  • Search this thread
  • Reply to this topic
1182 replies to this topic | 5 praises
#1
Posted 26 August 2011 - 10:08 PM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Imported from Germany and endorsed by premium car brands like Lamborghini (Sydney), Permanon Platinum is a high quality surface protection engineered to the nano level for ultimate shine and protection. Not only will the high gloss shine impress you, but the nano-coating provides protection against the harsh elements superior to what expensive clay and wax solutions can offer. Cleaning is also made easier for Permanon coated cars by up to 80%.
Look good and feel good not enough for you? The water repellent nature of the nano-coat is an additional safety feature as water glides off your all your mirrors upon application (applicable on all mirrors and glass surfaces!), giving you clearer vision on those rainy days.
Just dilute and spray on your designated areas, that's all you need. The electrostatic bonding nature means 1 spray on application lasts 6 months while the applicability of the product on both internal and exterior surfaces translates into massive cost savings for you (egs, Spray on your tyre rims to maintain shine while preventing accumulation of brake dust).
Seeing is Believing - Watch the videos now!
Click the following links to download our brochures
(1) Permanon Platinum
Make your purchase now http://www.beacon-enterprise.com
For enquiries,
(1) You can call us 93472184 (Jonathan),97661548 (Jerry)
(2) Email us at .com'>enquiry.com
Edited by pChou, 14 May 2014 - 04:43 PM.
Contact us directly for orders: 97661548 (Jerry), 98777768 (Titus)
Live chat support available at our website!
Beacon Enterprise Website Facebook Page
#2
Posted 26 August 2011 - 10:09 PM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Imported from Germany and endorsed by premium car brands like Lamborghini (Sydney), Permanon Car Supershine is a high quality surface protection engineered to the nano level for ultimate shine and protection. Not only will the high gloss shine impress you, but the nano-coating provides protection against the harsh elements superior to what expensive clay and wax solutions can offer. Cleaning is also made easier for Permanon coated cars by up to 80%.
Permanon products have been specially designed and engineered so that no special procedure or extra sanding will ever be required to remove Permanon products for repainting! The normal, standard surface preparation procedure that must be carried out to re-paint a yacht properly is more than enough to completely remove all Permanon coating elements! This is another very important unique benefit of Permanon products!
Permanon products are mono-molecular and not tri-molecular like other products, Permanon products only seal up to 90%, blocking water and moisture whilst allowing the surface to breathe. This is very important for leather and fresh paint, as ‘out-gassing’ the releasing of solvents from freshly applied paint is not prevented.
Permanon Supershine is very easily applied by simply wiping or spraying Supershine on any pre-cleaned non-porous surface, then hand dry or rinse. Since Supershine connects to surfaces statically no waxing, compounding or buffing is needed, just hand drying (reachable surfaces) or rinsing (hard to reach surfaces) is required for application.
(1)
(2)
(3)
Just $30 for 1 year's worth of shine, protection and safety .
(1) Permanon Car Supershine
Lazy to diy? Want a professional groomer to prep your surface and apply permanon for you while cleaning interior as well? We provide Permanon application services too!
Review on Permanon
How does it work?
To me, this is the most fascinating part about it. This technology actually came about as a result of a laboratory mishap which yielded a result that would ultimately become Permanon. Most surfaces in nature have a negative charge to them. These surfaces include the painted surface on your car whether it be metal, plastic, aluminum or carbon fibre. Glass and plastic are also negatively charged. In fact, if you apply a wax, sealant or nano glass coating to the surface such as Opti Coat or CQuartz, the surface retains its negative charge. Permanon contains silicon which has in nature a positive charge. You know what happens if you hold 2 magnets to each other with a negative side on one and a positive side on another: they attach themselves to each other very quickly. This is exactly what happens when you spray Permanon onto the surface of a non porous material. The protection in Permanon attaches itself to the surface. Not only that, but the true chemical beauty of it is that the surface has now changed polarity and has a positive charge. The significance of that is that dust, dirt and water are actually repelled by the surface of the material. Just like trying to bring 2 magnets together of the same polarity....ain't gonna happen!!
What can it be applied to?
As previously mentioned, non porous materials. What it will not work on is a much shorter list than what it will work on. Do not apply to cloth, unsealed leather, and rubber. Metal, plastic and glass are primary examples of what can be treated with Permanon. The metal can even be bare. I treated raw aluminum with Permanon Platinum and it sealed it and protected it against oxidization and finger prints. You can pretty much apply Permanon to the entire outside of your vehicle. Paint, glass and trim. It will not hurt the tires or rubber if it is sprayed onto the surface, it just won't yield any protection for that surface.
