  • Search this thread
  • Reply to this topic
75 replies to this topic | 30 praises
#1
Posted 06 February 2011 - 10:52 PM
Grix17
  • THREAD STARTER
  • Grix17
    4th Gear
    Author Image
    958
Hi, I'm expecting a new car in a few weeks and am planning to put a few layers of sealant at the very start.
I have been using Autoglym SRP and Extra Gloss Protection for my current ride.
My question is this:
If the car is new, should I still use polish (SRP) before I apply the first layer of hard wax (Extra Gloss Protection)?
#2
Posted 06 February 2011 - 11:02 PM
Booboon
  • Booboon
    6th Gear
    Author Image
    2,827
I think no problem w srp. I would use es after srp. Es is super durable.
Nick Foo, 37
IT Trainer
Sometimes I quite Eng.
#3
Davc
  • Davc
    4th Gear
    Author Image
    667
Yes.
http://www.autoglym....il.asp?v06VQ=FH
#4
Posted 07 February 2011 - 01:00 AM
Zenith_Mazda
  • Premium member
    Zenith_Mazda
    2nd Gear
    Author Image
    113
what is ES?
#5
Posted 07 February 2011 - 08:02 AM
Mad_Detailer
  • Mad_Detailer
    Clutched
    Author Image
    28
what is ES?
should be EGP = Extra Gloss
#6
Posted 07 February 2011 - 08:09 AM
Mad_Detailer
  • Mad_Detailer
    Clutched
    Author Image
    28
Hi..congrat on your new ride..came across in autopia that SRP contain micro-abrasive in it..Not to worry actually..Just like some product..when on a polishing pads..it act as a polish product but on a finishing pads..it can be a finishing product..instead on doing some rubbing on the surface..Simply apply it without using any force or pressure on it..remove it with a dry cloth..Need not wait for it to haze since it is use as a cleaning only..
Cheers
Benny
#7
Posted 07 February 2011 - 11:27 AM
Nzy
  • Premium member
    Nzy
    2Fast2Furious
    Author Image
    26,363
Cheers
Benny
Most finishing products have some abrasives in them also. And quite alot of people also use srp as the last step of polishing before waxing. Wait for it to haze will be better because he is going to apply EGP after that. EGP was designed to work with SRP if I am not wrong and it will look better. SRP is also able to provide some protection like a sealant.
#8
Posted 07 February 2011 - 12:30 PM
Mad_Detailer
  • Mad_Detailer
    Clutched
    Author Image
    28
Finishing product as in LSP?? Care to share which LSP has abrasive in it..
My LSP would refer to as wax or a sealant..
Cheers
Benny
Edited by Mad_Detailer, 07 February 2011 - 12:43 PM.
#9
Posted 07 February 2011 - 03:56 PM
Nzy
  • Premium member
    Nzy
    2Fast2Furious
    Author Image
    26,363
Cheers
Benny
Finishing product I thought u really meant finishing polish cuz u asked him to use a finishing pad. Normally most people refer wax/sealant as LSP and not finishing product ma.
#10
Posted 07 February 2011 - 04:43 PM
Davc
  • Davc
    4th Gear
    Author Image
    667
Compound - Abrasive
Cleaner - some abrasive
polish - little or no abrasive
Wax/sealant - no abrasive
That's just a guide. Some product is cleaner polish, some is polishing sealant, etc. Some are one step cleaner wax.
Pure wax/sealant requires you to prep/prime the surface very clean. Therefore some wax contains cleaner/polish.
SRP alone has some sealant, but EG will add on more protection and gloss. It is like after using 2 in 1 shampoo on the hair, you go one more step by using dedicated hair treatment oil.
#11
Posted 07 February 2011 - 04:52 PM
Hulk
  • Premium member
    Hulk
    4th Gear
    Author Image
    794
Yes why not. Maybe you can clay it if u want. Sure a lot of contaminants on surface during shipping.
#12
Posted 07 February 2011 - 05:27 PM
Nzy
  • Premium member
    Nzy
    2Fast2Furious
    Author Image
    26,363
Compound - Abrasive
I thought usually polish is the one with some abrasives and cleaner is the one with little or no abrasive just to prep the surface for wax/sealant.
#13
Posted 07 February 2011 - 05:37 PM
Maddriver
  • Premium member
    Maddriver
    Sponsor
    Author Image
    11,378
I was referring to another product..an example only
WebsiteDuragloss Car Care products
WebsiteOptimum Car Care products
Contact : Call / SMS / WhatApps 93387370 Benny
#14
Posted 07 February 2011 - 07:38 PM
Davc
  • Davc
    4th Gear
    Author Image
    667
Depending on the maker, some of them named the cleaner to be higher abrasiveness, some named polish to be higher abrasiveness.
e.g. Meguiars Pro range, Cleaner/Compound very abrasive, and Cleaner/Polish is more abrasive than Pure Polish.
Meguiars
So just read the details what you are using, if you are going the detailer way.
If not, just use any DIY range of products no headache.
#15
Friendstar
  • Friendstar
    NOS-ed
    Author Image
    15,497
hi guys,
just wondering, where's Gen2?
he used to be in such threads often.
#16
Posted 07 February 2011 - 09:37 PM
Gen2
  • Premium member
    Gen2
    5th Gear
    Author Image
    2,287
I will suggest you do a proper wash down with car shampoo, clay if needed, than clean up the paint work with SRP and finish with EGP. You will not know what the dealer has put on the paint work, so it will be better to do a proper first coating when you have collected your car.
One suggestion when using the SRP, no need to apply so thick untill the whole car turns white. A thin even coating will be good enough. Hope this helps.
Edited by Gen2, 07 February 2011 - 09:49 PM.
When It Comes To Shine
There Is No Compromise
#17
Posted 08 February 2011 - 10:35 AM
Grix17
  • THREAD STARTER
  • Grix17
    4th Gear
    Author Image
    958
Haha, thanks for the useful tips =)
Thanks to everyone else for their suggestions too!
#18
Posted 18 March 2011 - 10:25 PM
Carspecialist
  • Carspecialist
    Author Image
    8
hi all,
i just bought a new car and would like to find out on some good recommendation for car wash products(cheap and good)?
and how often do you peepz wash your cars ( DIY or professional car washers)?
thank you in advance
#19
Posted 31 March 2011 - 04:18 PM
Liam123
  • Liam123
    Author Image
    5
First thing, I have a 2006 Toyota Vios. I just need an advice on how often should I put on some wax on its body? Anyone? The color of the car is all black and I am a bit careful on the color so that it will not fade. Is it good to apply wax regularly or just twice a year or thrice? Thanks! thumbsup.gif thumbsup.gif
#20
Posted 01 April 2011 - 12:36 PM
Skip
  • Premium member
    Skip
    2nd Gear
    Author Image
    184
I don't think frequent waxing will do any harm to your paintwork, frequent polishing may wear down the paint thickness though.
IMHO the frequency of wax application depends on the durability of the wax used. When I was on Collinite 476 it could last me a good 3-4 months, compared to the generic waxes from petrol kiosks or supermarket shelves which typically lasts a couple of weeks.
Back to Detailing  ·  Aftermarket Top Reply to this topic
Quick Reply
