Shochong Clutched May 22, 2012 Share May 22, 2012 I have this Blackvue 350 for 2 months. These 2 days, the voice command sounds suddenly becomes a bit distorted and staggered. Usually, it will start normal recording after I start driving out, but now, the normally recording only starts when I drive many km out on the roads. Anyone knows what happened? Try formatting the card & see if it helps ↡ Advertisement Link to post Share on other sites More sharing options...
Salmon 1st Gear May 22, 2012 Share May 22, 2012 I have this Blackvue 350 for 2 months. These 2 days, the voice command sounds suddenly becomes a bit distorted and staggered. Usually, it will start normal recording after I start driving out, but now, the normally recording only starts when I drive many km out on the roads. Anyone knows what happened? As for the switching to normal recording mode, try to set your G-force setting to be more sensitive. Link to post Share on other sites More sharing options...
Pizza88 Clutched May 25, 2012 Share May 25, 2012 Thinking of getting Blackvue 350 from Gmarket. Can anyone recommend me which workshop to go for the Blackvue installation? Preferably installation rate at about $30. Thank you. Juz got my Blackvue DR350 from Gmarket and got a little surprise, they pack a Power Magic for me as well which I did not ordered. I think they may have made a mistake.. Link to post Share on other sites More sharing options...
Sphwee 1st Gear May 25, 2012 Share May 25, 2012 Freebies for you. Maybe it's a package deal. Link to post Share on other sites More sharing options...
Elstonng Neutral Newbie May 25, 2012 Share May 25, 2012 who you bought it from? Yup I bought it from the distributor wow gadget ;) Link to post Share on other sites More sharing options...
Elstonng Neutral Newbie May 25, 2012 Share May 25, 2012 Haizzz sad to say, I have updated the firmware to 1.04 and downloaded the program for sd formatting. But still the audio thingy is still the same on and off on and off..... Only thing improved is now I can see car plate numbers slightly clearer when zoom in as compared to previous version. But night video still grainy when vehicle is moving. Any bros here can recommend wat kind of settings should I configure like the brightness... Which level are ur using for night video......daytime is very clear not much problem at all except when vehicle moving. Does setting the brightness to higher level makes the night recording grainy? So far till now still not able to achieve a FuLL HD quality night recording....:( Any advise? Link to post Share on other sites More sharing options...
Adrianli Hypersonic May 25, 2012 Share May 25, 2012 Haizzz sad to say, I have updated the firmware to 1.04 and downloaded the program for sd formatting. But still the audio thingy is still the same on and off on and off..... Only thing improved is now I can see car plate numbers slightly clearer when zoom in as compared to previous version. But night video still grainy when vehicle is moving. Any bros here can recommend wat kind of settings should I configure like the brightness... Which level are ur using for night video......daytime is very clear not much problem at all except when vehicle moving. Does setting the brightness to higher level makes the night recording grainy? So far till now still not able to achieve a FuLL HD quality night recording....:( Any advise? Can provide a screenshot of ur settings??? Link to post Share on other sites More sharing options...
Elstonng Neutral Newbie May 27, 2012 Share May 27, 2012 Ok finally....Reformat the card again and upgrade firmware.... Video quality is much better now at least zoom in can see carplate number liao.... =P But still slightly grainy during night recording when vehicle moving. Bro Adrianli : May i know which brightness level u set to??? Me currently using level 2....still monitoring. My settings are all default never change anything other than brightness. Image settings is set at 30fps. Thank so much :) Link to post Share on other sites More sharing options...
Xfiles 1st Gear May 27, 2012 Share May 27, 2012 Latest External Battery Pack TPOWER for your car dvr & any 12V electronics devices from KOREA! Worrying of voiding the warranty of your new car if u tapped your new car dvr to the fusebox? Look no further! Introducing the TPOWER 10400MAH Super Capacity Battery Pack from Korea! Able to be recharged via your cigar socket while you are driving, and supply power up to 2 nights or more! What is TPOWER? Link to post Share on other sites More sharing options...
Adrianli Hypersonic May 27, 2012 Share May 27, 2012 Ok finally....Reformat the card again and upgrade firmware.... Video quality is much better now at least zoom in can see carplate number liao.... =P But still slightly grainy during night recording when vehicle moving. Bro Adrianli : May i know which brightness level u set to??? Me currently using level 2....still monitoring. My settings are all default never change anything other than brightness. Image settings is set at 30fps. Thank so much :) My brightness setting was on default. Never touched any setting except motion sensor n shock sensor sensitivity and LED off. Link to post Share on other sites More sharing options...
