Xspace 1st Gear August 27, 2011 Share August 27, 2011 This video is interesting... - ↡ Advertisement Link to post Share on other sites More sharing options...
Picanto 3rd Gear August 27, 2011 Author Share August 27, 2011 you go where to install? is there any at serangoon area? :) go to foon audio or wowgadgets.com Link to post Share on other sites More sharing options...
Civic_newb Neutral Newbie August 28, 2011 Share August 28, 2011 you go where to install? is there any at serangoon area? :) Hi Lezzo, You can find the Black Vue Singapore dealers here http://www.blackvue.com.sg/authorized-dealers.html I believe nearest is NightzConcepts in Serangoon, I have done my Day Light LED there, good workmanship but this light is not LTA friendly Link to post Share on other sites More sharing options...
Lezzo Clutched August 28, 2011 Share August 28, 2011 Hi Lezzo, You can find the Black Vue Singapore dealers here http://www.blackvue.com.sg/authorized-dealers.html I believe nearest is NightzConcepts in Serangoon, I have done my Day Light LED there, good workmanship but this light is not LTA friendly thanks bro. i called wow gadget and was told night conceptz too. haha. how much u do the daylight led there? Link to post Share on other sites More sharing options...
Mooneyes Neutral Newbie August 28, 2011 Share August 28, 2011 Hi how to change to 16g card? Do I copy black vue File from original 4g card? Link to post Share on other sites More sharing options...
Civic_newb Neutral Newbie August 30, 2011 Share August 30, 2011 (edited) Hi how to change to 16g card? Do I copy black vue File from original 4g card? I don't think this is the correct way but there is procedure in the local Black Vue website http://www.blackvue.com.sg/support.html I tried and it is actually very easy Edited August 30, 2011 by Civic_newb Link to post Share on other sites More sharing options...
Mooneyes Neutral Newbie August 30, 2011 Share August 30, 2011 Ok thanks will try it out. Actually I down loaded new firmware for pittasoft website. But 16g card stop recording after parking for few hour.Original 4g has no problem? Link to post Share on other sites More sharing options...
Tigerdhm Neutral Newbie August 31, 2011 Share August 31, 2011 Hi Bros, is the indicator light on the BV very bright? Does it cause any distractions when driving at night? Thanks. Link to post Share on other sites More sharing options...
Tarquin 1st Gear August 31, 2011 Share August 31, 2011 Must get one...nearly had an accident in JB last weekend...singapore car some more suddenly jam brakes with nobody in front... Link to post Share on other sites More sharing options...
Topspin 2nd Gear August 31, 2011 Share August 31, 2011 (edited) Hi how to change to 16g card? Do I copy black vue File from original 4g card? You need to first format it using the generic formating software provided in the Pitasoft website. Someone else in this thread suggested that you just need to copy over every files and folders from your old card to your new card. All the previous configuration settings will be transferred. I have used this method on mine after my fortnightly re-formatting. No problem. You do NOT need to copy over your previous recorded image files into your new one but copy only the blank RECORDING folder. If you like, you can also skip copying over the Application files to save space. The other alternative is to do a full firmware upgrade on your new card but this method takes longer to complete. For some unknown reasons my SD card sometimes gives off a verbal warning "check your SD card". Unplugging and plugging the power supply solves the problem temporary. I make sure I then reformat the card at my next opportunity. Edited August 31, 2011 by Topspin Link to post Share on other sites More sharing options...
Topspin 2nd Gear August 31, 2011 Share August 31, 2011 Hi Bros, is the indicator light on the BV very bright? Does it cause any distractions when driving at night? Thanks. Barely noticeable at night, anyway, the device is most likely installed behind your rear view mirror at the centre of your windshield. You won't be able to see the device while you are driving. In fact you need to ask your passenger to inform you if the light is blinking normally during recording. But for me, so long I hear the message " starting normal recording" before I move off, I don't need to check on the lights anymore. Link to post Share on other sites More sharing options...
Picanto 3rd Gear August 31, 2011 Author Share August 31, 2011 Must get one...nearly had an accident in JB last weekend...singapore car some more suddenly jam brakes with nobody in front... many drivers know about in car camera, but they always wait till accident happen, then regret not installing one. Link to post Share on other sites More sharing options...
Junxian Clutched August 31, 2011 Share August 31, 2011 erm can the power cable from cig outlet to the BV unit neatly hidden ? Link to post Share on other sites More sharing options...
Tazzi80 3rd Gear August 31, 2011 Share August 31, 2011 erm can the power cable from cig outlet to the BV unit neatly hidden ? They will tap to your 12V directly without using the cig outlet. The only wire most prob you will see is the part which pops out from the front inner roof to your camera. Link to post Share on other sites More sharing options...
Civic_newb Neutral Newbie August 31, 2011 Share August 31, 2011 Hi Bros, is the indicator light on the BV very bright? Does it cause any distractions when driving at night? Thanks. Black Vue comes with PC software which can configure many things, one of them is to switch on/off the LED indicators. I like the BLUE ring LED, looks great at night but you can it switch off. Many photos can be found on their website http://www.blackvue.com.sg BTW, anybody install it for front and back of your car? Link to post Share on other sites More sharing options...
Bslong Neutral Newbie September 1, 2011 Share September 1, 2011 Is Blackvue selling at Comex? Any group buy recently? Link to post Share on other sites More sharing options...
atlantis Neutral Newbie September 1, 2011 Share September 1, 2011 Is Blackvue selling at Comex? Any group buy recently? It's $199 from this eBay lady .. probably lower than group buy I've seen. Link to post Share on other sites More sharing options...
Picanto 3rd Gear September 1, 2011 Author Share September 1, 2011 erm can the power cable from cig outlet to the BV unit neatly hidden ? if done correctly, its very neat. ↡ Advertisement Link to post Share on other sites More sharing options...
W212 owners, please check-in
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
Marbella DashCam Users
Migrating down under? Come share your experiences
Peugeot Owner please come in..
Mazda Rx8 owners..pls come in
