  • Search this thread
  • Reply to this topic
92 replies to this topic | 196 praises
#1
Posted 12 June 2011 - 11:03 PM
Tleslie
  • THREAD STARTER
  • Premium member
    Tleslie
    4th Gear
    Author Image
    571
recently i noticed my headlights turn yellowish. the clear plastic cover the light bulb... looks like stain.
i saw some of the cars with such condition too.
anyone can advise how to remove the stain?
3 Anonymous members praised this
#2
Posted 12 June 2011 - 11:29 PM
Iiiusion
  • Premium member
    Iiiusion
    3rd Gear
    Author Image
    396
Use Meguiars PlastX / Mothers Plastic Polish
Might have to use those ultra fine sand paper before the above if v.serious case
Not sure how long it will last before yellows again
Edited by Iiiusion, 12 June 2011 - 11:29 PM.
#3
Posted 12 June 2011 - 11:47 PM
Sky61
  • Sky61
    5th Gear
    Author Image
    1,050
i'm using this, its better than plastx. autobacs sells them
#4
Posted 08 July 2011 - 03:12 PM
LouislexusGS
  • LouislexusGS
    1st Gear
    Author Image
    54
Go to Home-Fix and look for this Coat-Innovative Headlamp Restoration Kit. You get a pair of new headlamps again.
#5
Posted 08 July 2011 - 09:34 PM
5936
  • Premium member
    5936
    6th Gear
    Author Image
    3,901
Fine sand paper treatment should be done by the expert. Damage is non reversible.
Just use the meguar plastic X is good enough.
it is very good and effective on plastic. acrylic and not abrasive.
#6
Posted 08 July 2011 - 10:05 PM
Track
  • Premium member
    Track
    3rd Gear
    Author Image
    305
What about the inside surface of the headlight? Need to clean up?
2 Anonymous members praised this
#7
Posted 08 July 2011 - 10:16 PM
5936
  • Premium member
    5936
    6th Gear
    Author Image
    3,901
Usually cleaning and polishing oxidised external surface will solve problem.
Internal side is more or less concealed from environment.
I have not encounter inner side of lens turning yellow.
Inner lens cleaning is a big job, water may leaked into lens after removal for cleaning.
Hope yours require external cleaning only.
#8
Posted 08 July 2011 - 11:00 PM
Gendut
  • Gendut
    5th Gear
    Author Image
    1,537
Have you replaced your headlight bulbs before?
Did you change to the correct aftermarket type?
Here is something that a lot of people do not know. Modern headlight covers are made of plastic. Plastic degrades over time and accelerates its degradation when exposed to UV light to cause it to yellow and turn opaque.
The bulbs that you use should emit light that do not harm its lenses if they are made of plastic. For example if you use a H7 bulb, ensure that its replacement is identified as H7U. 'U' here means it cuts out the UV light. biggrin.gif
There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call The Twilight Zone.
Rod Serling
#9
Posted 08 July 2011 - 11:22 PM
Tigershark1976
  • Premium member
    Tigershark1976
    2Fast2Furious
    Author Image
    22,246
brake fluid can help to restore the headlight. but use with care. NEVER let the brake contact with the paint surface....
#10
Posted 08 April 2012 - 10:46 PM
Tailgatepro
  • Tailgatepro
    2nd Gear
    Author Image
    190
recent sold my 6 year old car and bought 2009 car. But this 3 year old car and the headlight is very yellow.
The DIY liquid can easily remove the stain but i found that is not as smooth as my 6 year old car.
I was wonder, is it previous owner send of polish workshop and they polish away the headlight coating protection?
Because i never use soap or don't bother on my 6 year old car and still look like new.
1)Pls advise is there a coating for original headlamp?
2) If yes, is there a coating to protect for at least 5 years. Since original coating can be done, why not aftermarket
#11
Posted 08 April 2012 - 11:16 PM
Davidtkl
  • Davidtkl
    6th Gear
    Author Image
    4,625
Do you happen to drive the previous generation of Mercedes C Class? This is what I noticed in most of them.
#12
Posted 08 April 2012 - 11:21 PM
13177
  • 13177
    2Fast2Furious
    Author Image
    28,109
Headlights turn yellowish can be clean off?! How about headlights turn 'rough' on the surface? unsure.gif
Clothe yourselves with compassion, kindness, humility, gentleness and patience.
Life is very fragile. Nobody knows what's gonna happen next.
#13
Posted 08 April 2012 - 11:23 PM
Picanto
claybar?
#14
Posted 10 April 2012 - 10:40 AM
13177
  • 13177
    2Fast2Furious
    Author Image
    28,109
claybar?
#15
Posted 10 April 2012 - 10:53 AM
Girl_powerful
  • Girl_powerful
    2nd Gear
    Author Image
    110
Wouldn't really help if the car is always parked under the hot sun, mine not only turn yellowish but also have some fine cracks inside the light cover?!
Edited by Girl_powerful, 10 April 2012 - 10:54 AM.
#16
Posted 10 April 2012 - 11:03 AM
Keithchue
  • Premium member
    Keithchue
    6th Gear
    Author Image
    2,771
send to autobacs..think they can restore for you
every day wont be the same after you make a wrong decision.
#17
Posted 10 April 2012 - 03:06 PM
Picanto
it can remove the smoothness of the headlight surface. as for the yellowish stains, you have to source for another product that can do the job
#18
Posted 10 April 2012 - 03:24 PM
Cba6p
  • Cba6p
    3rd Gear
    Author Image
    340
ahem2x...is it a Toyota??
#19
Posted 27 May 2012 - 08:50 PM
Stam
  • Premium member
    Stam
    1st Gear
    Author Image
    75
Only need to buy the products, any other things?
#20
Posted 28 May 2012 - 08:49 AM
Jessica1
  • Jessica1
    Author Image
    7
Thanks for your post.
Back to Detailing  ·  Aftermarket Top Reply to this topic
Meguiar's Clarity Glass Cleaner
Meguiar's Clarity Glass Cleaner  |  Rating   Submit Review
Reviewed by Dynaway  |  5th Gear
Good Smell, no streak cleaner
The smells is wonderful. Most importantly it does not streaks on glass. Very easy to wipe off. Not expensive.
Meguiar's Ultimate Wax Liquid
Meguiar's Ultimate Wax Liquid  |  Rating   Submit Review
Easy on easy off.
Easy to apply and easy to remove. Plastic and rubber friendly. Does not leave white stain on corners. Smell good no pungent chemical smell.
Related Product Guide search on sgCarMart.com : Car Wax, Car Polish
Quick Reply
Tags: headlights, turn, yellowish and 2 more...
