KP24 1st Gear May 1, 2017 Share May 1, 2017 Hello guys, sorry to dig up this old thread. Was contemplating between the Mini One 5-Door and Merc A180 after visiting both show rooms last weekend. Been able to dig up quite a bit of resource for Merc A180 but not for Mini. I would be using the car as my primary mode of transportation, so I would be driving quite a bit. Is anyone able to share with me their thoughts on the reliability of a Mini One and also the maintenance involved in a Mini? Thanks! Hi, 1.How do u find both car after the test drive 2.Also very much depend on your lifestyle and is mini your 2nd car 3.how big is your family etc ↡ Advertisement Link to post Share on other sites More sharing options...
KP24 1st Gear May 1, 2017 Share May 1, 2017 Hi, This might have been asked many time I Guess. Planning to get a second hand Mini Cooper S. Just wondering many mentioned of high maintainence. What exactly is that? Does breakdown easily? Monthly expenses? Or rather is just normal servicing every 10k? Sorry for the noob. i just bought a 9 years old MCS, nothing done yet so cant comment much but going to workshop soon as something is wrong as everyday i need to top up 500ml of water which im sure it not normal. Maintenance will be more ex if u are comparing with Japanese car as parts are more costly and very naturally the workmanship cost will be higher. Better to bring a technicians along as he should able to spot some tell tale sign of leaking etc, most important does the mini fits your lifestyle as it more friendly for 2 pax Link to post Share on other sites More sharing options...
Shan21 Neutral Newbie May 1, 2017 Share May 1, 2017 Anyone letting go your mini, pls pm me. Link to post Share on other sites More sharing options...
inlinesix Supersonic May 1, 2017 Share May 1, 2017 i just bought a 9 years old MCS, nothing done yet so cant comment much but going to workshop soon as something is wrong as everyday i need to top up 500ml of water which im sure it not normal. Maintenance will be more ex if u are comparing with Japanese car as parts are more costly and very naturally the workmanship cost will be higher. Better to bring a technicians along as he should able to spot some tell tale sign of leaking etc, most important does the mini fits your lifestyle as it more friendly for 2 pax 9 yr old already. Skip all repair & maintenance. Use until scrap. Are you sure parts are more costly? Link to post Share on other sites More sharing options...
Mercury1 Turbocharged May 1, 2017 Share May 1, 2017 I had a pal who bought roughly 7/8 year old mini but he brought it down to a mini workshop to check thoroughly before putting the money down. Cars of these age need a good checking, don't say mini any ill maintained conti car of this age will also be suspect. i just bought a 9 years old MCS, nothing done yet so cant comment much but going to workshop soon as something is wrong as everyday i need to top up 500ml of water which im sure it not normal. Maintenance will be more ex if u are comparing with Japanese car as parts are more costly and very naturally the workmanship cost will be higher. Better to bring a technicians along as he should able to spot some tell tale sign of leaking etc, most important does the mini fits your lifestyle as it more friendly for 2 pax 2 Link to post Share on other sites More sharing options...
inlinesix Supersonic May 2, 2017 Share May 2, 2017 I had a pal who bought roughly 7/8 year old mini but he brought it down to a mini workshop to check thoroughly before putting the money down. Cars of these age need a good checking, don't say mini any ill maintained conti car of this age will also be suspect. That's including Jap, Korean or China car hor. Link to post Share on other sites More sharing options...
Lava 5th Gear May 4, 2017 Share May 4, 2017 this car will bring you fun and joy. be a proud owner of mini. preventive maintenance is needed. I do my interim oil change at espace and full servicing at mini habitat. Link to post Share on other sites More sharing options...
MTMAutomotive Clutched May 5, 2017 Share May 5, 2017 hi all, any good workshop to recommend? just bought a nine years old cooper S East side workshop okay? Link to post Share on other sites More sharing options...
inlinesix Supersonic May 5, 2017 Share May 5, 2017 Mini engine bay is very tight resulted in very hot environment. It is best to change plastic piping to aluminium to avoid future problem. Link to post Share on other sites More sharing options...
KP24 1st Gear May 5, 2017 Share May 5, 2017 Oic,anw I already change the Thermostat n hoses so should solve the problem. Btw u also driving a mini? Link to post Share on other sites More sharing options...
KP24 1st Gear May 5, 2017 Share May 5, 2017 Yup it fine but I went to MCF Auto in kaki bukit. The boss is very knowledgment and I just replace the Thermostat n hoses 1 Link to post Share on other sites More sharing options...
Voodooman Supersonic November 15, 2017 Share November 15, 2017 Mini engine bay is very tight resulted in very hot environment. It is best to change plastic piping to aluminium to avoid future problem. Is this still an issue for the newer Mini using BMW designed engines? Link to post Share on other sites More sharing options...
inlinesix Supersonic November 15, 2017 Share November 15, 2017 Is this still an issue for the newer Mini using BMW designed engines? I am not sure. Looking at how packed the engine bay is. It is very likely. 1 Link to post Share on other sites More sharing options...
Voodooman Supersonic November 15, 2017 Share November 15, 2017 Interestingly, Topgear's top pick of the Mini is not the 2.0l Mini Cooper S but the 1.5l 5-Dr Mini Cooper. The latter reportedly offers sweeter steering. As a 2nd car, this is a lot cheaper than the 3 series, any long term cost I should be aware of? https://www.topgear.com/car-reviews/mini/hatch/verdict Link to post Share on other sites More sharing options...
Frozentouch Clutched November 19, 2017 Share November 19, 2017 Hi guys. My battery went flat just now? Appreciate it if someone can let in on how much it cost to replace the battery? First time mini one owner here. =) 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic November 19, 2017 Share November 19, 2017 Hi guys. My battery went flat just now? Appreciate it if someone can let in on how much it cost to replace the battery? First time mini one owner here. =) Get it replaced under warranty unless your car out of warranty. Rem to change it every 2 yrs after that Link to post Share on other sites More sharing options...
Vratenza Supersonic June 4, 2018 Share June 4, 2018 Mini LCI 2018 Externally, mainly the full circle LED DRL in the headlamps and availability of matrix LED headlamp options as well as 3D customisable side scuttles, rear lamp cluster union jack pattern. Mostly tiny cosmetic changes as what we expect from mid life refresh but most significant I think will be the transmission changes. Since 2017, Mini has been phasing in the 7 speed DCT in to the model line-ups: This year, all most all AT will be 7 speed DCT except for the performance D and JCW versions. Reason being 7 Speed DCT cannot handle the higher torque from these versions. 1 Link to post Share on other sites More sharing options...
Voodooman Supersonic June 17, 2018 Share June 17, 2018 Read in ST the new Mini One comes with a 1.5T engine and 7-speed gearbox but the century sprint is just 10.5s, why did they tune it down? To fit into Cat A? ↡ Advertisement Link to post Share on other sites More sharing options...
Renting a Mini bus to go Malaysia
Selling a 2017 Nissan Pulsar to buy a used 2016 Mini
Mini JCW GP Roll Over Shortly After Owner Takes Delivery
[Official] 2024 Mini Cooper
Next-Gen Mini Cooper Gets Special EV Sounds, Infotainment Modes, OTA Updates
The Best Cooling Measures: Ice Cream! 😂
