MyCarForum Logo
Search
Magnifying glass
  • Search this thread
  • Reply to this topic
55 replies to this topic | 0 praises
#1
Posted 03 June 2011 - 07:13 PM
RadX
  • THREAD STARTER
  • Premium member
    RadX
    Moderator
...first flash, now dis....
http://blog.macsales...ns-on-new-imacs
Apple Further Restricts Upgrade Options on New iMacs
Thursday, May 12th, 2011 | Author: OWC Michael
Since Late 2009, there’s been a well-documented issue with the iMac line. If you upgrade the hard drive, the fans can start spinning like crazy. The fans at high speed are loud, mainly unnecessary, and have caused a lot of headaches for DIYers everywhere.
The reason the fans spin this way has to do with the iMac’s method of hard drive temperature sensing. Prior to 2009, sensors were placed outside the hard drive to gauge how warm the drives were – if they got too hot, the fans turned on to keep everything nice and cool. This method was simple, effective and made changing, exchanging, or upgrading the main hard drive a relatively simple task.
With the release of the Late 2009 iMac, Apple changed the way the iMac communicates with the drive for that heat-sensing information. Each brand of hard drive Apple used had its own specific thermal sensor cable which connected to certain drives that featured internal temperature sensing. We found that you could still change the drive, albeit with a limited selection. Seagate drives could be swapped with larger capacity Seagate drives; Western Digital could be swapped with other Western Digital Drives; and so forth. There were also reports of other workarounds which included replacing the internal sensor with an external sensor (like the one from the optical drive bay), controlling the fans with software, or purchasing a replacement cable that matched your brand of new hard drive. In any event, there were perhaps a few convoluted ways to upgrade your iMac’s main drive outside of Apple’s offerings for greater speed, more capacity or to quickly restore a machine from a drive failure yourself.
This time around, Apple has changed the game again.
For the main 3.5″ SATA hard drive bay in the new 2011 machines, Apple has altered the SATA power connector itself from a standard 4-wire power configuration to a 7-wire configuration. Hard drive temperature control is regulated by a combination of this cable and Apple proprietary firmware on the hard drive itself. From our testing, we’ve found that removing this drive from the system, or even from that bay itself, causes the machine’s hard drive fans to spin at maximum speed and replacing the drive with any non-Apple original drive will result in the iMac failing the Apple Hardware Test (AHT).
In examining the 2011 27″ iMac’s viability for our Turnkey Upgrade Service, every workaround we’ve tried thus far to allow us to upgrade the main bay factory hard drive still resulted in spinning fans and an Apple Hardware Test failure. We swapped the main drive out (in this case a Western Digital Black WD1001FALS) with the exact same model drive from our inventory which resulted in a failure. We’ve installed our Mercury Pro 6G SSD in that bay, it too results in ludicrous speed engaged fans and an AHT failure. In short, the Apple-branded main hard drive cannot be moved, removed or replaced.
To add insult to injury, the latest iMac EFI Update 1.6 unleashed 6Gb/s speeds on two internal ports – and naturally, one of them is the proprietary, firmware-limited, 7200RPM main drive that can’t take advantage of those speeds anyway.
Now this isn’t to say that our Turnkey Upgrade Program isn’t going to include the new model iMacs. The external eSATA port, or adding hard drives or SSDs in addition to the main hard drive are still perfectly viable and working options in our testing so far. But it isn’t looking good at the moment to have the option to upgrade or even replace the main 3.5″ hard drive as shipped from Apple.
It really begins to raise questions: Is this planned obsolescence at work, or is the freedom promised in 1984 being revoked?
Hard drives fail. It is not a matter of “if” but rather a matter of “when” your hard drive is going to fail. We preach this all the time in regards to having a proper backup strategy in place to prepare from when that failure happens. But it seems now, that when that happens to the main drive on your iMac, you’re left with two options – buy a new drive from Apple and have them install it via one of their Authorized Service Centers, or enjoy the rather large Apple logoed paperweight on your desk. Want a 3.5″ drive larger than 2TB? Too bad – Apple doesn’t offer them.
