Tailgatepro 1st Gear June 17, 2011 Share June 17, 2011 How to choose a amp by spec?? Copy & paste from one of the amp spec: High-Pass Crossover Frequency: 30 - 400Hz ( how to choose this? is it 10 - 600hz better then 30-400 hz?) High-Pass Slope (Per Octave) 12dB ( higer dB better or lower?) Low-Pass Crossover Frequency 30 - 400Hz ( border ranger better?) Low-Pass Slope (Per Octave) 12dB (higer score of dB better or lower?) Total Harmonic Distortion 1% ( i think i know this, lower % the better) Signal-to-Noise Ratio 78dB ( i think lower the better, correct?) ↡ Advertisement Link to post Share on other sites More sharing options...
Fastfive1 5th Gear June 17, 2011 Share June 17, 2011 from what i know Signal-to-Noise Ratio the higher the better. Link to post Share on other sites More sharing options...
Mona-vie 1st Gear June 20, 2011 Share June 20, 2011 These specs you mentioned is not that important. More important is power output. How many watts at 8ohms, 4ohms? Also at what THD? If they rate 10% THD @ 200W, this amp is probably capable of only 100W or less (no one can listen with 10% THD). Also, can the amp produce enough current to drive the speakers. If its rated at 200W 8ohms but just 300W 4ohms, this means it cannot produce enough current to double power for 4 ohms speakers. Then have to read reviews like sound quality, imaging, brightness etc....... Cause specs alone does not tell the whole story about the amp. Link to post Share on other sites More sharing options...
Mona-vie 1st Gear June 20, 2011 Share June 20, 2011 Btw, there is one thing about power matching. You need to know the sensitivity of your speakers as well. Less sensitive speakers need more power to drive. Hence need to match the amp to the speaker. Link to post Share on other sites More sharing options...
Kinrad Neutral Newbie June 23, 2011 Share June 23, 2011 Here's what I do with out the Specs before I buy or use any amp or sound system in my car First, I ask the salesperson or installer what power rating you should consider based on your existing stereo, speakers and musical taste. Then probably select two or three amplifiers to compare. First, Compare amplifiers power ratings using the same parameters - ohms rating, voltage or frequency. (Most people in the industry use ohms rating as the standard of comparison, and set the standard at 4 ohms.) Ask the salesperson to plug the possible amplifiers into a radio and speakers that are similar to the ones in your car. Listen to the performance of each amplifier and select the one that sounds best to you. Check the physical size of the amplifier to make sure it will fit where you plan to put it. ↡ Advertisement Link to post Share on other sites More sharing options...
Which CRM is Right for Me? How to Choose a CRM?
ST CloseUp: Why some women choose to be child-free
Career switch interest vs Boss which one you choose
Which SUV would you choose for now?
Which comfort tyre to choose?
How to choose a HQ vas5054a clone
Which car to choose?
