AFV_V200 3rd Gear February 14, 2012 Share February 14, 2012 Has been suffer from that for like 10 yrs. I had torn ligament and stop running since 2000. and slowly suffer low back pain/sciatica? Some suggest it could be due to the low back spine pressing against my nerves. I wonder what specialist shall I go to? A SGH specialist suggested me to either cycle or swim. I would like to go back to running but... due to the torn ligament. Sigh. Last but not least. torn ligament is on inner right knee and I am bow legged. Anyone can share their experience here if they suffer the same. ↡ Advertisement Link to post Share on other sites More sharing options...
SimonTan 2nd Gear February 14, 2012 Share February 14, 2012 (edited) Specialist will not cure your daily activities that lead to the damage n pain. Specialist will suggest operation to cure it. Can tahan 10years....wow.....great endurance. Get the AIBI back stretcher......to reduce the spine pressure.....it will allow the disc to expand and get back to elasticity. Not much solution out there, but to self heal using mental power to spur the body to heal by itself. The flatten disc protruded out and pinch the nerves inside the spinal cord, leading to sciatica and nerve pain. Edited February 14, 2012 by SimonTan Link to post Share on other sites More sharing options...
Donut Supercharged February 14, 2012 Share February 14, 2012 have a friend who recently got slipped disc.... most painful moments for him, and he's a tough guy with history of marathons, cycling, trekking, sky divings. so after the slipped disc, he only stick to swimming and cycling, according to doctor's instructions. So swimming is the best option for you. on top of swimming, you can also do some back-focused gym regime, that will built up your back muscles. And take some yoga or pilates course to keep your spine flexible. forget about running and all those high impact sports. very hard to heal... almost impossible. but if you do the above, your spine can last a long time....... Link to post Share on other sites More sharing options...
Watwheels Supersonic February 14, 2012 Share February 14, 2012 (edited) have a friend who recently got slipped disc.... most painful moments for him, and he's a tough guy with history of marathons, cycling, trekking, sky divings. so after the slipped disc, he only stick to swimming and cycling, according to doctor's instructions. So swimming is the best option for you. on top of swimming, you can also do some back-focused gym regime, that will built up your back muscles. And take some yoga or pilates course to keep your spine flexible. forget about running and all those high impact sports. very hard to heal... almost impossible. but if you do the above, your spine can last a long time....... I think TS is talking about his hip area, not slipped disc or spine. There are a lot of factors affecting TS's issue. It could be his weight, his posture or maybe his knee like he mentioned. I know someone who is flat footed also has problems in one side of his hip joint. IMO is his posture which is affected, he's a tall and heavy, if the posture is not correct his weight is not distributed correctly on his joints thus the pain. Our core muscles (abs & back) support our upper body and helps our legs balance the whole body. Losing weight helps plus strengthening of the core muscle group will lessen the pain. What the specialist suggest is correct since jogging is out of the question to help loose weight. I suggest TS loose some weight if you are overweight and look to someone to make sure your overall posture is alright and see whether it helps. As for your knee there's nothing much can be done unless you do surgery to insert a rubber cushion as a replacement ligament. Edited February 14, 2012 by Watwheels Link to post Share on other sites More sharing options...
AFV_V200 3rd Gear February 14, 2012 Author Share February 14, 2012 I think TS is talking about his hip area, not slipped disc or spine. There are a lot of factors affecting TS's issue. It could be his weight, his posture or maybe his knee like he mentioned. I know someone who is flat footed also has problems in one side of his hip joint. IMO is his posture which is affected, he's a tall and heavy, if the posture is not correct his weight is not distributed correctly on his joints thus the pain. Our core muscles (abs & back) support our upper body and helps our legs balance the whole body. Losing weight helps plus strengthening of the core muscle group will lessen the pain. What the specialist suggest is correct since jogging is out of the question to help loose weight. I suggest TS loose some weight if you are overweight and look to someone to make sure your overall posture is alright and see whether it helps. As for your knee there's nothing much can be done unless you do surgery to insert a rubber cushion as a replacement ligament. I am not heavy at all. Main problem is my bow leg. I used to train in X-country during my NS day. runs 3x a week with lousy shoe. I am 175 weight 58 only. :) So skinny still give me hip area knee problem. guess i leak of low body work out which lead me to this pain. :( Link to post Share on other sites More sharing options...
Kampungboy Neutral Newbie February 14, 2012 Share February 14, 2012 Has been suffer from that for like 10 yrs. I had torn ligament and stop running since 2000. and slowly suffer low back pain/sciatica? Some suggest it could be due to the low back spine pressing against my nerves. I wonder what specialist shall I go to? A SGH specialist suggested me to either cycle or swim. I would like to go back to running but... due to the torn ligament. Sigh. Last but not least. torn ligament is on inner right knee and I am bow legged. Anyone can share their experience here if they suffer the same. I have lower back pain problem on and off ever since I injured my back muscles many years back. I realized sleeping on a firm mattress (not necessary need to be expensive) is almost a must. If you already sleeping on a firm mattress, please check if there is any sagging because sometimes you might not notice it. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear February 14, 2012 Share February 14, 2012 wheres the MBBS here? he can give better advice Link to post Share on other sites More sharing options...
