Ikeehc Clutched May 29, 2011 Share May 29, 2011 Had the same problem. Engine came on after a day on rest. Switched it off. Let it rest for a couple of hours and the engine went off after a few seconds. Its been two weeks now. Might just bring back to c&c next week ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 29, 2011 Share May 29, 2011 (edited) ever check engine light lighted , my car pickup power was really bad. I removed all spark plugs and inspect individually. one of the plugs was faulty(the ground electrode actually bend towards the centre electrode )I change to a new set of spark plugs, engine light still lighted though. after driving for about 30km and park the car,the check engine light went off the next time I start the car. How come the electrode can bend? Something must hv hit it? Is the plug the correct type? Edited May 29, 2011 by Pisces69 Link to post Share on other sites More sharing options...
Aveo6 Neutral Newbie May 29, 2011 Share May 29, 2011 If the engine checked light is due to O2 sensor, is it safe to drive on the road? I took over this car few month ago, the light keep coming back... Any advice? Link to post Share on other sites More sharing options...
Plim72 Neutral Newbie May 29, 2011 Share May 29, 2011 If the engine checked light is due to O2 sensor, is it safe to drive on the road? I took over this car few month ago, the light keep coming back... Any advice? depends..typically, most modern jap cars came with two 02 sensors, more for conti...if it is second 02 sensor at the cat, then you are safe. if it is the first o2 sensor, then your fc is going to be bad, sluggish performance and misfiring. can you live with that? if no, get the sensor swapped or replace Link to post Share on other sites More sharing options...
ER-3682 Twincharged May 29, 2011 Share May 29, 2011 How come the electrode can bend? Something must hv hit it? Is the plug the correct type? Maybe too much Acetone in the petrol.! Link to post Share on other sites More sharing options...
Kusje Supersonic May 29, 2011 Author Share May 29, 2011 so, whats the outcome? Sorry for the slow update. CNC did a check and the diagnostics said that the Throttle Body sensor wasn't working properly. They cleaned it or something and reset the code - check engine light went off and car isn't sluggish anymore. I am to monitor the situation and go back if it happens again. Total cost: $64.20. Link to post Share on other sites More sharing options...
Mauiman Neutral Newbie May 30, 2011 Share May 30, 2011 Sorry for the slow update. CNC did a check and the diagnostics said that the Throttle Body sensor wasn't working properly. They cleaned it or something and reset the code - check engine light went off and car isn't sluggish anymore. I am to monitor the situation and go back if it happens again. Total cost: $64.20. The throttle body of lancer ex 1.5 needs to be cleaned every 50K. Else check engine light will show and engine can only go up to 2K rpm only. I also driving ex 1.5, encountered twice liao. After cleaning throttle body and reset ecu ok le. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 30, 2011 Share May 30, 2011 Maybe too much Acetone in the petrol.! Seems very strange the metal electrode can bend. Something must hit it to make it bend. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 30, 2011 Share May 30, 2011 The throttle body of lancer ex 1.5 needs to be cleaned every 50K. Else check engine light will show and engine can only go up to 2K rpm only. I also driving ex 1.5, encountered twice liao. After cleaning throttle body and reset ecu ok le. Wah every 50K km must clean TB? That is with or without air filter installed? Link to post Share on other sites More sharing options...
Acerchan2002 Clutched May 30, 2011 Share May 30, 2011 Spark Plug faulty very easy to identify. Idle at traffic light, the car will vibrate and vibrate. Link to post Share on other sites More sharing options...
Wongkeanchung Neutral Newbie May 30, 2011 Share May 30, 2011 been using the plug for about 3k km see attach, left plug is the bended one and right is healthy Link to post Share on other sites More sharing options...
Wongkeanchung Neutral Newbie May 30, 2011 Share May 30, 2011 ah, correct not only that, when switch on aircon can see the rpm needle vibrate Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged May 30, 2011 Share May 30, 2011 Spark Plug faulty very easy to identify. Idle at traffic light, the car will vibrate and vibrate. The excessive vibration can also be due to worn engine mountings. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 30, 2011 Share May 30, 2011 been using the plug for about 3k km see attach, left plug is the bended one and right is healthy Very unusual unless u using plug with too long tip? Only thing is piston hit the plug. Link to post Share on other sites More sharing options...
Hulk 1st Gear May 30, 2011 Share May 30, 2011 Spark Plug faulty very easy to identify. Idle at traffic light, the car will vibrate and vibrate. Yes correct. I just replaced my spark plugs due to above cos misfire, when stop engine is dancing like going to die anytime Link to post Share on other sites More sharing options...
Mauiman Neutral Newbie May 30, 2011 Share May 30, 2011 Wah every 50K km must clean TB? That is with or without air filter installed? With K&N filter for mine. But throttle body is really dirty at 50000km... Link to post Share on other sites More sharing options...
ER-3682 Twincharged May 30, 2011 Share May 30, 2011 With K&N filter for mine. But throttle body is really dirty at 50000km... Actually K&N air filter let dirt in easily...very common...that why it is called "FilterCharger". Link to post Share on other sites More sharing options...
Kusje Supersonic May 30, 2011 Author Share May 30, 2011 Wah every 50K km must clean TB? That is with or without air filter installed? Mine also around 50k+ then give problem..... ↡ Advertisement Link to post Share on other sites More sharing options...
Music Concerts
Music Concerts
KIA K3 Owners check-in!
2023 Mercedes-AMG C63 S E Performance
Do officials still check the 3/4 tank rule at causeway?
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