How can it be applied?
Permanon, either Auto or Platinum, comes highly concentrated. In fact, you can use either a 5 or max 10% solution of Permanon to 90 to 95% of distilled water. Application can be via a pump sprayer of the garden type variety or even through a pressurized paint gun. You do not need to soak the surface. Just mist it on until you see the water on the surface beading and then you know it has bonded. The surface does not need to be previously wiped down with an alcohol wipe or equivalent. Make sure the surface is clean and dry...that's it!
How do I remove it?
OK, if the technology of this product didn't set it apart already, wait to you hear this: you can actually apply and remove this product without touching your surface! Once the Permanon has been applied, it can be immediately removed as the bonding process is instantaneous. All you are doing at this point is removing the distilled water that was used as a carrier for the Permanon. So, to remove that water without touching your paint, use a leaf blower or auto blower such as the Master Blaster. You don't want to leave the water on the paint, even if it is distilled, since you may get water spotting with it. Voila! You have just protected your surface without actually touching it. That method is my personal suggestion. Permanon suggests drying the surface with a micro fiber drying towel. Fair enough, but we all know that any time you touch the surface, you risk instilling marring of the paint. My method prevents that.
What kind of durability can I expect?
Permanon is not removed by normal cleaning products. You can remove it with an alkaline PH of 12.5 or greater which is extremely high on the scale. Most acids will not remove it although hydrofluoric acid can as well. These 2 examples are not something to which you would ever subject a painted surface! Otherwise, it will stay active for approx 6 months on a daily driver. A "Garage Queen" could theoretically stay protected for years.
What about maintenance?
Permanon will not adhere to itself. (Remember the magnets of the same polarity?) However, if there is an area where the Permanon has started to fade from, simply go over that area with new Permanon and it will bond to the low spots or the spots where it is no longer active. If in doubt, just go around the whole car again.
Permanon's Strengths:
I've already mentioned the repelling of dirt, dust and water. One of the key attributes to Permanon as well is its ability to withstand heat. Where this comes into play specifically with autos is with wheels and the resulting brake dust. When the brake dust settles on the wheels, it is at 265°F. This product can withstand heat up to 572°F!! Therefore, the brake dust cannot burn itself onto the surface of the Permanon-treated wheel like it could with a wax or sealant treated surface. Cleaning of brake dust just got easy.
Quick introduction to Permanon
Protect your car Engine Bay using Permanon, same spray on application! (proceed with caution, demonstration performed under guidance of car detailing experts)
Apply Permanon using a simple Garden style pressure pump, no fuss easy application!
Permanon Car Supershine works on Rims too! Resists up to 300 degrees while brake dust burns at around 270.
All the technical goodness of how Permanon fills up the nano level pits and crevices in a short 1 minute video!
Video of Lizard Sliding Off My Permanon-ed Car - WARNING EPIC VIDEO ALERT
Would you trust Permanon on your babes if Lamborghini cars are coated with Permanon too? ;)
We're proud to have the sizzling hot Cheryl Tay review Permanon for us and as well as our newly introduced triple layer Permanon grooming with gloss enhancer!
Props to our very own local female motoring journalist and blogger extraordinaire for taking up the Permanon experience =) Check out her blog for more motoring goodies, but of course, don't forget to size up her review of Permanon first! To read the full review, visit Cheryl Tay website now!
I left my car in the hands of the Beacon guys at the covered car park and went to have a drink. After the session, I was pleasantly greeted with a ‘moving mirror’ made out of my car! Note how the colours are a lot more vibrant and brighter after the session…
I was genuinely impressed with the clear reflections of the surroundings on my car:
Grooming using Permanon is really convenient, especially for those who are very busy and have no time to groom the car themselves. If you really don’t have time to even do the DIY follow-up (that takes approximately 30-45 minutes on average) over the next 3 to 6 months before the next session, you can just rinse your car with water quickly.
Since the initial grooming session, I have not done any DIY sessions or washed my car (unless you count rain wash) and my car is doing fine! What about you? When was the last time you groomed your car? Or have you even groomed your car before? ;)
For enquiries,
(1) You can call us 97661548 (Jerry), 93472184 (Jonathan) 96670623 (Martin)
(2) Email us at .com">enquiry.com
Edited by Beacon_Enterprise, 07 May 2012 - 04:14 PM.