As die-hard Apple users, we tout all the time that its OK that Apple machines cost more initially, since they’re built better and last so much longer than their PC counterparts. Besides, there’s places like Other World Computing that help keep those aging Macs still powering along as viable machines with upgrades and accessories designed to give you the most out of your Mac investment.
I actually purchased a 27″ 2010 iMac Core i5 earlier this year. I was a bit nervous about Apple’s apparent push toward making OS X more iOS like and wanted the option to upgrade or opt to stay with Snow Leopard for my home machine. I was feeling the buyer’s remorse, just a little bit, when Apple added, not one, but two Thunderbolt ports to the back of the latest model. That kind of speed down the line would certainly allow for plenty of future storage expansion. Once Thunderbolt equipped enclosures finally come to market and all the bugs are worked out, of course. I’m just not the “early adopter” type.
I gotta be honest, I’m not feeling one bit of that remorse anymore. I have a machine that I’m certain I can keep maintained myself with products from OWC for many years to come. If my main hard drive does fail, I know I have options available to replace it. If I need an overall speed boost, I know I can get an OWC Mercury Extreme SSD and install that as my boot drive. If I find I need a faster connection than FireWire 800, I can always add a high-performance eSATA port through the TurnKey Upgrade Program. In short, I have multiple options available to me to configure my iMac to my particular needs.
New iMac envy? Nah…I’ll take the freedom of choice over limitations any day of the week.
RESPECT is only for the DEAD!
#2
Posted 03 June 2011 - 07:16 PM
Beehive3783
  • Premium member
    Beehive3783
    NOS-ed
    Author Image
    17,722
Haha.. farking Apple.. always coming up with proprietary designs and connectors. That's exactly why till now I don't have a single Apple product in my possession.
Cheers
Ben
#3
Posted 03 June 2011 - 07:22 PM
Chucky2007
  • Premium member
    Chucky2007
    Author Image
    7,848
i used to have no apple products... but no choice their product damn popular.. so bought Iphone 3GS for wife previous year, bought iphone4 this year & sold it for profit, and now buy ipad for wife...and damn the ipad2 Jailbreak is not yet!!!!!!!!!! Its damn irritating & apple is really control freak. I dun feel so restricted using my Android phone..
有❤️就好👌
多做少说,多听👂少讲
做人吃点亏,莫占人便宜
#4
Posted 03 June 2011 - 07:27 PM
Booboon
  • Booboon
    6th Gear
    Author Image
    2,815
ppl sell kidney for ipad2 wor
Nick Foo, 37
IT Trainer
Sometimes I quite Eng.
#5
Posted 03 June 2011 - 07:29 PM
Shull
  • Premium member
    Shull
    2Fast2Furious
    Author Image
    28,215
Kudos to both of you.. Me too, so far, i refuse to buy any Apple product.. I hate their controlling business model, so don't want my money to go into their bank account.
2002 Honda Civic ES8 (2003-2013) | 2009 Honda Civic FD2 (2009 - present) | 2007 Mitsubishi Lancer CS3 (2013 - present)
Visit my travel blog at http://almostafreque...er.blogspot.com
#6
Posted 03 June 2011 - 07:37 PM
Turboflat4
  • Premium member
    Turboflat4
    2Fast2Furious
    Author Image
    33,480
Watch: http://www.southpark...1-humancentipad
Much better if you've seen the B-grade gross-out horror movie "Human Centipede".
We live in a primitive time, don't we, Will? Neither savage nor wise. Half measures are the curse of it; any rational society would either kill me or put me to some use.
#7
Posted 03 June 2011 - 08:12 PM
Deathism
  • Deathism
    4th Gear
    Author Image
    599
lmao..hilarious!
#8
Posted 03 June 2011 - 08:53 PM
Blackyv
  • Premium member
    Blackyv
    2Fast2Furious
    Author Image
    26,097
Very funnier that those who choose to buy apple product and yet, complain about it knowing well in advance what to expect... me too, never own an apple product before and not intend to do so as far as I can see.... I'm rebellious type and like freedom...
