Garlic 1st Gear July 10, 2011 Share July 10, 2011 (edited) Hello everyone, I recently sent vehicle back to agent to rectify a leaking issue. Water pump and several clips were replaced. 2 weeks ln, I notice coolant level is dropping rapidly again and it now smells like paint thinner, there is also an oily film on the surface. What can cause sweet smelling coolant to turn into an oily liquids which smells like paint thinner? Some gasket leak? Thanks. Edited July 10, 2011 by Garlic ↡ Advertisement Link to post Share on other sites More sharing options...
Mona-vie 1st Gear July 10, 2011 Share July 10, 2011 Hello everyone, I recently sent vehicle back to agent to rectify a leaking issue. Water pump and several clips were replaced. 2 weeks ln, I notice coolant level is dropping rapidly again and it now smells like paint thinner, there is also an oily film on the surface. What can cause sweet smelling coolant to turn into an oily liquids which smells like paint thinner? Some gasket leak? Thanks. Oil in the water?? Not good, sounds like gasket problem. Link to post Share on other sites More sharing options...
Jamesc Hypersonic July 10, 2011 Share July 10, 2011 This is really serious. Coolant is leaking into your engine oil. Get it seen to as soon as possible. Link to post Share on other sites More sharing options...
5936 1st Gear July 10, 2011 Share July 10, 2011 I think it's internal leak. But not sure if it's from where. Could probably be unburn fuel. You can also self check if there is a internal leak, by checking colour of EO. Milky means serious mix of EO and water. With engine warm shut off, draw EO dipstick, let a few drop drip onto exhaust manifold, if you hear sizzling = coolant breeched through. Get a mechanic to perform pressure test on the cooling system, if cant determine the cause. Link to post Share on other sites More sharing options...
Watwheels Supersonic July 10, 2011 Share July 10, 2011 (edited) Confirm it's the head gasket. Get it replaced. Your coolant is leaking into the combustion chamber. You should be seeing some white smoke coming out from your exhaust while the engine is running. If the petrol and engine oil can travel all the way to your coolant reservoir that means the leak is quite bad. It's recommended you overhaul the engine and have the internal combustion chamber thoroughly cleaned. Edited July 10, 2011 by Watwheels Link to post Share on other sites More sharing options...
Garlic 1st Gear July 10, 2011 Author Share July 10, 2011 Thanks for the feedbacks, will be making an appointment to get it rectified tomorrow. The engine is also making a loud ticking noise. Here is a picture of the oil film, coolant is pink VW G12. ↡ Advertisement Link to post Share on other sites More sharing options...
House painting
House painting
Reputable like Lye Design in Amk Auto-point