#3
Posted 26 August 2011 - 10:10 PM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
How does Permanon work? Why does it last so long? All your questions answered in this in-depth review of Permanon technology!
http://www.metalfini...ting-technology
Permanon is a brilliant 21st century surface protection that eliminates the need for buffing or polishing and is conveniently sold as a concentrate so that you buy less water and more protection. Permanon utilizes waterborne nano-engineered particles of Silicium (14Si) that electrostatically bond to the surface being protected. There is no chemical or mechanical action to damage, or alter, the surface you are protecting. Permanon is designed to protect polyurethane topcoats and other solid surfaces such as glass, FRP, stainless steel, chrome, rubber, finished leather, granite, varnish, enamel, and solid surface products. Permanon protection will outlast any wax or oil based renewable surface protection and comes specially formulated for Aircraft, Yachts, Boats, Cars, Trucks, Interiors, Pool & Spas, and Glass
Permanon features the following capabilities:
Dirt cannot bond to treated surfaces
Surfaces are protected against industrial and environmental Pollution
Repels airborne dust
Eliminates the need for harsh and potentially dangerous chemical cleaners
Reduces cleaning costs by 50% or more
Improves clarity of transparent materials and reduces light scattering
Resistant to temperature extremes from 40°C to 300°C
Resistant to ultra violet (UV) exposure, undiluted provides 100% UV protection Anti-fouling properties
Significantly improves the “maintainability” of man-made surfaces
HOW IT WORKS
All materials are porous and contain microscopic peaks and valleys, much like the profile of a mountain range. These irregularities are known as capillary structures. On manufactured surfaces (including paints and coatings) there may be millions of these defects per square inch. Contaminants such as fine dirt, minerals, and pollutants are drawn into the voids where they are extremely hard to remove. Capillary structures also provide microbes and bacteria with an excellent place to grow and multiply.
The silicium particles of Permanon are laminar shaped, which means they overlap each other like the scales of a fish. These platelets are deposited on the capillary wall and closely follow the contour of its surface. These platelets will fill up to 90 percent of the capillary void, resulting in a surface that is smoother and more resistant to soiling. The overlapping of the platelets also reduces the permeability of the treated surface, making it virtually impossible for moisture and other reactive agents to migrate through the protected coating to the metal surface.
I’ve been testing this for about 8 months; when you apply it to a clean surface, that surface virtually takes on properties of hardened glass. It’s easy to clean, protects against UV light. What I like most about it is permeability control. When you spray it on a hard surface, it achieves a contact surface of 160 degrees and it virtually eliminates the transfer of moisture or other chemical compounds through the existing coating to the substrate.
Super water repellant. The filling of the capillary structures with silicium nanoparticles produces a hydrophobic surface. (A hydrophobic surface is one that repels moisture.) In contrast, a hydrophilic surface is one that absorbs moisture. The potential of a surface to absorb or repel moisture is based on many factors, including: temperature, relative humidity, material homogeneity, and static electricity. Surface roughness is also a major factor; the rougher the surface, the higher the spreading rate or attraction for water. The smoother the surface, the more repellant it is to moisture.
Close up photos of water Beading on Permanon-ed Car after heavy rain
Edited by Beacon_Enterprise, 19 March 2012 - 10:56 PM.
#4
Posted 26 August 2011 - 10:12 PM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Permanon Platinum PPS ( Paint Protection System )
Unparalleled surface protection for your ride
Your favourite Permanon Platinum PPS ( Paint Protection System ) can now be installed by our professional Permanon Applicator Specialist who will prep your surface and apply Permanon Platinum at your convenience!
(1) Overview of our Mobile Service
Click here to read the full details!
(2) Permanon Platinum PPS Details & Pricing
Why Choose Permanon Platinum PPS Mobile Service?
(1) We are the only Permanon Applicator Specialist in Singapore to use Permanon Platinum and BrilliantShine 2 in 1 Car Wash Shampoo. As the sole distributor of the Permanon product range, we thoroughly understand our products and will be able to ensure you get the longest mileage from Permanon Platinum!
(2) We are the only Permanon Applicator Specialist in Singapore to apply sealant on Car Surface, Windscreen and Tyre Rims at NO EXTRA COST!
Some charge up to $40 just for mobile windscreen water repellant service alone!
(3) Our customers’ testimonials are our best ambassador.
