Str2 Neutral Newbie July 19, 2011 Share July 19, 2011 Hi All, My auto trans 2005 Honda car (not CVT) recently developing a obvious whining engine brake sound. Is this a auto box problem? (I hv always change autobox on time or earlier using Honda Z1 trsnmission fluid). Any bros has experience this in yr ride ? ....... and what the cause and remedy? ↡ Advertisement Link to post Share on other sites More sharing options...
Stanchiam 1st Gear July 19, 2011 Share July 19, 2011 belt sound? Link to post Share on other sites More sharing options...
Str2 Neutral Newbie July 19, 2011 Author Share July 19, 2011 Don't think so. I changed air-con belt and water pump belt already. Sound only appears during slowing down (engine braking as mentioned) and pedal not depress. Once step on pedal, whining sound kind of disappear. Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear July 19, 2011 Share July 19, 2011 Don't think so. I changed air-con belt and water pump belt already. Sound only appears during slowing down (engine braking as mentioned) and pedal not depress. Once step on pedal, whining sound kind of disappear. I believe the breather valve/tank is leaking or some hoses leading to this area is leaking also...the hose goes back to the engine..if my guess is correct, the cel will come on soon. Link to post Share on other sites More sharing options...
Str2 Neutral Newbie July 25, 2011 Author Share July 25, 2011 I checked it is not breather hose sound....it coming from the auto trans box. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged August 5, 2011 Share August 5, 2011 was it the hollow-like sound? i've heard it in my ride too, also gone after stepping on gas. but i dunno where sound came from. Link to post Share on other sites More sharing options...
JayRideFD3 Neutral Newbie September 5, 2017 Share September 5, 2017 Any update what's found regarding the loud engine sound while braking?? ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
