Blackyv Turbocharged August 25, 2013 Share August 25, 2013 sorry to hijack your thread as i cant able to start new topic. Im currently driving 2008 nissan latio. I was wondering 2008 nissan latio use timing belt or chain? tried to search online but have mix results.any expert to advise me? greatly appreciated Timing chain... It will outlast the coe... ↡ Advertisement Link to post Share on other sites More sharing options...
Deuter_2009 Neutral Newbie August 30, 2013 Share August 30, 2013 Ohh.. Confirm is timing chain? cos i need to go for major servicing soon.. Link to post Share on other sites More sharing options...
13177 Supersonic August 30, 2013 Share August 30, 2013 Ohh.. Confirm is timing chain? cos i need to go for major servicing soon.. Ask the workshop mechanic, they should know whether it is chain or belt. Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear July 31, 2015 Share July 31, 2015 Any latio owners encounter this.. drive side floor mat suddenly becomes wet. Confirm no water bottle spill or drive thru flood area... Aircon leak somewhere? Link to post Share on other sites More sharing options...
Xman13 1st Gear August 1, 2015 Share August 1, 2015 Any latio owners encounter this.. drive side floor mat suddenly becomes wet. Confirm no water bottle spill or drive thru flood area... Aircon leak somewhere? I have the same issue before. Apparently it was caused by the leak on the seal of the windscreen. Got the windscreen change and all ok... Link to post Share on other sites More sharing options...
Ben5266 Supercharged October 2, 2015 Share October 2, 2015 I want to change the cabin air filter. But... cannot find leh... Watch the youtube for Nissan Versa. But still cannot find. Where is the filter? Link to post Share on other sites More sharing options...
Kklim Supercharged October 2, 2015 Share October 2, 2015 I want to change the cabin air filter. But... cannot find leh... Watch the youtube for Nissan Versa. But still cannot find. Latio.JPG Where is the filter? For 2010 Sylphy it's right next to the firewall. Taking out the horizontal piece (at bottom right of pix) with the 4 screws. That gives direct access to the aircon filter. The tab is at the top so you need to reach in and up. 1 Link to post Share on other sites More sharing options...
Ben5266 Supercharged October 2, 2015 Share October 2, 2015 For 2010 Sylphy it's right next to the firewall. Taking out the horizontal piece (at bottom right of pix) with the 4 screws. That gives direct access to the aircon filter. The tab is at the top so you need to reach in and up. Ok. Thanks. I will try again. Link to post Share on other sites More sharing options...
Acewin 4th Gear October 2, 2015 Share October 2, 2015 Hi Benz, Can post some picture or detail on how to remove to share with everyone. Thanks Link to post Share on other sites More sharing options...
Kklim Supercharged October 2, 2015 Share October 2, 2015 Got angkong here: http://www.zerotohundred.com/newforums/nissan/294535-d-i-y-cleaning-sylphy-air-cond-dust-filter.html Link to post Share on other sites More sharing options...
Ben5266 Supercharged October 4, 2015 Share October 4, 2015 Got it. Actually, no need to remove the glove box. Just need to reach the panel and slide up. Link to post Share on other sites More sharing options...
Kklim Supercharged October 4, 2015 Share October 4, 2015 One tab at bottom? Or two? Sylphy has two. Quite diff to get. Link to post Share on other sites More sharing options...
Ben5266 Supercharged October 4, 2015 Share October 4, 2015 One tab at bottom? Or two? Sylphy has two. Quite diff to get.2. Just need to press and slide up to get the tabs out.But it is not too difficult to remove the glove box. Just need more time. Link to post Share on other sites More sharing options...
Bluebellas Clutched June 26, 2016 Share June 26, 2016 Hi, sorry to hijack this track, when I turn off the car engine this morning, noted the car icon flashing. I turn on engine again, it doesn't happen. Anyone knows what it means? Link to post Share on other sites More sharing options...
M2469 1st Gear July 23, 2016 Share July 23, 2016 T Hi, sorry to hijack this track, when I turn off the car engine this morning, noted the car icon flashing. I turn on engine again, it doesn't happen. Anyone knows what it means? Same is happening to my 08 Latio, clocked 115k, the car engine light turns on, off & on again no more car engine light on... This happen after i install 2 ch car cam which needs to tap into the fuse box for continual power supply, dunno is it the cause or due to car wear & tear, electronic/ parts failing... Link to post Share on other sites More sharing options...
Jayc Clutched July 23, 2016 Share July 23, 2016 Hi, Looking to sell or scrap my Latio sports soon. PM me if you need any parts to swop. I have 16" sports rims with PS3 Tyres (used for 20k only), K&N drop in filter available for swop. Link to post Share on other sites More sharing options...
Bluebellas Clutched July 23, 2016 Share July 23, 2016 T Same is happening to my 08 Latio, clocked 115k, the car engine light turns on, off & on again no more car engine light on... This happen after i install 2 ch car cam which needs to tap into the fuse box for continual power supply, dunno is it the cause or due to car wear & tear, electronic/ parts failing... Connect Correct.jpg I din install anything Lor, and coincidently am at ard 115km Link to post Share on other sites More sharing options...
Jayc Clutched July 25, 2016 Share July 25, 2016 Hi, Looking to sell or scrap my Latio sports soon. PM me if you need any parts to swop. I have 16" sports rims with PS3 Tyres (used for 20k only), K&N drop in filter available for swop. Car sold. ↡ Advertisement Link to post Share on other sites More sharing options...
2021 3rd Generation Nissan Note (E13)
Nissan QashQai 2014 Part 2
Nissan Teana Experience
2023 Tan Chong Car Challenge
2018 Nissan Serena e-POWER