Check it out at http://www.facebook....acon.Enterprise
(4) As car owners ourselves, we know that it is impractical to engage the services of a groomer every time you want to wash your car. Our philosophy is to take the mystery out of car care and teach you the best and simplest way you can maintain your car’s shine and paintwork protection. This is why we continue to encourage customers to try the DIY kit with meticulous, guided and patient instruction from our groomers after they have groomed you car! Any questions? Fire away! Our Permanon Applicator Specialist will make sure you know how to upkeep your car’s condition before leaving the premises.
Our Operating Hours
- Email : .com">Enquiry.com
- Contact number : +65 93472184 ( Jonathan), +65 97661548 (Jerry)
- Website: www.Beacon-Enterprise.com
- www.facebook.com/Bea con.Enterprise
Edited by Beacon_Enterprise, 25 June 2013 - 08:00 PM.
#5
Posted 26 August 2011 - 10:17 PM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Photos and review contribution from our valued customer, Andy Chan
I used to get professional car polishing gurus to do up my ride. This was until I bought a bottle of permanon from Jerry after hearing about it from some of my friends. I must say I hestitated for 2 weeks before deciding to call upon Jerry because I am extremely skeptical of car grooming product.
I recalled that evening I went to pick up the permanon from Jerry, he took the pain to explain the instructions to me. I would like to thank Jerry for his effort. After about 10 minutes of instruction, I bidded farewell and promised to call him if I do not know how to do it properly. I zoomed back home and started on the permanon immediately. Application was very easy and took me half hour to go through the entire car. The results are astonishing! Water marks are gone and water droplets no longer stick onto the surface of the glass and car. In the past, I only get this kind of result after detailing with thick car wax and only for shortwhile. With permanon, its seems to be permanent even after weeks without washing or re-applying the permanon.
When I wash the car now, it can be done with water and no shampoo. I am also very impressed by how easily bird droppings and dirt got washed off as if permanon has some kind of anti static capability. This is my third dose of permanon and I maybe overdoing it in such a short interval. But one thing for sure, car washing has never been so easy for me! I am not a very charitable person when it comes to singing praises. But, after using permanon, I tell myself that I must write this letter to you give credit where it is due and thank Beacon Enterprise for this remarkable car detailing product.
Why didn't those car polishing gurus thought of permanon before?
Regards
Andy Chan
Visit our facebook to view more reviews!
#6
Posted 27 August 2011 - 10:12 AM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Photos and review contribution from our valued customer, Andrew, VAGS
Last sat i tried the Brilliant shine n permanon,the effect was so gd that after i wash wif brilliant shine n dried the ride,the ride was so shining that make mi wanna skip applying permanon process :p but still i go ahead wif permanon,the water beading was really great and its a gd products tat save mi alot of time although i still took abt 1 hr to complete the washing as i use the products for the engine bay too...
Visit our facebook to view more photos!
#7
Posted 27 August 2011 - 10:13 AM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Photos and Review Contribution from Our Valued Customer, Edwin
Having used Zaino's Z8 and CS, I had a rather high benchmark for permanon. Needless to say, I was not disappointed with the shine after 15 mins of application. However I was only truly impressed on a rainy day. Normally there would be water marks after the rain evaporates and I will be extremely anal in cleaning the car to prevent the marks from being etched in. I was surprised to find little to NO water marks ! Furthermore they provide really good service and answered all my questions numerous times on their live chat. Thumbs up for permanon !
Edwin
To receive the latest updates,reviews and promotions, click to join Beacon Enterprise Facebook page. =)
#8
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Nissan GTR
No equipment, no machinery required :)
Spray on and wipe off. That's all you need for Permanon Surface Protection
Just wipe off with Microfibre cloth
Water beading immediately after application. No baking or curing required
Permanon surface protection is extremely hydrophobic (water repellant)
Visit our facebook to view more GTR photos and reviews!
#9
Posted 27 August 2011 - 10:14 AM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
BMW
Left bonnet with Permanon applied - Water is repelled off the surface
Right bonnet - No permanon, water still stays on the surface resulting in water marks if not removed in time
Spray on and wipe off. As easy as that! No curing or baking required!
Water slides off left bonnet while still remains on the non permanon area
Visit our facebook to view more BMW photos and reviews!
#10
Posted 27 August 2011 - 08:28 PM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Volkswagen
Awesome! High gloss shine after applying Permanon Car Supershine.
Car Surface is protected by Permanon Car Supershine.
#11
Posted 27 August 2011 - 09:53 PM
Psyn
  • Psyn
    Author Image
    5
Photos and review contribution from our valued customer, Clifton Yip, VAGS
Met up with Jonathan last Sun afternoon for self collection and went back home to wash the car. After washing the car with Brilliant Shine, I used the Permanon Car Supershine on the windscreen and windows only as I will be going for my regular groomer this Friday.
