Tweakmax2 Neutral Newbie December 18, 2011 Share December 18, 2011 Mine car only front 2 is disc brake, want to have a better feel when depressing the brake ↡ Advertisement Link to post Share on other sites More sharing options...
Z_Dash Clutched December 18, 2011 Share December 18, 2011 How much does it cost to do stainless streel braided hose? I've heard of it improving brake responsiveness as well as stability. Link to post Share on other sites More sharing options...
Weiiix Neutral Newbie December 18, 2011 Share December 18, 2011 what car you driving ? stainless brake hose cost abt 1xx or more depending on car model. Link to post Share on other sites More sharing options...
Lightbringer 6th Gear December 18, 2011 Share December 18, 2011 around $250 from Goodyear Link to post Share on other sites More sharing options...
Sofes Neutral Newbie December 23, 2011 Share December 23, 2011 most car accessory shop/ workshop will have. Can see magazine like option, hotstuff for reference. just call up and ask if got stock for your car model and how much. diff brand diff price. Link to post Share on other sites More sharing options...
Rolh Neutral Newbie December 23, 2011 Share December 23, 2011 what car you driving Link to post Share on other sites More sharing options...
Titaniumr Neutral Newbie December 23, 2011 Share December 23, 2011 Dun change. Leave as is. I did to my alfa, it has to be replaced 3 times due to leakage. I did to my lex and again after a few months, it leaked - due to tha braided hoses are stiff and if not installed properly, when you turn the steering wheel, there is a lot of bending and pulling which causes leak. So with my current performance ride, i still leave it stock. Link to post Share on other sites More sharing options...
AlvinDj 1st Gear December 23, 2011 Share December 23, 2011 Dun change. Leave as is. I did to my alfa, it has to be replaced 3 times due to leakage. I did to my lex and again after a few months, it leaked - due to tha braided hoses are stiff and if not installed properly, when you turn the steering wheel, there is a lot of bending and pulling which causes leak. So with my current performance ride, i still leave it stock. Did you have it install on both occasions with the same installer / WS.. ? Seems like they didn't do a good job or not skilled enough I reckon... For SSBH, really need some skills... It's really dangerous if it goes haywire... Link to post Share on other sites More sharing options...
5936 1st Gear December 24, 2011 Share December 24, 2011 Industrial hydraulic hose shop can do it. Kian Teck has one. Link to post Share on other sites More sharing options...
Ysc3 Twincharged December 24, 2011 Share December 24, 2011 order from here : http://www.pro-rs.com/ and then find a ws to fix it for you. shud save around 30%. Link to post Share on other sites More sharing options...
Titaniumr Neutral Newbie December 24, 2011 Share December 24, 2011 Different workshop as I did it for different cars. And also didn't feel any difference at all. I think best to stick to the stock ones. Link to post Share on other sites More sharing options...
Yuan 6th Gear December 25, 2011 Share December 25, 2011 Dun change. Leave as is. I did to my alfa, it has to be replaced 3 times due to leakage. I did to my lex and again after a few months, it leaked - due to tha braided hoses are stiff and if not installed properly, when you turn the steering wheel, there is a lot of bending and pulling which causes leak. So with my current performance ride, i still leave it stock. For your case, I believe it is the workmanship. I did have SSBH before and used for a couple of years before I revert back to stock. There are a couple of other reasons for it . Personal Preference as well. Anway, I had the following link (which I had posted before some years back in this forum) for your reading pleasure: http://www.nsxprime.com/wiki/Brake_Lines Link to post Share on other sites More sharing options...
SimonTan 2nd Gear December 25, 2011 Share December 25, 2011 If the replacement steel hose is same length as the original, it's the exact same holding points. I don't see how it can leak or break due to steering wheel turning and suspension up/down. Link to post Share on other sites More sharing options...
Edca 1st Gear December 26, 2011 Share December 26, 2011 Try VTTR ssbh at r**h tech, forgot the first name. So far never face any problem since installed... Can go check it out... IMHO Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 26, 2011 Share December 26, 2011 (edited) Mine car only front 2 is disc brake, want to have a better feel when depressing the brake If you are kidding with us, this is ticklish. Any brake performance improvement with stainless steel hose/tube is like beauty to the beholder. I believe your car manufacturer knows a little more about their brakes. Any air bubbles in the hydraulic brake system must be bleed-off/evacuated to achieve that better feeling when you depressed the brake foot pedal. In case you just wanted to spend some money on your car. Go for better tire. Edited December 26, 2011 by Good-Carbuyer Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 26, 2011 Share December 26, 2011 How much does it cost to do stainless streel braided hose? I've heard of it improving brake responsiveness as well as stability. Unless your COE car got rotten brakes, there should not be noticeable improvement by changing to stainless steel braided hoses. You should invest in replacement brake master cyclinder, all wheel cyclinders, brake rotors... Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 26, 2011 Share December 26, 2011 Dun change. Leave as is. I did to my alfa, it has to be replaced 3 times due to leakage. I did to my lex and again after a few months, it leaked - due to tha braided hoses are stiff and if not installed properly, when you turn the steering wheel, there is a lot of bending and pulling which causes leak. So with my current performance ride, i still leave it stock. Some people just assume/imagine they know more than car manufacturers about brakes. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 26, 2011 Share December 26, 2011 Did you have it install on both occasions with the same installer / WS.. ? Seems like they didn't do a good job or not skilled enough I reckon... For SSBH, really need some skills... It's really dangerous if it goes haywire... I believe some people do learned from mistake(s). Unfortunately, some like to pay for mistakes. ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Where can I get rubber sheet
Where is the best buffet spread?
Steel cabinet
Steel cabinet
