Chucky2007 Turbocharged May 24, 2011 Share May 24, 2011 so should I get Daikin or Mitsubishi? Both brands are good... installer more important. So google for reputable shops that can help you plan the aircon ducts layouts, and also good installers will lay nicely for you. ↡ Advertisement Link to post Share on other sites More sharing options...
Freestylers09 5th Gear May 24, 2011 Share May 24, 2011 easiest way is square feet x 60 unless inside alot people staying wif heavy electrical stuffs then x 70-80 Link to post Share on other sites More sharing options...
Sabian Turbocharged May 24, 2011 Share May 24, 2011 Both brands are good... installer more important. So google for reputable shops that can help you plan the aircon ducts layouts, and also good installers will lay nicely for you. The mech who services my aircon is not a fan of Daikin. He's seen a number of cases requiring replacement of the "control board" (translated from mandarin). Link to post Share on other sites More sharing options...
5936 1st Gear May 24, 2011 Share May 24, 2011 Yes I use this method. Minus bulky cabinets, Also to consider location of compressor, piping distance to furthest fan coil unit, Link to post Share on other sites More sharing options...
Hondavvvtec 1st Gear November 25, 2011 Share November 25, 2011 most ppl used 18K btu for their 4 room flat living hall, i think i made a mistake, i bought 26K btu for hall, is this considered as over loading ? what are the negative effects ? Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 25, 2011 Share November 25, 2011 most ppl used 18K btu for their 4 room flat living hall, i think i made a mistake, i bought 26K btu for hall, is this considered as over loading ? what are the negative effects ? If yours is inverter tech, i think the negative effect is negligible. Link to post Share on other sites More sharing options...
Goodspeed Clutched November 25, 2011 Share November 25, 2011 As a norm....rooms u can use 70 Btu/Sqrft as guide.. U get the total sqrft and X 70 and you get the BTU u need. U can add in safety factor of 1.2 but try to get inverter type. For living room, it will be good to oversize because of high heat load Link to post Share on other sites More sharing options...
SimonTan 2nd Gear November 25, 2011 Share November 25, 2011 Inverter is just a fanciful name for variable speed. It just means the compressor can self control the motor speed to lower when the cooling demand is low. Those non inverter type, only operates at one maximum speed, no matter what is your temperature setting. So it consumes same high energy, when you don't need too much air con power. Because people like to cool their room fast, the air con compressor usually are oversized to have sufficient power to do that. When the room is cold to the desired temperature, the compressor motor should not require to spin so fast to cool the room anymore. Inverter type will varies the compressor motor speed to cater for the lower demand, thus saving electricity, as compared to a non inverter type that it's motor still spin at maximum speed no matter what is the cooling demand. Link to post Share on other sites More sharing options...
West_end Neutral Newbie November 26, 2011 Share November 26, 2011 Thank you very much for the efforts in sharing your knowledge. I find it highly informative. ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Car air-con
Car air-con
How do I calculate my deregistration value?