As I could not resist and decided to do up the entire car. Pictures speak a thousand words, I have decided to cancel my Friday appointment with my groomer already.
To receive the latest updates,reviews and promotions, click to join Beacon Enterprise Facebook page. =)http://www.facebook....acon.Enterprise!
#12
Posted 27 August 2011 - 09:55 PM
Psyn
  • Psyn
    Author Image
    5
Photos and review contribution from our valued customer, William, KIA
Finally after purchasing for some time, I was free to apply the Permanon Car Supershine. Was a bit skeptical as I have previously tried many grooming services, but the results were always less than satisfactory: Either the results didn't last, wasn't good enough or simply too pricey. So for something that takes only 15-30 mins, I did not have high hopes.
Well, I have to say after trying this is truly revolutionary! Simply spray on and wipe takes away much of the effort that used to be associated with waxing, and results are quite stunning. The surface has now taken on a mirror-like gloss, as the attached pictures clearly shows. Now will monitor how lasting this is , but currently this is the best product I have ever used, bar none!
Regards,
William
#13
Psyn
  • Psyn
    Author Image
    5
SGMercs Permanon Car Supershine Demonstration, 31st July '11 Kallang Leisure Park
#14
Posted 27 August 2011 - 09:56 PM
Psyn
  • Psyn
    Author Image
    5
Photos and review contribution from our valued customer, dashMK5,VAGS
Used to be using other grooming products. uses wax,polish,sealant but doesn't last more than a week especially after few pours of rain.
Was reading the vagsg forum one night and stumbled upon this thread. went to Stamford tyre and grabbed hold of the Brilliant shine and permanon package and result was immediate.
even SO said car looks like more shiny and more mirrored look.
Now is the second week and I already did 2 coatings. Result is unbelievable and it takes only 40mins to apply the two products.
Thumbs upp!
#15
Posted 27 August 2011 - 09:57 PM
Psyn
  • Psyn
    Author Image
    5
Demo for Honda Civic FD Club on 24th June 2011 Kallang Leisure Park
#16
Posted 27 August 2011 - 09:58 PM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Photos and Review Contribution from Our Valued Customer, Wilson Tan from VAGS
Bought the Supershine couple of weeks back but finally managed to do it last night. The toughest work was lugging a pail of water from house to car park...
Couldn't really see the result last night. This morning the sight made all the hard work well worth it.
The BrilliantShine and Permanon is a great combo.
Thanks!
Regards,
Wilson Tan
#17
Posted 27 August 2011 - 09:59 PM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Photos and review contribution from our valued customer, Andrew, Kia
Hi Everyone,
Would like to share my experience from using brilliantshine and permanon for the past 3 months. Seriously speaking washing my car has been a breeze after being recommended to use these 2 fabulous products.
Firstly, when using brilliantshine for washing my car, the paint coating will have a shiny mirror like look and touching it up with permanon protects my car paint from the sun. As i park in the open air, this is something i am rather particular with.
Secondly, My sports rim are always shiny and oil free when using the both products. Also my fear of parking outdoors is bird s--t stains which is an irritant to car users like us. After using brilliantshine, the stain comes off easily especially when the stain has been there for along time.
Thirdly, Juddering sound effects no longer bothers me after using them.
That is why i would like to express my thanks to beacon enterprise for providing me with a cost saving car wash and protective solution for my car.
Keep up the good work and hope to hear my promotions from you guys.
Cheers.
Best Regards
Andrew
#18
Posted 27 August 2011 - 10:02 PM
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Review from across the causway by Zer0CooL!
Can see the reflection?? Lol
Good product u have there bro..easy to use, immediate effect, less time, make every single penny worth! thanks bro
#19
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Review from across the causway by NavinRobert!
The product really rocks ...!! The first I saw my car shiny was on delivery day at the showroom now it looks like back from showroom again.
#20
Beacon_Enterprise
  • THREAD STARTER
  • Premium member
    Beacon_Enterprise
    Sponsor
    Author Image
    754
Photos and review contribution from our valued customer, Alex, Fiat
I only have one sentence "I simply love the SHINE!!!"
Edited by Beacon_Enterprise, 13 December 2011 - 04:23 PM.
Back to Products & Services  ·  Sponsors Top Reply to this topic
Quick Reply
Tags: aircraft, grade, permanon and 4 more...
1 user(s) are reading this topic
    Google (1)
