  • Search this thread
  • Reply to this topic
26 replies to this topic | 0 praises
#1
Posted 30 June 2011 - 11:46 AM
Xrbeast
  • THREAD STARTER
  • Xrbeast
    1st Gear
    Author Image
    50
Hi all Alfisti,
Just to share. If you guys have a loose steering feel, ie. the wheel seems to wander on uneven road and you hear knocks when roads are uneven, you may have a worn tie rod.
To confirm this, raise your car, with both hands at 3 and 9 oclock position, rock the front wheel (left or right). if you there is freeplay, chances are your tie rods are worn. To double confirm, remove the rubber boot of the inner tie rod to see the inside when you move the wheel laterally. (inner tie rods fails more often than outer one)
The problem with alfa is that they claim that they do not sell the tie rods separately and you have to get a whole steering rack to replace it. so you can either buy from ebay (which i bought and replaced before, but they do not last, it was worn in less than a year (it could be due to some potholes on the road that i encountered that cause the premature failure). Or, get a used rack from scrapyard (like propel) to salvage the tie rods, which i also did on the recently tie rod change.
Please do not spent thousands of dollars on a new steering rack when you can fix this problem at a much lower cost.
Rdgs
u only exist in what u do
#2
Posted 06 August 2011 - 11:48 PM
Gorjiam
  • Gorjiam
    5th Gear
    Author Image
    1,129
Sorry, you bought the entire tie rod or just the tie rod ends?
I think I am facing the same issue as you.
Shameful owner of a disgusting Japanese Econ Box.
#3
Posted 13 September 2011 - 10:30 AM
Mks14
  • Premium member
    Mks14
    2nd Gear
    Author Image
    103
Same here. Are there other ways to find out if the tie rods are the cause? Will a worn CV boot cause the same problem?
#4
Posted 13 September 2011 - 10:45 AM
Torquey
  • Torquey
    1st Gear
    Author Image
    94
when i go over a hump at moderate speed i can feel the wheels shuddering upon descending.
would this be caused by worn out tie rods, ball joints or something else?
#5
Posted 18 November 2011 - 11:20 PM
GTblue
  • GTblue
    Author Image
    7
I got the same problem and there is a "clock clock" sound when going over humps n uneven road and it feel like the suspension is very crashy so I changed my upper wishbones n shocks n rubber mount but the problem still exist ... I should try to find out more about the tie rods
#6
Posted 18 November 2011 - 11:51 PM
Vertiga
  • Vertiga
    2nd Gear
    Author Image
    144
Try taking out the anti roll bar rubber bush and check if it is already harden. If harden, change it.
Another is to check the anti roll bar link bar. Take it out and check if the joint is worn.
#7
Posted 19 November 2011 - 12:11 AM
Happily1986
  • Premium member
    Happily1986
    NOS-ed
    Author Image
    14,314
your shocks are about to give up.
1923 - 2015. You will be missed.
#8
Posted 11 May 2013 - 10:30 AM
Count_duku
  • Count_duku
    5th Gear
    Author Image
    1,060
I visited Alfa parts websites like alfaworkshop, and they do sell the inner tie rods independently from the steering rack. I just ordered and hopefully they fit the steering rack as with the integrated ones. From experience, changing the tie rod ends (with the right angle ball joint) alone do not help much. Dunno why the workshops like to change this part and waste time and money. ok maybe it's the cheaper option and worth a try.
"You never really own a Rolex, you merely look after it for the pawnshop"
#9
Posted 11 May 2013 - 11:42 AM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,008
Maybe yr friendly garage don't have a proper ball joint extractor. Maybe they are more handy in using chisel and hammer
Edited by Yeobh, 11 May 2013 - 11:43 AM.
Visit My Facebook for the latest automotive breaking news & innovative specialty tools.
#10
Posted 12 May 2013 - 09:59 AM
Count_duku
  • Count_duku
    5th Gear
    Author Image
    1,060
Dunno whether they have the tools, hopefully they don't ruin the tie rod ends while removing the inner one ..
Yeah, I saw some youtube tie rod changing guides and some workshops just use a hammer to loosen the tie rod end. And there is a horseshoe wrench to remove the inner tie rod from the steering rack, hope they have that too .. sweatdrop.gif
#11
Posted 12 May 2013 - 10:10 AM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,008
This is commonly used in our many HDEEBEE garages
#12
Posted 16 May 2013 - 12:56 PM
Count_duku
  • Count_duku
    5th Gear
    Author Image
    1,060
Just completed my inner tie-rod change, the result is superb.
