Fuelsaver Supercharged January 5, 2012 Share January 5, 2012 Hi all experiencing above after removing drl n wiring. drl was previously installed independent of lighting n came with on/off switch. previously a wire wired / tapped to 7.5 fuse. now removed "unused" (not sure if it's needed / not) 7.5 fuse to see how, as i'm thinking it shorted if unused (me poor in electrical / electronic, so pls tell me if it's not the case). appreciate any advise, especially from those who encountered similar issue. ↡ Advertisement Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 9, 2012 Author Share January 9, 2012 Replaced new batt, everything seemed fine. Rechk previously removed wiring, no short or contact w car body or other wire. Every morning start car, at acc, volt meter reads 12.2v, so is it normal now, as parked car running surveillance camera, configured to cut off at 11.8v? Appreciate any advice, Tia. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear January 9, 2012 Share January 9, 2012 Happy New Year Puzzle? If you are saying after installing replacement battery, everthing seems fine. Then the battery/battery connection(s) could had been the problem. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 10, 2012 Author Share January 10, 2012 Mai Suan lei... Didn't know last batt zhun zhun die after I removed drl wiring, so Thoth I didn't do properly maybe short n cause fast drain on batt. Ya, I should think batt was issue, connection all ok. Tks. Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 10, 2012 Share January 10, 2012 Happy New Year Puzzle? If you are saying after installing replacement battery, everthing seems fine. Then the battery/battery connection(s) could had been the problem. Im still trying to figure out what e fark he trying to say? Maybe he speak some special electricians jargon? Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear January 10, 2012 Share January 10, 2012 (edited) Im still trying to figure out what e fark he trying to say? Maybe he speak some special electricians jargon? TS is not an Electrician, just MCF Member with a tread he could not be too sure about Edited January 10, 2012 by Good-Carbuyer Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 10, 2012 Share January 10, 2012 TS is not an Electrician, just MCF Member with a tread he could not be too sure about Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 11, 2012 Author Share January 11, 2012 Im still trying to figure out what e fark he trying to say? Maybe he speak some special electricians jargon? Alamak, me too noob so could not describe properly la. If I could describe properly, I don't think I'd have posted Liao... Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 11, 2012 Share January 11, 2012 Alamak, me too noob so could not describe properly la. If I could describe properly, I don't think I'd have posted Liao... OK. Lets hope u get yr problem solved in e end. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 12, 2012 Author Share January 12, 2012 OK. Lets hope u get yr problem solved in e end. ya, i think problem solved, n i've just diy-ed philips daylight 4 led drl in 2 afternoons - difficult part lies in getting connector clamped onto headlight power cable strand & philip control module wire due to very crampy headlight area & just-nice headlight cable length. the satisfaction of diy... provided things don't screw up beyond what u can salvage... Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 12, 2012 Share January 12, 2012 (edited) ya, i think problem solved, n i've just diy-ed philips daylight 4 led drl in 2 afternoons - difficult part lies in getting connector clamped onto headlight power cable strand & philip control module wire due to very crampy headlight area & just-nice headlight cable length. the satisfaction of diy... provided things don't screw up beyond what u can salvage... U did yr Philips 4 LED daylight running lights ah? How much u bought e parts to fix up yr LEDs? I might consider doing if ty r lasting unlike what most shops wil give u n ty start to blow in a few months only. Most r made in China crap led's. Also FYI only. Aftermarket LEDs DRL is illegal in SG. U need to switch them off when going fr inspection. BTW DRL sud b connected directly to an electrical source that is "ON" as soon as u turn on e engine n not connected to headlights elect supply cos ty supposed to b on ALL E TIME as long as engine is running. I wud likely connect to other source like ciggy lighter or ACC source better. Edited January 12, 2012 by Pisces69 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged January 13, 2012 Author Share January 13, 2012 (edited) U did yr Philips 4 LED daylight running lights ah? How much u bought e parts to fix up yr LEDs? I might consider doing if ty r lasting unlike what most shops wil give u n ty start to blow in a few months only. Most r made in China crap led's. Also FYI only. Aftermarket LEDs DRL is illegal in SG. U need to switch them off when going fr inspection. BTW DRL sud b connected directly to an electrical source that is "ON" as soon as u turn on e engine n not connected to headlights elect supply cos ty supposed to b on ALL E TIME as long as engine is running. I wud likely connect to other source like ciggy lighter or ACC source better. no need to buy anythin (almost); all provided! only need no. 10 spanners, no. 8 spanner (for my own bolt & nut for mounting provided brackets onto grille), screwdriver (if u use provided self tap screws), plier (to clamp provided connector to tap power signal fr headlight to philips LED control module; this part REALLY challenging - i dropper provided connector & can't find it, ended buying another at autobacs, which design easier to slot into wire at cramp space). also running DRL wire another challenge due to cramp space between grille & radiator. philips led drl designed to turn off if you on headlight & on if no lights. another type would dim if other lights on. i heard need to cover / tape drl before inspection & not just turn off. PM me if u wanna check out mine:) Edited January 13, 2012 by Fuelsaver ↡ Advertisement Link to post Share on other sites More sharing options...
Battery Voltage up & down
GSS 2021 join forces with Lazada
From India to S.Africa in an off-peak Hyundai Matrix
Black flakes from washing machine
Blast from the past!!! WWF stars!!
Singapore Idol Hady Mirza BANNED from condo facilities
Michelle Yeoh deported from Burma
How to trace owner from vehicle registration number?
