workshop drain out the oil engine oil - btw was the Toyota Lexus full syn oil. Fill up with ELF Semi Syn oil - then noise disappeared, the mech told me this mileage use semi syn oil is better. Just sharing my experience - you can ask your car mech on this... Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 2, 2016 Share January 2, 2016 unsure what tht noise was, but may be loose metal cover / heat shield, timing chain tensioner, valve clatter (similar to diesel engine clatter). don't conclude as gearbox issue first. try cheaper method like bolting covers / shields in engine bay b4 start-up first, then listen to engine valve cover area when idling. hope u r able to resolve e issue w/o much cost. Link to post Share on other sites More sharing options...
Ckchong8 1st Gear January 3, 2016 Share January 3, 2016 Hello, I'm not sure where / what this sound is (I think its 'rattling') and I think its coming from the gearbox. It happens when the car is idling http://picosong.com/EF7u/ Anyone know what is it? sound like belt worn off Link to post Share on other sites More sharing options...
hsl118 6th Gear January 27, 2016 Share January 27, 2016 Went for supper with neighbour who just got his new vezel. Noticed he liked to change gears from Drive to Neutral when approaching red traffic. The last time I did this was when driving a manual transmission. When doing that RPM shot up instantly while he let the car rolled. Did not comment since he is a self professed motor-head. Is he killing his CVT gearbox doing this? Or highly recommended? Link to post Share on other sites More sharing options...
paddychs 1st Gear January 27, 2016 Share January 27, 2016 I'll leave the gear at D instead of N. Heard not a good idea to keep switching cos will damaged the solenoid in the long run. Pls see this https://www.quora.com/Should-one-shift-gear-into-neutral-when-stopped-at-a-traffic-light Link to post Share on other sites More sharing options...
Cobragold Clutched February 12, 2016 Share February 12, 2016 (edited) Hi, I am driving a Toyota axio, after my last cvt oil change, the mech gave back to me the oil can with about 1 litre left inside. Since a full tin is 4 litre, is the amount used correct. Recently I noticed that I need to use more engine power to move the car ,especially when reverse gear. Can the lack of enough cvt oil cause this problem ? What is the correct amount of oil required? If the gear box is having a problem, anyone can recommend a workshop to rectify,? Anyone had this type of problem before? Any help will be greatly appreciated. Edited February 12, 2016 by Cobragold Link to post Share on other sites More sharing options...
hsl118 6th Gear February 12, 2016 Share February 12, 2016 Hi, I am driving a Toyota axio, after my last cvt oil change, the mech gave back to me the oil can with about 1 litre left inside. Since a full tin is 4 litre, is the amount used correct. Recently I noticed that I need to use more engine power to move the car ,especially when reverse gear. Can the lack of enough cvt oil cause this problem ? What is the correct amount of oil required? If the gear box is having a problem, anyone can recommend a workshop to rectify,? Anyone had this type of problem before? Any help will be greatly appreciated. Do you still have your car manual to refer to? It usually should be less than 4L. Link to post Share on other sites More sharing options...
Blackyv Turbocharged February 12, 2016 Share February 12, 2016 Talk about Gb, I guess I kill my 4at Gb during cny trip up north.. After my return, the Gb has delayed engagement.. During morning cold start, when engage to D from P, and release foot brake, car won't move at all for like 1-2seconds.. Googled for the symptom and bingo, common problem for a problematic auto gb.. Anyway, hope it can hold till end of this year... Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 12, 2016 Share February 12, 2016 Talk about Gb, I guess I kill my 4at Gb during cny trip up north.. After my return, the Gb has delayed engagement.. During morning cold start, when engage to D from P, and release foot brake, car won't move at all for like 1-2seconds.. Googled for the symptom and bingo, common problem for a problematic auto gb.. Anyway, hope it can hold till end of this year... Maybe try lucas oil or the xando additive that is thicker that helps reduce the pressure lost due to worn seals. 1 Link to post Share on other sites More sharing options...
LIMCS Neutral Newbie February 18, 2016 Share February 18, 2016 Just did an overhaul at sin ming one of the gearbox specialised workshop. Put my car there on tuesday afternoon, just gotten my car back today. Less than 3 days overhaul. Hope it is a good overhaul as i see my car camera only off half a day due to removal of car battery. Link to post Share on other sites More sharing options...
AHBA 2nd Gear February 20, 2016 Share February 20, 2016 Just did an overhaul at sin ming one of the gearbox specialised workshop. Put my car there on tuesday afternoon, just gotten my car back today. Less than 3 days overhaul. Hope it is a good overhaul as i see my car camera only off half a day due to removal of car battery. Think they replaced with another unit (recon...or whatsoever). The time needed to bring down & put back the gb is about half a day's work Link to post Share on other sites More sharing options...
LIMCS Neutral Newbie February 20, 2016 Share February 20, 2016 (edited) Think they replaced with another unit (recon...or whatsoever). The time needed to bring down & put back the gb is about half a day's work really ah bro? like that i feel cheated cos they supposed to overhaul and replace new parts for my gearbox. tuesday i went to ellipse auto to put my car in the afternoon and collected on thursday afternoon as seen my car cam, they only jack up my car about 7 pm in the night on tuesday 16th feb . which after camera came on back about 3 pm on wednesday 17th feb . then there after all the way camera was active till thursday 18th feb where shown they send to alignment and come back. i collect the car on 19th thursday about 4 pm. 2 days only. now the car is smooth and no delay in engagement from P to D. but how to check whether been replace by reconned gearbox or they really rebuilt my transmission. altogether i paid 2200 exclued 7 percent gst. altogether is 2354 Edited February 20, 2016 by LIMCS Link to post Share on other sites More sharing options...
Ivan_06 5th Gear February 21, 2016 Share February 21, 2016 Get manual transmission. 1 Link to post Share on other sites More sharing options...
AHBA 2nd Gear February 22, 2016 Share February 22, 2016 really ah bro? like that i feel cheated cos they supposed to overhaul and replace new parts for my gearbox. tuesday i went to ellipse auto to put my car in the afternoon and collected on thursday afternoon as seen my car cam, they only jack up my car about 7 pm in the night on tuesday 16th feb . which after camera came on back about 3 pm on wednesday 17th feb . then there after all the way camera was active till thursday 18th feb where shown they send to alignment and come back. i collect the car on 19th thursday about 4 pm. 2 days only. now the car is smooth and no delay in engagement from P to D. but how to check whether been replace by reconned gearbox or they really rebuilt my transmission. altogether i paid 2200 exclued 7 percent gst. altogether is 2354 Bro dun worry whether the unit is recon or original since your problem is solved. Happy driving! Link to post Share on other sites More sharing options...
Runforyourlife 5th Gear February 22, 2016 Share February 22, 2016 cvt gearbox can last beri beri long no worry. the worry is whether u can accept the way it sounds and works bros. Link to post Share on other sites More sharing options...
Camrytron 6th Gear February 22, 2016 Share February 22, 2016 Just did an overhaul at sin ming one of the gearbox specialised workshop. Put my car there on tuesday afternoon, just gotten my car back today. Less than 3 days overhaul. Hope it is a good overhaul as i see my car camera only off half a day due to removal of car battery. Bro what car is that? ↡ Advertisement Link to post Share on other sites More sharing options...
Singaporean are unhappy and poor
Volvo...for life (literally!)
Questions about Gearbox overhaul
Benefits of having bigger population in our day to day life.
