Anyone try EPS Power Mesh before??
Ptc77
post-34349-1318379194_thumb.jpgpost-34349-1318379221_thumb.jpgIt claim to be a revolutionary product designed and developed in Japan using Thorium Technology to enable more oxygen to be produced at the air intake system to provide more power and torque for combustion engines. With more oxygen the combustion engine will be able to combust the fuelmore efficiently leaving less carbon deposits. Apart from improving performance, the Power‐mesh also helps produces cleaner emissions. From $140 onwards
Features:
‐ Better power and torque across the RPM range
‐ Improved fuel economy by 5% to 15%
‐ Cleaner emissions
‐ Faster response and overtaking power
‐ Immediate effect
‐ Lasts up to 300,000km
‐ Works on diesel and petrol engines
‐ Easy installation
More information of EPS Power Mesh at: http://www.box.net/shared/j7rdmufqm61gq1xl4540
Edited by Ptc77
Trash mesh. We don't see well known coy like HKS, K&N coming up with all this crap. Save your $$. Buy from established brands.
Edited by Pitpot
wahahaa.....a steel mesh can produce more oxygen??? :blink:[hur]
forget abt going carbon neutral. forget abt planting more trees. dun waste it on a car. let's juz stick this mesh all over our environment and we'll all have more oxygen to breathe. [laugh]
Honestly....
5-15% better fc?
I want to get 20 pcs. [laugh]
It may actually work. Nothing rocket science. If it contains radioactive elements. IT will be able to produce oxygen. Cause alpha particles produced during the decay will convert N2 into O2. Its known as nuclear transmutation.
If no radiation readings from this mesh, means the product is lying.
If got radiation readings from this mesh, means can call SCDF Hazmat Team to evacuate the area liao.
Few problems.
Common thorium half-life is about 14Bil yrs. The decay rate is too slow to produce any effects.
Secondly, when there is radioactive decay, the thorium nucleus decays and shoots out an ionized particle. you cannot control what this particle will strike, it could strike the pvc piping, plastic body work, air filter element, smoke particles in the air, a leaf in the filter box, carbon dioxide, or anything other than nitrogen. Worse if it strikes the mechnic that is changing the filter for you.....
Thirdly, processed thorium could decay in 2 yrs, but that is a controlled substance. Could have legal implications for even posessing it.
This is really a wild idea...........