Spirited 1st Gear February 14, 2012 Share February 14, 2012 Why not try chiropractic? When there are mis-alignments in the spine, it can lead to disc problems and affect the nerves. I used to have back pain that comes on about twice a year. Each time progressively worse and last longer. I started this chiropractor which my cousin recommend. I feel so much better! Link to post Share on other sites More sharing options...
Somewhat1975 6th Gear February 14, 2012 Share February 14, 2012 (edited) try this this exercise cured my lower back pain few months ago. If your pain is more than lower back, try full set of somatic exercise below If you need reading, try to find this book somatic exercise your pain go away in hours. Edited February 14, 2012 by Somewhat1975 Link to post Share on other sites More sharing options...
Ocean6576 4th Gear February 14, 2012 Share February 14, 2012 I wonder what specialist shall I go to? A SGH specialist suggested me to either cycle or swim. I would like to go back to running but... due to the torn ligament. Sigh. One question...what did the SGH specialist says causing the pain? Link to post Share on other sites More sharing options...
Shor 1st Gear February 14, 2012 Share February 14, 2012 Oh talking about this Sciatica pain is normally on one leg. I suffered almost 6 years. Not healed at all. My symptom - Standing for too long , walking for around 2km , my left hip downwards will have a very Sharp pain, all the way down to the shin and foot. Sometimes bottom of my feet will get numb. The ONLY way outdoor is, I squad down, or sit down a little while and it goes away. My Treatment - Went for MRI, I forgotten what the result something like L4 and L5 slipped. So that thing always rubbed and touch the nerve causing the pain. - After MRI, took 2 x Pysio therapy packages. No improve and I opt out to continue the therapy, this time I took up Chiropractic therapy. Very expensive but hope that this work. After 12 courses of spinal manipulative therapy, again no improvement on the pain. - After the expensive treatment, I lose patient and this time I tried the TCM method. Accupunture, Tuina etc. It relieved a little only after the treatment but it comes back again. - So I try my best to DIY by searching infos in the internet. Before I sleep, I do a round of stretching, or while watching TV, stretch my left leg to aside until I feel the pain, leave it for 10 mins. Until my whole foot become numb. I did this continuously for 1 month, it really healed or must I say, I can walk more distance without the Sciatica nerve pain. - Currently, I stopped the stretching and it comes back again. I am also looking for advice right now regarding this pain. It's quite hard to heal unless you choose an Op. IMHO Has been suffer from that for like 10 yrs. I had torn ligament and stop running since 2000. and slowly suffer low back pain/sciatica? Some suggest it could be due to the low back spine pressing against my nerves. I wonder what specialist shall I go to? A SGH specialist suggested me to either cycle or swim. I would like to go back to running but... due to the torn ligament. Sigh. Last but not least. torn ligament is on inner right knee and I am bow legged. Anyone can share their experience here if they suffer the same. Link to post Share on other sites More sharing options...
Shor 1st Gear February 14, 2012 Share February 14, 2012 Hopefully some doctors or expert can comment more on this. Or someone suffered Sciatica pain and recovered give some tips too! Thanks! Link to post Share on other sites More sharing options...
Wind30 Turbocharged December 27, 2017 Share December 27, 2017 Oh talking about this Sciatica pain is normally on one leg. I suffered almost 6 years. Not healed at all. My symptom - Standing for too long , walking for around 2km , my left hip downwards will have a very Sharp pain, all the way down to the shin and foot. Sometimes bottom of my feet will get numb. The ONLY way outdoor is, I squad down, or sit down a little while and it goes away. My Treatment - Went for MRI, I forgotten what the result something like L4 and L5 slipped. So that thing always rubbed and touch the nerve causing the pain. - After MRI, took 2 x Pysio therapy packages. No improve and I opt out to continue the therapy, this time I took up Chiropractic therapy. Very expensive but hope that this work. After 12 courses of spinal manipulative therapy, again no improvement on the pain. - After the expensive treatment, I lose patient and this time I tried the TCM method. Accupunture, Tuina etc. It relieved a little only after the treatment but it comes back again. - So I try my best to DIY by searching infos in the internet. Before I sleep, I do a round of stretching, or while watching TV, stretch my left leg to aside until I feel the pain, leave it for 10 mins. Until my whole foot become numb. I did this continuously for 1 month, it really healed or must I say, I can walk more distance without the Sciatica nerve pain. - Currently, I stopped the stretching and it comes back again. I am also looking for advice right now regarding this pain. It's quite hard to heal unless you choose an Op. IMHO How is your hip? I have exactly the same symptoms for like 8 months.... sometimes good sometimes worse.... haven’t seen doc yet though ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Frozen shoulder
Frozen shoulder
Anybody getting prostatitis?
Is Scoliosis Treatable
I’m A Young Adult With Autoimmune Disease. Here’s What Folks Don’t Get About Chronic Pain
Lexus ES is back
Lexus ES is back
Dear CPF: Give Me Back My Money!
Renal failure on the rise
