  • Search this thread
  • Reply to this topic
486 replies to this topic | 102 praises
#1
Posted 19 February 2012 - 02:00 PM
BengGaBoy
  • THREAD STARTER
  • BengGaBoy
    2nd Gear
    Author Image
    184
Hi folks,
Looks like my current budget only allow me to buy Avante 1.6A car in the range of 2008-2009 registered vehicles. As such, would like to seek fellow Avante drivers about the maintenance section.
1. do Avante like some older car need to change timing belt ? If yes, at what mileage interval (e.g. 60KM) need to change and how much $$$ ? And also, does it also need to change the water pump that usually associated with timing belt ?
2. How much is to replace the original shock absorber (4x) ?
3. How much to replace the aircon fan belt ?
4. Anything special about Avante car battery ? Can settle with $150 ?
5. So far anybody overhaul or change their auto gearbox before ? If yes, how much ?
6. Anybody replace their master brake pump ? If yes, how much ?
The above is based on my current ride experience which I need to replace. Any other areas where I have missed, will be be glad if you can point out to me :)
Thanks
2 Anonymous members praised this
#2
Posted 19 February 2012 - 02:25 PM
XenonWhite
  • XenonWhite
    4th Gear
    Author Image
    542
Hi folks,
Thanks
1. Timing belt can change around 80k km. some have gone up to 150+km then change. Not ex, go to stockist.
water pump i heard can replace it around 160k km. go stockist.
2. Shocks if i'm not wrong around $80-$90++ per pcs. go to Stockist..
3. Aircon fan belt... Er.. never hear b4.. nowadays running on electric motor
4. car batt is international (same for most cars), depends on where u go, Less than $150 is definitely possible.
5. auto gearbox overhaul, not that i've heard of..
6. u probably replace the brake pump if u did upgrade your brakes system.. else should be able to last pretty long..
7. air filter, air-con filter, spark plugs. go to stockist.
Avante is a low maintenance and humble car similar to a good nice wife.. biggrin.gif biggrin.gif biggrin.gif
P.S. If u wanna have even lower servicing cost, buy from stockist and replace in m'sia.. Labour cost is dirt cheap over there. But of cos some might say its dangerous, so u need to go to the right place.
P.S.S. The moment u step out of the "safe" country, u need to be on your guard. Even in sg also can kenna wallop by ang mo and they can escape from here, so the choices is yours to make.
Edited by XenonWhite, 19 February 2012 - 02:29 PM.
Meganut and 2 Anonymous members praised this
#3
Posted 23 February 2012 - 07:50 PM
BengGaBoy
  • THREAD STARTER
  • BengGaBoy
    2nd Gear
    Author Image
    184
Hi XeonWhite,
Thanks for your comprehensive reply :)
Anyway, just to check, is Avante gearbox normal type or CVT type ?
Thanks
#4
Posted 23 February 2012 - 08:09 PM
Raytham
  • Raytham
    3rd Gear
    Author Image
    330
Bro, Avante is running on timing chain not belt so no need to change.
#5
Posted 23 February 2012 - 08:44 PM
Gohsj89
  • Premium member
    Gohsj89
    4th Gear
    Author Image
    642
i don't drive avante, but i know it's running on timing chain.
#6
Posted 23 February 2012 - 09:01 PM
Gohsj89
  • Premium member
    Gohsj89
    4th Gear
    Author Image
    642
Hi XeonWhite,
Thanks
avante is running on conventional 4AT.
#7
Posted 25 February 2012 - 10:22 AM
BengGaBoy
  • THREAD STARTER
  • BengGaBoy
    2nd Gear
    Author Image
    184
Thanks for the info.
It's good to hear the timing belt is chain type :) Btw, the water pump still have to change right ?
#8
Posted 25 February 2012 - 11:26 AM
Fattychubby
  • Premium member
    Fattychubby
    3rd Gear
    Author Image
    268
I believed there should also be a belt which is meant for water pump and aircon compressor.
#9
Posted 25 February 2012 - 11:33 AM
Seanboi
  • Seanboi
    6th Gear
    Author Image
    4,904
It's called fan belt. If you get from stockist, will not exceed $80 including labour.
#10
Posted 25 February 2012 - 12:43 PM
XenonWhite
  • XenonWhite
    4th Gear
    Author Image
    542
Hi XeonWhite,
Thanks
Normal 4 speed torque converter.. its a CVVT engine... something like those v-tech kinda of stuff..
#11
Posted 25 February 2012 - 12:44 PM
XenonWhite
  • XenonWhite
    4th Gear
    Author Image
    542
water pump still need to change of cos as in most cars unless u wanna have a ruin engine..
#12
Posted 25 February 2012 - 12:46 PM
XenonWhite
  • XenonWhite
    4th Gear
    Author Image
    542
There's no fan belt in the Avante.. Its an alternator belt..
Fan belt is no longer the "in" thing as most cars come with electric fan that have variable speed nowadays..
#13
Posted 26 February 2012 - 10:03 AM
BengGaBoy
  • THREAD STARTER
  • BengGaBoy
    2nd Gear
    Author Image
    184
Thanks for the input.
By the way, Avante 1.6A S edition, does it come with controls on steering wheel ? Cause I see some have some do not have it even though 1.6A S same model and year of registration.
#14
Posted 26 February 2012 - 11:06 AM
Odessus
  • Premium member
    Odessus
    1st Gear
    Author Image
    77
My dad's ride has those controls on the steering wheel.
#15
Posted 26 February 2012 - 11:21 AM
Friendstar
  • Friendstar
    NOS-ed
    Author Image
    16,204
U give such an elaborate advice without even knowing that avante runs on timing chain
#16
Posted 26 February 2012 - 11:27 AM
Weichien
  • Weichien
    5th Gear
    Author Image
    1,885
Hi XeonWhite,
Thanks
4at. But my workshop told me its cvt same like what latio use.
#17
Posted 26 February 2012 - 12:09 PM
Weichien
  • Weichien
    5th Gear
    Author Image
    1,885
It's reliable really mantianance is v low, serve me well for past 5yeara w zero part failure really. Haven change any wear and tear part as far as I can remember except servicing and tire change spark plug ATF. Parts failure nothing so far.
#18
Posted 26 February 2012 - 12:33 PM
Picanto
korean cars nowadays are built to last long long
#19
Posted 26 February 2012 - 02:17 PM
Tohto
  • Premium member
    Tohto
    2Fast2Furious
    Author Image
    78,408
That's mean your workshop know nothing about the car. Just try to smoke around. dry.gif
#20
Posted 26 February 2012 - 02:19 PM
Odessus
  • Premium member
    Odessus
    1st Gear
    Author Image
    77
LOL!!!
Back to Korean Talk  ·  Car Brands Top Reply to this topic
Quick Reply
Tags: Hyundai, Avante, Maintenance and 1 more...
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