#9
Posted 03 June 2011 - 08:59 PM
Tianmo
  • Premium member
    Tianmo
    2Fast2Furious
    Author Image
    60,198
just when I am about to go buy an Imac air..................I see this ............. smallcry.gif
芸芸人海,罪孽深重,神佛不渡,唯我魔渡
with the spirit of the MCF tiko club..............We are................ TIKO RANGERS!!!
#10
Posted 03 June 2011 - 09:01 PM
Chucky2007
  • Premium member
    Chucky2007
    Author Image
    7,848
really meh????
有❤️就好👌
多做少说,多听👂少讲
做人吃点亏,莫占人便宜
#11
Posted 03 June 2011 - 09:28 PM
Greggywong
  • Greggywong
    2nd Gear
    Author Image
    218
really meh????
Go and read the news la!
#12
Posted 03 June 2011 - 09:30 PM
Kangadrool
  • Premium member
    Kangadrool
    2Fast2Furious
    Author Image
    33,238
MacBook Air has no hard drive; using flash storage. Both storage and RAM are soldered to logic board. So, not upgradeable. Buy one in stock condition that suit your requirements. sleep.gif
#13
Posted 03 June 2011 - 09:53 PM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    29,650
Wow, I didn't know there's quite a few like me. Thought I am the only one.
I am also not using any Apple products. No iPhone, iPod, iTouch, iPad, mac, etc.
Bcoz we are not an iAddict.
Edited by Fcw75, 03 June 2011 - 09:54 PM.
#14
Posted 03 June 2011 - 10:40 PM
Tianmo
  • Premium member
    Tianmo
    2Fast2Furious
    Author Image
    60,198
oh.........my bad.......is macbook air......name also kan salah.............. blush.gif
I no need upgrade one lah...........very basic usage...........no play game...........not doing any design work.............just want it slim and light so that can bring around.............do some work (MS office), email, surf MCF............
thought of those tablet, but still think a proper notebook is better....................
芸芸人海,罪孽深重,神佛不渡,唯我魔渡
#15
Posted 03 June 2011 - 11:19 PM
Bystander50
  • Bystander50
    6th Gear
    Author Image
    4,938
Same here, you paid for the product, by right you are free to do whatever you want with it.
This is precisely the reason why I refused to get an Iphone. The bluetooth file transfer option is deliberately disabled. Iphone 4s or any past generation Iphones that goes back to Apple care will have their screws replaced so that you cannot repair or replace the battery yourself. And unless you jailbreak the phone, you can't freely download any apps not approved by them.
#16
Posted 03 June 2011 - 11:22 PM
Bystander50
  • Bystander50
    6th Gear
    Author Image
    4,938
That guy is a fool to do so. In another 1-2 years, the ipad 2 will be replaced with a newer model.
Comparing the Ipad to a netbook, I rather get a netbook that has more functionality and less restrictions and can install any applications freely. The Ipad just look like a giant Iphone.
I can upgrade the RAM and harddisk as I like without the need to go back Apple (provided it is upgradable).
Edited by Bystander50, 03 June 2011 - 11:25 PM.
#17
Posted 03 June 2011 - 11:37 PM
Pltang
  • Pltang
    5th Gear
    Author Image
    1,090
the upgradin is endless.... in long run.. is the current product that cant upgrade more worth it... or keep upgrading old product with more $?
Mitsubishi Colt sold at mileage: 110467
#18
Posted 03 June 2011 - 11:43 PM
Alpha78
  • Premium member
    Alpha78
    6th Gear
    Author Image
    4,245
Normal is getting dressed in clothes that you buy for work and driving through traffic in a car that you are still paying for in order to get to the job you need to pay for the clothes and the car, and the house you leave vacant all day so you can afford to live in it.
#19
Posted 03 June 2011 - 11:44 PM
Sohboonguan
  • Sohboonguan
    5th Gear
    Author Image
    1,528
maybe i buy your kidney for 5000 SGD.. better then 4000++ right?
lolz
*disclaimer: MY POSTS ARE PURELY FOR ENTERTAINMENT USE ONLY!
#20
Posted 04 June 2011 - 12:08 AM
Ocean6576
  • Ocean6576
    4th Gear
    Author Image
    886
Quick Reply
