Babysaint Neutral Newbie September 18, 2011 Share September 18, 2011 hi, im currently driving a 08 legacy and my dashboard rattles.. did some research got pple post abt removing the whole dashboard and fix d problem. problem is, i dunno how to do it any bros or sis out here got any workshop to recommend? i really love me car but the sound is driving me nuts an example of how they fix it: http://legacygt.com/forums/showthread.php/...me-9-87104.html ↡ Advertisement Link to post Share on other sites More sharing options...
Satria_neo Clutched September 19, 2011 Share September 19, 2011 You can try to DIY yourself first but identifying where is the source of the rattle? IS it cause by glove box? Or under the steering wheel etc? Such things do happen and it can be just due to a lose screw. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear September 19, 2011 Share September 19, 2011 Just like a dripping tap in the dead of the night. It's annoying. Best is to remove everything from the dashboard and glove compartment first. To try to elminate the source. It could be loose coins or pens in the holders or glove compartment. If there is a afterrmarket HU, then most likely the sound system wiring. Or a loose wire from the IU cable. Sometimes stuffing some high density rubber foam between two surfaces, e.g. The side of the dashboard in contact with body frame, etc. If all else fail...then proceed to dismemtal the dashboard piece by piece. Good luck....I hate the rattling sound in my car too. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear September 19, 2011 Share September 19, 2011 Did you change suspension and lower your car ? It could be a harsh ride that causes stuff to rattle in the car... If its so, you might wanna try this as a cure....it works for me. Just spray between dashboard parts. Link to post Share on other sites More sharing options...
Nightkids 6th Gear September 19, 2011 Share September 19, 2011 hi, im currently driving a 08 legacy and my dashboard rattles.. did some research got pple post abt removing the whole dashboard and fix d problem. problem is, i dunno how to do it any bros or sis out here got any workshop to recommend? i really love me car but the sound is driving me nuts an example of how they fix it: http://legacygt.com/forums/showthread.php/...me-9-87104.html Why don't you go back to Motor Image and have a check? Is you car still under warranty? Link to post Share on other sites More sharing options...
Exiga Clutched September 19, 2011 Share September 19, 2011 Hi Ghostrider, Where did you get the OWS Body Flex Gel from..? My ride been ratling for quite sometime already & its been driving me nuts.. ha..ha..ha TIA. Link to post Share on other sites More sharing options...
Babysaint Neutral Newbie September 19, 2011 Author Share September 19, 2011 Where to spray the owe gel? And also where to buy it? Link to post Share on other sites More sharing options...
Hotnyh 3rd Gear September 24, 2011 Share September 24, 2011 (edited) Did you change suspension and lower your car ? It could be a harsh ride that causes stuff to rattle in the car... If its so, you might wanna try this as a cure....it works for me. Just spray between dashboard parts. May I ask where you bought this product? I've not noticed it before at Autobacs. Edited September 24, 2011 by Hotnyh Link to post Share on other sites More sharing options...
Yuan 6th Gear September 24, 2011 Share September 24, 2011 Is this effective? I used to have this problem when I was on coils. After changing back to stock suspension, all the rattling went away. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 24, 2011 Share September 24, 2011 hi, im currently driving a 08 legacy and my dashboard rattles.. did some research got pple post abt removing the whole dashboard and fix d problem. problem is, i dunno how to do it any bros or sis out here got any workshop to recommend? i really love me car but the sound is driving me nuts an example of how they fix it: http://legacygt.com/forums/showthread.php/...me-9-87104.html Must check mine for recent strange noises in cabin when driving along uneven roads. Link to post Share on other sites More sharing options...
Iiiusion 2nd Gear September 24, 2011 Share September 24, 2011 Swift also have lotsa rattles, sianz Link to post Share on other sites More sharing options...
MG_Myvi 1st Gear September 24, 2011 Share September 24, 2011 Must check mine for recent strange noises in cabin when driving along uneven roads. Bro...Myvi main noise issues got a few....sun visor clip, pillar A or B panel...shaky glovebox cover or maybe the so called air bag cover abover the glovebox. I managed to settled all one by one after coming 2 years. Even loose door rubber seals caused sound when on uneven road. Link to post Share on other sites More sharing options...
MG_Myvi 1st Gear September 24, 2011 Share September 24, 2011 Swift also have lotsa rattles, sianz Ya lor...my fren's Swift also experience such issue...esp from rear wheelarch area...near rear passenger seat. Link to post Share on other sites More sharing options...
MG_Myvi 1st Gear September 24, 2011 Share September 24, 2011 Bro, please advise where to get this product. Link to post Share on other sites More sharing options...
Kangadrool Supersonic September 24, 2011 Share September 24, 2011 Rattles and squeaks are common even for well built contis. It does not help that Singapore roads are very badly paved. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 24, 2011 Share September 24, 2011 Bro...Myvi main noise issues got a few....sun visor clip, pillar A or B panel...shaky glovebox cover or maybe the so called air bag cover abover the glovebox. I managed to settled all one by one after coming 2 years. Even loose door rubber seals caused sound when on uneven road. So many likely sources for the one issue? Mine already 2 years old car? Busy-busy. Link to post Share on other sites More sharing options...
D3badge 6th Gear September 25, 2011 Share September 25, 2011 (edited) Rattles and squeaks are common even for well built contis. It does not help that Singapore roads are very badly paved. ??? even my friends from America are impress by our road condition, maybe cause Singapore small thus easy to manage Edited September 25, 2011 by D3badge Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear September 25, 2011 Share September 25, 2011 My Lancer EX also rattle.. not sure whether other Lancer EX owners have this same problem? My is on the right hand side of the dashboard.. where the ERP and reverse meter display is.. when back to C&C, they say cant replicate the noise so no action... ↡ Advertisement Link to post Share on other sites More sharing options...
Intermittent rattling noise, car in ICU
Dashboard wrap
Dashboard wrap
Questions on Toyota Altis dashboard
How to solve unwanted noises in your car
Something to get off my Chest About Mercedes Cars
Dashboard sabre light
Honda fit dashboard
Honda fit dashboard
Dashboard cracks
Dashboard cracks
