Transpasser162 Neutral Newbie December 15, 2011 Share December 15, 2011 Experts out there, need your help. I had change my rim & tyre to aftermarket type sometimes back and this's what happen - steering wheel has NO vibration even if i hit more than 100km/hr BUT - Steering wheel start to vibrate ONLY when i APPLY brake when i hit more than 100km/hr.... Why is that so? Please advise.Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Jerrimie Clutched December 15, 2011 Share December 15, 2011 if vibrate on braking most likely is rotors or brake pad uneven wear if i am not wrong Link to post Share on other sites More sharing options...
Ken4555 1st Gear December 15, 2011 Share December 15, 2011 Experts out there, need your help. I had change my rim & tyre to aftermarket type sometimes back and this's what happen - steering wheel has NO vibration even if i hit more than 100km/hr BUT - Steering wheel start to vibrate ONLY when i APPLY brake when i hit more than 100km/hr.... Why is that so? Please advise.Thanks haha... my momo vibrates a little ard 100km/h... then ok till 150-160km/h... braking no vibrations wat so ever... opp of you... Link to post Share on other sites More sharing options...
Transpasser162 Neutral Newbie December 15, 2011 Author Share December 15, 2011 (edited) Yes lo..normally i also read mostly are cruising at high speed the steering wheel will vibrate and mine is opposite. My car is only 1.5yr old and never change brakepad or rotor before... so will either this 2 item be the cause of my steering wheel vibration when i brake at high speed?? Edited December 15, 2011 by Transpasser162 Link to post Share on other sites More sharing options...
Maka Neutral Newbie December 15, 2011 Share December 15, 2011 Experts out there, need your help. I had change my rim & tyre to aftermarket type sometimes back and this's what happen - steering wheel has NO vibration even if i hit more than 100km/hr BUT - Steering wheel start to vibrate ONLY when i APPLY brake when i hit more than 100km/hr.... Why is that so? Please advise.Thanks Try stepping it slowly instead. Or change to 4 pots or higher. If oready on 4 pots and still vib, it could be due to rotor warping. Link to post Share on other sites More sharing options...
Help1 1st Gear December 15, 2011 Share December 15, 2011 u need high-speed balancing Link to post Share on other sites More sharing options...
Dessimbk Neutral Newbie December 15, 2011 Share December 15, 2011 Most likely disc rotor warp. Better to confirm by workshop, then they will ask you to do replacement or skimming. Link to post Share on other sites More sharing options...
Dchahs Clutched December 15, 2011 Share December 15, 2011 Most likely disc rotor warp. Better to confirm by workshop, then they will ask you to do replacement or skimming. Bro dessimbk is right Is the rotor, mine also same suitable from high speed and now low speed apply brake also vibrate. Have it changed and now steady leow Link to post Share on other sites More sharing options...
SimonTan 2nd Gear December 15, 2011 Share December 15, 2011 Sometimes could be just some debris stuck between the rims and rotor plate after changing tyres. Try to clean the rims face that is touching the rotor.....and do balancing. Should solve the problem for most. Else then it will likely be warped rotor. Link to post Share on other sites More sharing options...
JingYun Neutral Newbie December 15, 2011 Share December 15, 2011 haha... my momo vibrates a little ard 100km/h... then ok till 150-160km/h... braking no vibrations wat so ever... opp of you... no wonder u can hit 9k+ posts... [gossip] Link to post Share on other sites More sharing options...
Cheesepiekia 5th Gear December 15, 2011 Share December 15, 2011 Try high speed balancing first before changing any parts. Link to post Share on other sites More sharing options...
SFK5898P Neutral Newbie December 15, 2011 Share December 15, 2011 likely to be rotor that warped. If you go to mech, if your brake pad is finish and you carry on to use it. It will damage your rotor. Once rotor is damage, it will be as what you experience now. Brake only, steering move right and left... Link to post Share on other sites More sharing options...
Ken4555 1st Gear December 16, 2011 Share December 16, 2011 no wonder u can hit 9k+ posts... knn buay song is it?... Link to post Share on other sites More sharing options...
Ken4555 1st Gear December 16, 2011 Share December 16, 2011 Try high speed balancing first before changing any parts. why you all keep saying high speed balancing for what? TS says steering vibrates ONLY when braking... Link to post Share on other sites More sharing options...
Ken4555 1st Gear December 16, 2011 Share December 16, 2011 Try stepping it slowly instead. Or change to 4 pots or higher. If oready on 4 pots and still vib, it could be due to rotor warping. i have a frd when braking his car stops 'jerky'... like brake pressure hard soft hard soft... either brake pump dying or rotors warp... but NO vibrations of the steering... Link to post Share on other sites More sharing options...
Celicar Turbocharged December 16, 2011 Share December 16, 2011 why you all keep saying high speed balancing for what? TS says steering vibrates ONLY when braking... PLUS only when he is trying to brake from a travelling speed of over 100km/h. If I am not wrong, the common convention about warped rotor is re. vibration when braking from a low travelling speed (not over 100km/h), am I correct? Link to post Share on other sites More sharing options...
W210k 1st Gear December 16, 2011 Share December 16, 2011 90% probability yr front disc brake rotors are warped Link to post Share on other sites More sharing options...
Celicar Turbocharged December 16, 2011 Share December 16, 2011 90% probability yr front disc brake rotors are warped Why only front? ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
Wheel Hubs
Wheel Hubs
ItzJuzCarbon can customise any of your steering wheels, car parts, interior trims, side panels and accessories with Carbon Fiber!
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
Brake Pads
Brake Pads
Steering column
Steering column