Shochong Clutched June 5, 2012 Share June 5, 2012 (edited) --- Edited June 6, 2012 by Shochong Link to post Share on other sites More sharing options...
Shochong Clutched June 6, 2012 Share June 6, 2012 (edited) Helping sell off 5 units of Brand new RMA DR400 6 months overseas warranty: $250. Interested sms me at 84827998. Edited June 6, 2012 by Shochong Link to post Share on other sites More sharing options...
Picanto 3rd Gear June 6, 2012 Author Share June 6, 2012 overheating issues problem? Link to post Share on other sites More sharing options...
Shochong Clutched June 6, 2012 Share June 6, 2012 (edited) overheating issues problem? ya RMA the old PCB board from overheating Edited June 6, 2012 by Shochong Link to post Share on other sites More sharing options...
Asure7 1st Gear June 7, 2012 Share June 7, 2012 Having problem with Transcend Class 10 MicroSD card i bought, to be used for my blackvue. Would appreciate if anyone can help. The problem is as follows: 1. After unsealing SDcard #1, directly proceed to format using SDcard Formatter. (Full - Overwrite). 2. Within 3 seconds, it returned an error saying "Could not format the Memory Card. Please remove the Memory Card and try again". 3. Tried using "Quick Format" but also failed. 4. Try to format just using Windows 7, but also failed "Card cannot be formatted". 5. As a result, SDcard #1 is now rendered useless as the computer cannot access the card. 6. Unsealed SDCard #2. 7. Decided not to format first, and just try to copy files into the card and see if it is ok. 8. Tried to copy a 4GB video file into the SDCard, but get error saying the file is too big for the SDcard. 9. Thinking it may be a limitation with FAT32 file system, I tried copying a 700MB file instead. 10. While copying 1/2 way, error occured and the copy failed. 11. Try to use SDcard Formatter again. 12. Failed in the same way like SDCard #1. Help me please! :( Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 7, 2012 Share June 7, 2012 Having problem with Transcend Class 10 MicroSD card i bought, to be used for my blackvue. Would appreciate if anyone can help. The problem is as follows: 1. After unsealing SDcard #1, directly proceed to format using SDcard Formatter. (Full - Overwrite). 2. Within 3 seconds, it returned an error saying "Could not format the Memory Card. Please remove the Memory Card and try again". 3. Tried using "Quick Format" but also failed. 4. Try to format just using Windows 7, but also failed "Card cannot be formatted". 5. As a result, SDcard #1 is now rendered useless as the computer cannot access the card. 6. Unsealed SDCard #2. 7. Decided not to format first, and just try to copy files into the card and see if it is ok. 8. Tried to copy a 4GB video file into the SDCard, but get error saying the file is too big for the SDcard. 9. Thinking it may be a limitation with FAT32 file system, I tried copying a 700MB file instead. 10. While copying 1/2 way, error occured and the copy failed. 11. Try to use SDcard Formatter again. 12. Failed in the same way like SDCard #1. Help me please! :( Check ur card reader!!! My older card reader also like that. New card reader smooth smooth. Link to post Share on other sites More sharing options...
Asure7 1st Gear June 7, 2012 Share June 7, 2012 Check ur card reader!!! My older card reader also like that. New card reader smooth smooth. I tried 1 external card reader (came with the blackvue) on a PC. Then try another internal card reader (built-in with laptop)... oso same thing :( Haiz... lemme find another PC to try.... Link to post Share on other sites More sharing options...
Shochong Clutched June 7, 2012 Share June 7, 2012 (edited) I tried 1 external card reader (came with the blackvue) on a PC. Then try another internal card reader (built-in with laptop)... oso same thing :( Haiz... lemme find another PC to try.... Mostly is your adapter that is defective. Brand new card rarely have manufacturer defects especially when 2 is brand new sealed.. Edited June 7, 2012 by Shochong ↡ Advertisement Link to post Share on other sites More sharing options...
W212 owners, please check-in
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
Marbella DashCam Users
Migrating down under? Come share your experiences
Peugeot Owner please come in..
Mazda Rx8 owners..pls come in
