Yeobh 4th Gear July 27, 2011 Share July 27, 2011 (edited) I have not come across a 8mm spark plug with hex 14mm yet. After checking with my mech friends I was told that they are used in Citroen vehicles , BMW mini, Renault etc - mainly European vehicles. Do you have exprience trying to remove such small size plugs, pl share with us the tools you need to access and remove the spark plugs. Edited July 27, 2011 by Yeobh ↡ Advertisement Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 27, 2011 Share July 27, 2011 should be able to get those tube wrench (various sizes) from neighbourhood hardware shops, costs anything from $2.80 to $6. If tube is too short, can buy another one of bigger size and stack on top of it. Use a screwdriver and insert into a hole on top to help you turn. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 27, 2011 Author Share July 27, 2011 It's ok to use those plumber nut opener with pre 80's Japanese cars but with modern cars especially those from French PSA group ( as I was told) it's tedious and time consuming unless you have the right tools. Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 27, 2011 Share July 27, 2011 Most of the spark plugs are seated deep into the engine block except some old small cap single cylinder motorcycle engine. That's why you need tube wrench or dedicated spark plug wrench and not spanner or plumber nut opener. Positioning of the plugs could also pose a problem even if you have the right tools (boxer engines layout). Link to post Share on other sites More sharing options...
Gnahp Supercharged July 27, 2011 Share July 27, 2011 The tool kits that came with the car should have the spark plug socket, no? Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 27, 2011 Author Share July 27, 2011 (edited) The tube wrench is a plumber's tool. To get into deep seated spark plug you need ex long thin walled socket with flexible joint. Edited July 27, 2011 by Yeobh Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 27, 2011 Share July 27, 2011 The tool kits that came with the car should have the spark plug socket, no? Don't think they give anymore. If lucky, only spare tyre + jack. Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 27, 2011 Share July 27, 2011 The tube wrench is a plumber's tool. To get into deep seated spark plug you need ex long thin walled socket with flexible joint. Most spark plug wrench with flexible joint are standard fixed length (quite short). You can lengthen it by welding an extended rod to it. Link to post Share on other sites More sharing options...
Gnahp Supercharged July 27, 2011 Share July 27, 2011 I think not many car owners replace their spark plugs on their own nowadays. I like to play LEGO, I assembled mine from loose components. Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 27, 2011 Share July 27, 2011 I still do on my bike and on car. More difficult for a 4-cylinder bike than car. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 27, 2011 Author Share July 27, 2011 During the 70's few of my older friends were involved in running weekend classes on general car maintenance for DIYers. At that time DIYers were car owners who love to do schedule maintenance on their own but some preferred to do as a group. Changing engine oil, doing up the brakes, replacing ignition point and plugs etc etc . As labour cost goes up, those who are handy and have some auto knowledge may again may want to do the minor service/maintenance themselves if time and place permits . Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear March 3, 2012 Share March 3, 2012 I believe mcfers may one day share such place for DIY ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Plug-and-play vaccine
Spark Car Care
Spark Car Care
Aftermarket vs. OEM Spark Plug Wires
Replace spark plugs
Replace spark plugs
Denso Iridium Spark Plug (IK20)
Replacement seal for bathroom sink plug
Mazda 5 2008 Spark Plug
