Keithchue 5th Gear December 1, 2017 Share December 1, 2017 Just to add, my tires 235/65R18. Pressure at 30psi instead of the 33psi recommendation specs. Still doesn’t help with the harsh ride. Also, to improve ride comfort, any after mkt shocks to recommend? Was advice if change shocks, keep stock springs as after mkt springs not as good. Any comments? maybe check mountings, they are also absorbing some shock. ↡ Advertisement Link to post Share on other sites More sharing options...
ianest 1st Gear December 1, 2017 Share December 1, 2017 maybe check mountings, they are also absorbing some shock. You referring to engine and gearbox mountings? According to technician, they look ok during the 119 point inspection. Any other mountings ? Link to post Share on other sites More sharing options...
EmilyKoon December 26, 2017 Share December 26, 2017 maxspeedingrods, this site including air suspension, turbo, coilovers, connecting rods, crank, air bag, control arm, camber plates and other parts, pls let me know if you need, thanks 1 1 Link to post Share on other sites More sharing options...
ianest 1st Gear December 27, 2017 Share December 27, 2017 maxspeedingrods, this site including air suspension, turbo, coilovers, connecting rods, crank, air bag, control arm, camber plates and other parts, pls let me know if you need, thanks I'm interested to find out more. I drive a Murano 3.5. According to 2 different Tan Chong technicians at 2 different centres with test drive, they feel there is nothing wrong with suspension. I've been driving consecutive for last 20yrs, i don't think my butt is "sensitive". Perhaps SUV was meant to feel firm. I find my stock suspension system too stiff and prefers softer and more comfort ride. What would you recommend? Link to post Share on other sites More sharing options...
JusticeCg December 29, 2017 Share December 29, 2017 What kind of suspension u need? 1 Link to post Share on other sites More sharing options...
ianest 1st Gear December 29, 2017 Share December 29, 2017 (edited) I'm interested to find out more. I drive a Murano 3.5. According to 2 different Tan Chong technicians at 2 different centres with test drive, they feel there is nothing wrong with suspension. I've been driving consecutive for last 20yrs, i don't think my butt is "sensitive". Perhaps SUV was meant to feel firm. I find my stock suspension system too stiff and prefers softer and more comfort ride. What would you recommend? My sole interest is comfort ride. No idea what is required. I'll be grateful if anybody as suggestions. Change springs with lower spring rate? Edited December 29, 2017 by ianest Link to post Share on other sites More sharing options...
dcb Turbocharged January 1, 2018 Share January 1, 2018 (edited) Comfort? Stay stock. My sole interest is comfort ride. No idea what is required. I'll be grateful if anybody as suggestions. Change springs with lower spring rate? Edited January 1, 2018 by dcb 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear January 1, 2018 Share January 1, 2018 My sole interest is comfort ride. No idea what is required. I'll be grateful if anybody as suggestions. Change springs with lower spring rate? Check the tyres size, load and speed index vs the recommended. The recommendation would be in the owners manual or on the placard somewhere on the vehicle. Tyres forms part of the suspension - the sidewall stiffness contributes to the overall ride comfort. E.g. performance tyres that have stiffer side walls. different load index and speed index vs recommended old tyres with harden side walls - check the date code Link to post Share on other sites More sharing options...
ianest 1st Gear January 2, 2018 Share January 2, 2018 (edited) Comfort? Stay stock. Current is already stock. Unless the Tan Chong technicians are wrong, (they say suspension feels normal), else must change car liao... :-) Check the tyres size, load and speed index vs the recommended. The recommendation would be in the owners manual or on the placard somewhere on the vehicle. Tyres forms part of the suspension - the sidewall stiffness contributes to the overall ride comfort. E.g. performance tyres that have stiffer side walls. different load index and speed index vs recommended old tyres with harden side walls - check the date code tyre 235/65R18 . Tyre pressure pump 3psi below manual recommended. Edited January 2, 2018 by ianest 1 Link to post Share on other sites More sharing options...
dcb Turbocharged January 2, 2018 Share January 2, 2018 Current is already stock. Unless the Tan Chong technicians are wrong, (they say suspension feels normal), else must change car liao... :-) tyre 235/65R18 . Tyre pressure pump 3psi below manual recommended. If that’s the case then buy Bilstein dampers and eibach springs for your ride and adjust to softest damping. Hope it’s to your liking. Link to post Share on other sites More sharing options...
