Keen 1st Gear May 5, 2011 Share May 5, 2011 it just remain like at 2.5K rpm and your speed just climbs to cruising? so I assume it's cvt? so what fluid do I need to use? cvt fluid or diaqueen? ↡ Advertisement Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged May 5, 2011 Share May 5, 2011 it just remain like at 2.5K rpm and your speed just climbs to cruising? so I assume it's cvt? so what fluid do I need to use? cvt fluid or diaqueen? For mit cvt, it wa normally specified to use Mit Diaqueen SP3 ATF, instead of those cvt fluid which nissan, toyota n honda cvt cars specified. Anyway for other jap car makers, their own brand ATF got non cvt, for cvt, got 2 or 3 diff grades. For mitsubitshi brand i have only seen Diaqueen SPIII, have not come across any Diaqueen Cvt before. The manual also specify Dizqueen SP3. Just stick to what your car manual states.... Link to post Share on other sites More sharing options...
Yuan 6th Gear May 5, 2011 Share May 5, 2011 (edited) oh, mine is a auto, just that not sure if it's cvt or the normal 4 speed auto... so for either case I only need to use Mitsubishi Diaqueen III? No need for cvt transmission fluid? Somebody answered your earlier query already Edited May 5, 2011 by Yuan Link to post Share on other sites More sharing options...
Keen 1st Gear May 9, 2011 Share May 9, 2011 cos in the manual I saw both MITSUBISHI DIAQUEEN CVT FLUID J1 and Mit Diaqueen SP3 ATF... So not sure what fluid to use... Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged May 9, 2011 Share May 9, 2011 cos in the manual I saw both MITSUBISHI DIAQUEEN CVT FLUID J1 and Mit Diaqueen SP3 ATF... So not sure what fluid to use... no wondering you are confused. I guess its meaning either one can be used. My wife's Colt Plus is also using CVT gearbox, but manual only states Diaqueen SPIII. Anyway i have not come across Diaqueen CVT Fluid J1 in Singapore. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged May 9, 2011 Share May 9, 2011 By the way how old is yr car? My wife's car manufactured in 2007.. maybe that time Mitsubishi hasn't produced CVT Fluid J1? Link to post Share on other sites More sharing options...
Yuan 6th Gear May 9, 2011 Share May 9, 2011 cos in the manual I saw both MITSUBISHI DIAQUEEN CVT FLUID J1 and Mit Diaqueen SP3 ATF... So not sure what fluid to use... I think I remembered it was Mitsubishi Diaqueen SP III. Anyway, I am changing my ATF fluid in a couple of weeks time when I send my car for servicing. I let you know after that. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged May 9, 2011 Share May 9, 2011 I think I remembered it was Mitsubishi Diaqueen SP III. Anyway, I am changing my ATF fluid in a couple of weeks time when I send my car for servicing. I let you know after that. yo, which tyre is good and quiet?? Link to post Share on other sites More sharing options...
Keen 1st Gear May 10, 2011 Share May 10, 2011 By the way how old is yr car? My wife's car manufactured in 2007.. maybe that time Mitsubishi hasn't produced CVT Fluid J1? The lancer is bought in 2006, not too sure on the cvt fluid... Link to post Share on other sites More sharing options...
Keen 1st Gear May 10, 2011 Share May 10, 2011 I think I remembered it was Mitsubishi Diaqueen SP III. Anyway, I am changing my ATF fluid in a couple of weeks time when I send my car for servicing. I let you know after that. You driving a a cvt lancer too? where you send for servicing? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear May 10, 2011 Share May 10, 2011 Mercy-mercy. Do compare apple to apple. Some are designed for lower usage. Example: a smaller engine does dictate the average service life, too. Link to post Share on other sites More sharing options...
Keen 1st Gear May 16, 2011 Share May 16, 2011 Oh ya is it normal for CVT gearbox not to change gear when I rev it till redline, it keep staying there and wun up shift... speed around 80 to 90... It's my first cvt car, so I am not so such about it... Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear May 16, 2011 Share May 16, 2011 Oh ya is it normal for CVT gearbox not to change gear when I rev it till redline, it keep staying there and wun up shift... speed around 80 to 90... It's my first cvt car, so I am not so such about it... it won't change gear.. go wiki how CVT works.. it is like Gilera bikes.. u cannot hear/feel drop in gear.. just lut the pedal and see the speed climb.. of cos, don't keep lut-ing la.. Link to post Share on other sites More sharing options...
Keen 1st Gear May 16, 2011 Share May 16, 2011 but the rpm stay at 6k rpm, normal? i tot even if i dun feel it it will change gear? Link to post Share on other sites More sharing options...
Ceecookie 5th Gear May 16, 2011 Share May 16, 2011 but the rpm stay at 6k rpm, normal? i tot even if i dun feel it it will change gear? It will stay there for as long as the accelerator is depressed to the max Link to post Share on other sites More sharing options...
Yuan 6th Gear May 16, 2011 Share May 16, 2011 You driving a a cvt lancer too? where you send for servicing? Outside workshop. Link to post Share on other sites More sharing options...
Yuan 6th Gear May 16, 2011 Share May 16, 2011 Oh ya is it normal for CVT gearbox not to change gear when I rev it till redline, it keep staying there and wun up shift... speed around 80 to 90... It's my first cvt car, so I am not so such about it... It should not change gear. Link to post Share on other sites More sharing options...
Yuan 6th Gear May 16, 2011 Share May 16, 2011 yo, which tyre is good and quiet?? Er, how about Hankook V12? Not too noise but good grip. Definitely not as quiet as yokohama aspec db. ↡ Advertisement Link to post Share on other sites More sharing options...
Singaporean are unhappy and poor
Volvo...for life (literally!)
Questions about Gearbox overhaul
Benefits of having bigger population in our day to day life.