1. Solved my issue of alignment going off.
2. Eliminated tram-lining and steering jerking left and right while going bumpy roads.
3. Steering feels nice and tight.
4. Also reduced the steering noise.
Edited by Count_duku, 16 May 2013 - 12:56 PM.
#13
Posted 25 May 2013 - 11:43 AM
Count_duku
  • Count_duku
    5th Gear
    Author Image
    1,060
Update - looks like I had to change my tie rod ends as well, another $100. The ones replaced last year crapped out only after 20,000km damn.
#14
Posted 31 July 2013 - 09:57 PM
Best20
  • Best20
    Author Image
    21
hi guys...
I also having the same problem. But i changed my tie rods, lower control arm and damper.
I still have problem turning right, is there anywhere i can get the workshop to check on the under carriage?
#15
Posted 19 August 2013 - 08:52 AM
Thsjeffrey
  • Thsjeffrey
    Author Image
    1
Hi, if my steering wheel is looser than before, but not say very serious, I mean I just feel that it is "lighter" than before when i make a turn, should I worry about it ? To what extent does it warrant a check at workshop ?
Thanks much for any advice.
#16
Posted 24 August 2013 - 03:12 PM
Count_duku
  • Count_duku
    5th Gear
    Author Image
    1,060
hi guys...
I also having the sprobl m. But i changed my tie rods, lower control arm and damper.
Actually there are many parts that affects the steering, not only the tie rods which comes in 2 parts- inner and outer. I have also changed upper and lower control arms, the upper arms changed twice as parts were faulty. Ok after that, the car needs to get a good alignment, for my Alfa it was zero/zero front toe and rears +11/+11. I did the alignment many times, still pull left and alignment shop noticed not enough +ve castor / -ve camber on the front left, about half degree off. The were some bolts under the subframe, where the lower arm is attached loosened that and push out a bit. This knocked the toe out but fixed tbe castor/camber mismatch, aligned the front toe to zero again and presto!
Steering is much, much better but .. still feel a little torque steer, steering pull only when accelerator is applied and steering wheel is at certain angles. When free gear no pull. I suspect this is due to the drive shafts and CV joints, will work on these next year..
#17
Posted 11 February 2014 - 09:21 PM
Count_duku
  • Count_duku
    5th Gear
    Author Image
    1,060
After "recon" my cv joint twice the past year, finally decided to swap the entire drive shaft (drivers side). I think that's the last fix to the steering issues.
#18
Posted 31 October 2014 - 08:44 AM
Count_duku
  • Count_duku
    5th Gear
    Author Image
    1,060
Update on alignment pulls - some shops have a side slip tester that tests the alignment when car is moving forward. The problem is normal alignment rig checks the toe angles when the car is stationary. When the car is accelerating, the front wheels pull and worn suspension can cause the front toe to change. A good mechanic can do minor adjustments to the front toe and check measurement on the side slip tester to negate the pull. Alternatively the solution is to replace all the worn parts.
#19
Posted 31 October 2014 - 09:24 AM
Jaspok
  • Premium member
    Jaspok
    1st Gear
    Author Image
    78
Not sure if this is worn tie rods related but I have a knocking sound when doing U turn full lock to the right despite changing front lower arms and new shocks less than 5k ago.
"On the 8th day GOD created a BMW... On the 9th day he traded it in for an Alfa Romeo :)"
#20
Posted 31 October 2014 - 09:03 PM
Ftco
  • Premium member
    Ftco
    5th Gear
    Author Image
    1,230
May be drive shaft?
Back to Alfa Romeo Club  ·  Car Brands Top Reply to this topic
1 9 6 9 Sung Beng Auto Pte Ltd
1 9 6 9 Sung Beng Auto Pte Ltd  |  Rating   Submit Review
Reviewed by Grsvch  |  Neutral Newbie
Got a good quote on the spot and received a whatsapp (with detailed breakdown quote) confirmation after fixing the repair appointment. Within 2 days was able to get my car instead of the 3 days given by another major car workshop that quoted me a higher price. Only blip is they prefer NETS or cash. » Read More
H & H Auto Rebuilt Pte Ltd
H & H Auto Rebuilt Pte Ltd  |  Rating   Submit Review
Reviewed by Brooke_wxl  |  Neutral Newbie
Just got my B170Merz back from H&H last week. It is a pleasure to go to a workshop when you feel there's someone looking out for your vehicle & Best interest. I had no issue so far, & Plan to continue going to them for all my car needs.
Related Motor Directory search on sgCarMart.com : Repair & Servicing
Quick Reply
