Hermes_1 Neutral Newbie November 5, 2011 Share November 5, 2011 Hi bros/ sis, my right head bulb just blew. Appreciate any recommendation on what brand is good and where to install? Thanks & regards. ↡ Advertisement Link to post Share on other sites More sharing options...
Eyke Supercharged November 5, 2011 Share November 5, 2011 wat color u wan first? Link to post Share on other sites More sharing options...
Hermes_1 Neutral Newbie November 5, 2011 Author Share November 5, 2011 wat color u wan first? I was researching and found Philip power2 night. Anything better but lta compliant? Link to post Share on other sites More sharing options...
I-LOVE-CARS 1st Gear November 5, 2011 Share November 5, 2011 I was researching and found Philip power2 night. Anything better but lta compliant? Philip headlights are a perfect choice.. Link to post Share on other sites More sharing options...
Eyke Supercharged November 5, 2011 Share November 5, 2011 Link to post Share on other sites More sharing options...
HONDAFIT08 Neutral Newbie November 5, 2011 Share November 5, 2011 yeah just change to philips extreme vision from extreme power . Really great brightness n throw ! Worth to buy . Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 5, 2011 Share November 5, 2011 Hi bros/ sis, my right head bulb just blew. Appreciate any recommendation on what brand is good and where to install? Thanks & regards. Main headlamp you can consider changing yourself. Unless your car is some french car that got to change the bulb via the wheelarch , otherwise, removing the headlamp assembly and changing the bulb should be a straightforward affair. Link to post Share on other sites More sharing options...
Detach8 5th Gear November 5, 2011 Share November 5, 2011 philips are nice... but just a word on headlights... please don't install some super bright white/blue/yellow bulbs. be considerate to other road users. thanks. Link to post Share on other sites More sharing options...
Dscheng 3rd Gear November 5, 2011 Share November 5, 2011 Hi bros/ sis, my right head bulb just blew. Appreciate any recommendation on what brand is good and where to install? Thanks & regards. HID is the way to go ~!! Link to post Share on other sites More sharing options...
Eyke Supercharged November 5, 2011 Share November 5, 2011 HID is the way to go ~!! illegal and glaring if not factory-installed Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 5, 2011 Share November 5, 2011 HID is the way to go ~!! Most people never even check whether their HIDs are properly aligned after installing. I have no sorry for those that are fined. Link to post Share on other sites More sharing options...
Eyke Supercharged November 5, 2011 Share November 5, 2011 I have no sorry for those that are fined. I have many orbis for those that are fined Link to post Share on other sites More sharing options...
Passion 5th Gear November 5, 2011 Share November 5, 2011 Most people never even check whether their HIDs are properly aligned after installing. I have no sorry for those that are fined. I think stock are just nice.factory fitted HID are a advantage. Self install HID is no go. I did once and immediately dismantle it.Looks cool but if don't want to blind people,have to aim to like 10m ahead. Which is of no point. Else the bloody signboard on the road will be light up by HID. Want to use HID,then change to projector lens with nice cut off.certain cars with projector lens are not suitable with HID. Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 6, 2011 Share November 6, 2011 I think stock are just nice.factory fitted HID are a advantage. Self install HID is no go. I did once and immediately dismantle it.Looks cool but if don't want to blind people,have to aim to like 10m ahead. Which is of no point. Else the bloody signboard on the road will be light up by HID. Want to use HID,then change to projector lens with nice cut off.certain cars with projector lens are not suitable with HID. well some people just dont get it. headlamps in sg context are mainly for people to note your car's presence rather than to light up the road like a fairway. just like switching on the headlamps in MSCP is to alert oncoming cars in blind corners that someone is incoming. i believe some people intentionally leave their third party headlamps (not just HIDs) misaligned because they are selfish. Projecting the beam further will help them see further, never mind the fact that the beam is directed onto people's rearview mirror. Link to post Share on other sites More sharing options...
Hermes_1 Neutral Newbie November 6, 2011 Author Share November 6, 2011 yeah just change to philips extreme vision from extreme power . Really great brightness n throw ! Worth to buy . May I know if xtreme power is yellow light like stock? Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 6, 2011 Share November 6, 2011 If it's H4, a cheap normal Philips H4 is good enough. $10 from supermarket or petrol station. Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 6, 2011 Share November 6, 2011 Main headlamp you can consider changing yourself. Unless your car is some french car that got to change the bulb via the wheelarch , otherwise, removing the headlamp assembly and changing the bulb should be a straightforward affair. I just managed to change my H7 on my Megane after groping in darkness for 15 minutes. First time changing. Hand bruised. Not DIY for those with big hands. Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 6, 2011 Share November 6, 2011 I just managed to change my H7 on my Megane after groping in darkness for 15 minutes. First time changing. Hand bruised. Not DIY for those with big hands. via wheelarch? ↡ Advertisement Link to post Share on other sites More sharing options...
Energy Savings / Non Heat up LED Headlights Technology
LED head light
LED head light
Theives Gouged Out This Poor Porsche Taycan's Headlights
Recommend me a hotel in Hangzhou
Recommend me a good handheld vacuum
