Redplanet Clutched August 22, 2012 Share August 22, 2012 50 is not recommended for cars. It is used only for racing where high temp is present and only for lorries only. Now where did u get this? ↡ Advertisement Link to post Share on other sites More sharing options...
Duskyoa Neutral Newbie August 22, 2012 Share August 22, 2012 (edited) Now where did u get this? Is the information I have gathered thruout the years. Any information you think it is wrong? What I am saying is normally is the case, not a fixed and must do rule. Edited August 22, 2012 by Duskyoa Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged August 22, 2012 Share August 22, 2012 I always maintain the oil level at 3/4 level. Reason??? More responsive engine and thats the oil level with 3L engine oil (I use 1L bottle). So far, I have not encounter any issue with my engine, my millage is over 200K now and still going strong... Opened my engine cover last year to replace the rubber gasket and the internal part of the engine is sparking clean and no sign of excessive wear n tear (posted in MCF before, you may do a search if want to see) Link to post Share on other sites More sharing options...
Redplanet Clutched August 22, 2012 Share August 22, 2012 Well I don't agree. Especially the 2 sentences I quoted from your post. What do you drive? Link to post Share on other sites More sharing options...
Kurty Supercharged July 31, 2013 Share July 31, 2013 Is it normal old car tend to consume e.o? I did a check today and realize my 7yrs old car beginning to consume .. Normal? Link to post Share on other sites More sharing options...
ER-3682 Twincharged July 31, 2013 Share July 31, 2013 Is it normal old car tend to consume e.o? I did a check today and realize my 7yrs old car beginning to consume .. Normal? Normal,depends on mileage....even some German cars,new engine also eat engine oil. Link to post Share on other sites More sharing options...
Tiger1 6th Gear July 31, 2013 Share July 31, 2013 (edited) Can some expert offer some advice for the following : Must engine oil be filled up to the "full" level ? As the dip stick shows both "L" and "H" mark, theoretically 3/4 full should be ok right ? Easy. L for "lau U" -----top up oil. H for "ho liao" ----no need top up oil. Edited July 31, 2013 by Tiger1 Link to post Share on other sites More sharing options...
Kurty Supercharged July 31, 2013 Share July 31, 2013 Normal,depends on mileage....even some German cars,new engine also eat engine oil. then is it normal, if engine oil is low, you tend to hear the rattling engine sound? i'm going to do another check tomorrow, if really low, i got to top up Link to post Share on other sites More sharing options...
Fuelsaver Supercharged July 31, 2013 Share July 31, 2013 Normal,depends on mileage....even some German cars,new engine also eat engine oil. Guess what, recently bot a used car. Manual stated engine will consume up to 1l eo per certain mileage. But so far hasn't. I guess if follow manual use 5w-30 maybe will. Now on 40. To check eo lvl, off running engine n wait few minutes to check. Lvl like many said, toward H. Link to post Share on other sites More sharing options...
TVT Supercharged July 31, 2013 Share July 31, 2013 then is it normal, if engine oil is low, you tend to hear the rattling engine sound? i'm going to do another check tomorrow, if really low, i got to top up According to the owner's manual book, it says it is normal as overtime the engine will consume some EO. However it should not be too much. Engine rattling sound is what? Is it the tak tak tak sound ? Link to post Share on other sites More sharing options...
ER-3682 Twincharged July 31, 2013 Share July 31, 2013 Guess what, recently bot a used car. Manual stated engine will consume up to 1l eo per certain mileage. But so far hasn't. I guess if follow manual use 5w-30 maybe will. Now on 40. To check eo lvl, off running engine n wait few minutes to check. Lvl like many said, toward H. Most Japanese car engine do not 'eat' engine oil,i scrapped 2 Japanese cars this year,both with me for near 10 years[from new],both did not need to top up between services.. Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 1, 2013 Share August 1, 2013 Is it normal old car tend to consume e.o? I did a check today and realize my 7yrs old car beginning to consume .. Normal? Depends on car model. Most cars after 7 yrs still dun drink oil. Mine already 7 yrs n hardly drink any oil (40 weight) even with a lot of whacking. If yr car drink too much oil, its time fr an overhaul. Maybe just change piston rings if ty r worn or the valve guides. Also chk if yr gaskets hv leak or yr coolant has oily film. All these things u sud hv chked b4 u buy. Or u can try using a heavier EO n see if it helps but u lose on performance n economy. If 10K km u need to top-up>1 lit eo, its very bad already. Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 1, 2013 Share August 1, 2013 then is it normal, if engine oil is low, you tend to hear the rattling engine sound? i'm going to do another check tomorrow, if really low, i got to top up If u can hear a loud rattling sound, u need to overhaul already. Pistons longah. Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 1, 2013 Share August 1, 2013 According to the owner's manual book, it says it is normal as overtime the engine will consume some EO. However it should not be too much. Engine rattling sound is what? Is it the tak tak tak sound ? His sound like those diesel taxi. Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 1, 2013 Share August 1, 2013 Easy. L for "lau U" -----top up oil. H for "ho liao" ----no need top up oil. U replying to a 2011 post. Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 1, 2013 Share August 1, 2013 So I better top it up to MAX? Btw, what is wet sump and dry sump? Wet sump it has oil inside. Dry sump its dry n no more oil inside. Hahahahahaha. Link to post Share on other sites More sharing options...
Ckchong8 1st Gear August 2, 2013 Share August 2, 2013 (edited) Depends on car model. Most cars after 7 yrs still dun drink oil. Mine already 7 yrs n hardly drink any oil (40 weight) even with a lot of whacking. If yr car drink too much oil, its time fr an overhaul. Maybe just change piston rings if ty r worn or the valve guides. Also chk if yr gaskets hv leak or yr coolant has oily film. All these things u sud hv chked b4 u buy. Or u can try using a heavier EO n see if it helps but u lose on performance n economy. If 10K km u need to top-up>1 lit eo, its very bad already. Probably you on time servicing and using top premium eo leh...not the lotsa oil that why lah Edited August 2, 2013 by Ckchong8 Link to post Share on other sites More sharing options...
Kurty Supercharged August 2, 2013 Share August 2, 2013 Depends on car model. Most cars after 7 yrs still dun drink oil. Mine already 7 yrs n hardly drink any oil (40 weight) even with a lot of whacking. If yr car drink too much oil, its time fr an overhaul. Maybe just change piston rings if ty r worn or the valve guides. Also chk if yr gaskets hv leak or yr coolant has oily film. All these things u sud hv chked b4 u buy. Or u can try using a heavier EO n see if it helps but u lose on performance n economy. If 10K km u need to top-up>1 lit eo, its very bad already. yesterday before i drove my car, i observe the dip stick.. E.O was barely hitting the L mark, i guess that's the root of the sound.. hence i pour a L of E.O in, after a while, the sound was gone.. well, i will observe it.. My ride is only 7yrs+, 94K mileage only.. unlikely to be be piston ba.. this sat, throw it to my workshop and observe ↡ Advertisement Link to post Share on other sites More sharing options...
Math Question
Math Question
A level results for University Courses
SCHNELL Engine Oil 5W40
O level results coming out soon!
P2096 Check engine light
DIY engine oil change
