Windcloud03 Neutral Newbie December 20, 2011 Share December 20, 2011 Dear experts, I am a newbie in car servicing but mine is a 2nd hand 3 yo Honda Stream RSZ. My ride is usually bumpy and I can feel the noise within the car if going up to 80+ kph. Is it due to the suspension, vibration in the tyres (have changed since last servicing in July) or soundproofing problems? Please give me your comments. Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Thedream 3rd Gear December 20, 2011 Share December 20, 2011 hard to guess without you describing what kind of noise you're referring to... but since you mentioned "bumpy," are your tyres pumped higher than recommended? If so, can try pumping less air... Link to post Share on other sites More sharing options...
Windcloud03 Neutral Newbie December 20, 2011 Author Share December 20, 2011 Oh yes, forgot to describe the noise. It's like engine coupled with tyre sounds, seems either soundproofing is not so good or something is wrong with the tyres. My service guy told me 34psi for front and 32 for back wheels. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 20, 2011 Share December 20, 2011 What kind of noise? Is it like 'wong wong' noise? Link to post Share on other sites More sharing options...
Windcloud03 Neutral Newbie December 20, 2011 Author Share December 20, 2011 (edited) The noise is like those you hear during plane takeoff. Thinking to get the cars serviced again...changed to Goodyear soft tyres at Huat Lee because of this problem during last servicing. Edited December 20, 2011 by Windcloud03 Link to post Share on other sites More sharing options...
Bigbadguy 1st Gear December 20, 2011 Share December 20, 2011 Your Tyres Still got Tread? Maybe Worn out thats y noisy. Link to post Share on other sites More sharing options...
Beregond Supersonic December 21, 2011 Share December 21, 2011 (edited) The noise is like those you hear during plane takeoff. Thinking to get the cars serviced again...changed to Goodyear soft tyres at Huat Lee because of this problem during last servicing. goodyear got alot of model leh, maybe u can name your model, and wong wong sound anormal sound, should be either bearing or tyres, can alway go to your trusted car workshop to check. Edited December 21, 2011 by Beregond Link to post Share on other sites More sharing options...
Mustank Hypersonic December 21, 2011 Share December 21, 2011 my axle broke! ===========> [bigcry] $3800 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 21, 2011 Share December 21, 2011 my axle broke! ===========> [bigcry] $3800 Wow, your tank also gave way liao. That's a big damage! What happened? Link to post Share on other sites More sharing options...
Mustank Hypersonic December 21, 2011 Share December 21, 2011 mech told me that my rear axle seal gave way, oil leaking and i didnt notice. drive until piang! mrt so jiat lat, 3800 i pay. lan lan. mustank must go on! some chaps help me to push one side but cannot move. truck refuse to budge. but i put neutral and release hand brake liao leh. later in workshop also cannot push. definately signs of rear axle jam up. but when jack up, rear wheels can turn manually leh Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 21, 2011 Share December 21, 2011 That suxs bro. $3800 is a lot of money! Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear December 21, 2011 Share December 21, 2011 mech told me that my rear axle seal gave way, oil leaking and i didnt notice. drive until piang! mrt so jiat lat, 3800 i pay. lan lan. mustank must go on! some chaps help me to push one side but cannot move. truck refuse to budge. but i put neutral and release hand brake liao leh. later in workshop also cannot push. definately signs of rear axle jam up. but when jack up, rear wheels can turn manually leh weight of your tank on the axle bearings, causing the worn axle bearings to lock up along its interference parts. Once lifted up, almost no weight on bearing, it will be easier to turn. Mustank axle so expensive? Must change whole axle? Is it 4wd? u changing the differentials is it? Link to post Share on other sites More sharing options...
Mustank Hypersonic December 22, 2011 Share December 22, 2011 weight of your tank on the axle bearings, causing the worn axle bearings to lock up along its interference parts. Once lifted up, almost no weight on bearing, it will be easier to turn. Mustank axle so expensive? Must change whole axle? Is it 4wd? u changing the differentials is it? lucky i bought the 2 wheel drive version (rear wheel drive). mech told me that the whole axle gone case, must change everything. only thing no need to change is the axle housing. because no one hold stock such a rare breakdown item in SG, they got to DHL from korea. $3800 But when no breakdown, i one person can physically push mustank for short distances. Link to post Share on other sites More sharing options...
Mustank Hypersonic December 22, 2011 Share December 22, 2011 That suxs bro. $3800 is a lot of money! i really lan lan. these few days i take mrt, bring those insane power torchlight and wear combat boots Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 22, 2011 Share December 22, 2011 No symptoms before it breaks down? Should have right? Link to post Share on other sites More sharing options...
5936 1st Gear December 22, 2011 Share December 22, 2011 Your tank also want year end bonus. Link to post Share on other sites More sharing options...
Mustank Hypersonic December 23, 2011 Share December 23, 2011 No symptoms before it breaks down? Should have right? got some low noise but i didnt know so serious. when the noise became very loud, it was too late Link to post Share on other sites More sharing options...
Mustank Hypersonic December 23, 2011 Share December 23, 2011 Your tank also want year end bonus. yalor ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
Intermittent rattling noise, car in ICU
