  • 1
  • Search this thread
  • Reply to this topic
10 replies to this topic | 0 praises
#1
Posted 09 June 2011 - 09:35 PM
Shor
  • THREAD STARTER
  • Shor
    5th Gear
    Author Image
    2,069
Recently my car tremble when it's on red light no matter I put the gear to D or N . I was wondering what went wrong. Was thinking that might be the engine mounting, what will be more likely? Any bros know? Any inputs appreciate. Thank you very much!
If that's engine mounting, is it necessary to replace all four ? And what will be the costs like?
Edited by Shor, 09 June 2011 - 09:42 PM.
Regular naps prevent old age, especially if you take them while driving.
http://roadtriptotha...o-thailand.html
#2
Posted 20 June 2011 - 08:22 PM
Royong
  • Royong
    Author Image
    7
encounter similar condition b4. The problem is the engine mount. But it is adviseable to look for specialist for your car model. Cause the mechanic (who specialise in my car model suzuki swift) recommend me to just change one of the engine mount as it is a common wear and tear for swift. if I go to other mechanic, most probably they will recommend me to change all three engine mount.
#3
Posted 20 June 2011 - 08:27 PM
5936
  • Premium member
    5936
    6th Gear
    Author Image
    3,901
idling speed a bit low.
For older conti car, it may be dirty idling controller.
my 2 cents
#4
Posted 20 June 2011 - 08:28 PM
Grimicer
  • Premium member
    Grimicer
    Clutched
    Author Image
    44
sounds a lot like engine mount issues, however, they have been recommendations to change all 4 engine mounts as if you change 1 engine mount and it does not solve the problem, you need to change the other 3 which is double labor charge.
(and the labor charge is not cheap!)
#5
Posted 20 June 2011 - 08:47 PM
Shor
  • THREAD STARTER
  • Shor
    5th Gear
    Author Image
    2,069
It's recommended to change all 3 or 4 at one time. Save the trouble and labor fee for the next time.
#6
Posted 20 June 2011 - 09:00 PM
Nikamura
  • Nikamura
    4th Gear
    Author Image
    508
yep really depends on what car you driving.. for swift its always the one on the driver side that give way.
but TS got experince hearing a "tock" sounds when accelerating off from stationary?
if not that it might be the ignition coil gonna up the lorry too. 2 pcs of it.. not cheap to change too.
#7
Posted 20 June 2011 - 09:12 PM
Edca
  • Premium member
    Edca
    2nd Gear
    Author Image
    117
I'm having this problem too. But my car just less than 3 years. How come so fast got problem?
#8
Posted 20 June 2011 - 10:56 PM
Grimicer
  • Premium member
    Grimicer
    Clutched
    Author Image
    44
what car are you driving?
#9
Posted 21 June 2011 - 10:20 PM
Royong
  • Royong
    Author Image
    7
If ur car is less then 3 yr, do u still hv warranty? Try going bk to change for a new set for free. U nor know.
#10
Posted 21 June 2011 - 11:15 PM
Elevatorman
  • Elevatorman
    Author Image
    The number of points accumulated from users who Praise or Disliked your posts.
    0
The next time it happens, take a look on the RPM, does it drop when tremble. I think engine mount should not cause RPM to drop.
#11
Posted 21 June 2011 - 11:26 PM
Shor
  • THREAD STARTER
  • Shor
    5th Gear
    Author Image
    2,069
Mine RPM did not drop. But the tremble is minor, I just leave it. Actually engine mount is very cheap, but the labor is much more Expensive.
  • 1
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Quick Reply
Tags: Car, trembles, moving
