Jaspok 1st Gear October 31, 2014 Share October 31, 2014 Not sure if this is worn tie rods related but I have a knocking sound when doing U turn full lock to the right despite changing front lower arms and new shocks less than 5k ago. ↡ Advertisement Link to post Share on other sites More sharing options...
Ftco 2nd Gear October 31, 2014 Share October 31, 2014 Not sure if this is worn tie rods related but I have a knocking sound when doing U turn full lock to the right despite changing front lower arms and new shocks less than 5k ago. May be drive shaft? Link to post Share on other sites More sharing options...
Count_duku 4th Gear November 1, 2014 Share November 1, 2014 (edited) Not sure if this is worn tie rods related but I have a knocking sound when doing U turn full lock to the right despite changing front lower arms and new shocks less than 5k ago. My clunk was due to inner tie rod - when doing U turn sure clunk. Anyways the tie rods are much cheaper than the CV shaft. A few hundreds vs $1500 for CV shaft. Inner tie rod connects the steering rack to the outer rod, which connects to the lower arm, if I'm not mistaken been a while. Edited November 1, 2014 by Count_duku Link to post Share on other sites More sharing options...
Count_duku 4th Gear November 1, 2014 Share November 1, 2014 Forgot to mention mine was a single clunk , if repeated knocking then something else .. Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 1, 2014 Share November 1, 2014 Not sure if this is worn tie rods related but I have a knocking sound when doing U turn full lock to the right despite changing front lower arms and new shocks less than 5k ago. Knocking sound from L wheel while doing U turn? Most constant velocity (CV) joint on the L side will worn off first. Link to post Share on other sites More sharing options...
Count_duku 4th Gear March 11, 2015 Share March 11, 2015 Update on alignment pulls - some shops have a side slip tester that tests the alignment when car is moving forward. The problem is normal alignment rig checks the toe angles when the car is stationary. When the car is accelerating, the front wheels pull and worn suspension can cause the front toe to change. A good mechanic can do minor adjustments to the front toe and check measurement on the side slip tester to negate the pull. Alternatively the solution is to replace all the worn parts. Finally replaced the worn part - worn lower arm bushings with Powerflex. Eliminated the pull to one side. Link to post Share on other sites More sharing options...
andy7 Neutral Newbie November 24, 2016 Share November 24, 2016 is this very common issue? ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
ItzJuzCarbon can customise any of your steering wheels, car parts, interior trims, side panels and accessories with Carbon Fiber!
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
Steering column
Steering column
the newest Mercedes model slk plaid
Reinventing the Wheel - Tesla Edition
Steering wheel off centered from seat.