Kklee 6th Gear January 2, 2018 Share January 2, 2018 Current is already stock. Unless the Tan Chong technicians are wrong, (they say suspension feels normal), else must change car liao... :-) tyre 235/65R18 . Tyre pressure pump 3psi below manual recommended. What's the recommended? E.g A) Recommended 205/55R16 91V Front/Rear 220/210 - Original tyres bias towards comfort and quiet tyres B) Change to 205/55R16 91V Front/Rear 220/210 - Michelin PS3 bias towards performance. C) Change to 205/55R16 94W Front/Rear 210/220 - Michelin PS4 bias towards performance Comparing B to A - stiffer sidewalls - harsher ride comfort e.g. less tolerant to speed regulating strips - steering more responsive - better grip in wet/dry Compare C to B - softer sidewalls - at recommended pressure of 220/210, ride more bouncy - at recommend pressure - steering response too light and sensitive - at recommended pressure, slight reduction in wet/dry grip IMHO, if all else the same, the reduction of pressure maybe a no-no as it may compromise the traction and longevity (heat) of the tyre i.e. safety. Link to post Share on other sites More sharing options...
ianest 1st Gear January 2, 2018 Share January 2, 2018 If that’s the case then buy Bilstein dampers and eibach springs for your ride and adjust to softest damping. Hope it’s to your liking. thanks for recommendation. is there a specialized eibach distrubuter to recommend? where to go where technician knows a suitable spring rate for my requirement? dont want to end up with stiffer "performance" springs... :- ) What's the recommended? IMHO, if all else the same, the reduction of pressure maybe a no-no as it may compromise the traction and longevity (heat) of the tyre i.e. safety. Recommended front/rear 33 psi. I reduced rear to 30 psi. Link to post Share on other sites More sharing options...
dcb Turbocharged January 2, 2018 Share January 2, 2018 I will recommend Godspeed Auto. Look for Boss Lyonel. thanks for recommendation. is there a specialized eibach distrubuter to recommend? where to go where technician knows a suitable spring rate for my requirement? dont want to end up with stiffer "performance" springs... :- ) Link to post Share on other sites More sharing options...
ianest 1st Gear January 2, 2018 Share January 2, 2018 I will recommend Godspeed Auto. Look for Boss Lyonel. Thanks for recommend. wah Bro, the GodSpeed facebook is all about conti and performance cars. Will they be insulted if I ask them for comfort ride mode? 1 Link to post Share on other sites More sharing options...
dcb Turbocharged January 2, 2018 Share January 2, 2018 Won't la. They also do JDM rides. Thanks for recommend. wah Bro, the GodSpeed facebook is all about conti and performance cars. Will they be insulted if I ask them for comfort ride mode? Link to post Share on other sites More sharing options...
ianest 1st Gear January 2, 2018 Share January 2, 2018 Won't la. They also do JDM rides. Noted. Will drop by for their advise. thx! Link to post Share on other sites More sharing options...
dcb Turbocharged January 13, 2018 Share January 13, 2018 Have you done so? Noted. Will drop by for their advise. thx! Link to post Share on other sites More sharing options...
ianest 1st Gear January 15, 2018 Share January 15, 2018 Have you done so? Noped. Have been travelling. Why? ↡ Advertisement Link to post Share on other sites More sharing options...
ACG Performance - Official Distributor For Brembo, AirBFT Air Suspensions & GFG Forged Wheels!
Over 900 flats to be built in Sin Ming; first new HDB project in the area in over 30 years
