Pelican 1st Gear February 4, 2011 Share February 4, 2011 is aftermarket security system reliable? they could have some sort of master key to access your car after installing it into your car. ↡ Advertisement Link to post Share on other sites More sharing options...
Lanevomax 1st Gear February 4, 2011 Share February 4, 2011 i believe everything can be breakable. but the GSM sercurity system see not bad, will sms you if there is a break in. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear February 5, 2011 Share February 5, 2011 Alarm only to warn u someone is stealing your car. Security is just an extra layer to slow down the theft. Aftermarket system are almost the same as factory units. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear February 5, 2011 Share February 5, 2011 All standard system can be beaten. U will need to do some diy to make it harder for Car stealer. If they just want to steal the stuff inside your car, no alarms can help you. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Mercedes - Reliable?
Environment Building evacuated due to ‘security situation’; no threat items found so far: Grace Fu
FT discrimination agst locals
Stop False Accusation
Aftermarket car alarm
HELP! Need a reliable plumber & electrician
NASA's Voyager 1 is sending mysterious data from beyond our solar system. Scientists are unsure what it means.
