Colourblind Clutched March 19, 2012 Share March 19, 2012 Hi, Anyone to comments on the above mentioned engine oil? Thanks, ↡ Advertisement Link to post Share on other sites More sharing options...
Carbine- Clutched June 21, 2012 Share June 21, 2012 never hear before Link to post Share on other sites More sharing options...
Cdior 1st Gear June 21, 2012 Share June 21, 2012 Red line ester base @ $17.50 / quartz is gd enough for all cars. Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 21, 2012 Share June 21, 2012 got cement inside?? Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear June 21, 2012 Share June 21, 2012 Wait till you know the price...its some taiwanese oil I believe..yet over price.. Link to post Share on other sites More sharing options...
ER-3682 Twincharged June 21, 2012 Share June 21, 2012 I only used Liquid Moly "Ceratec",a ceramic coating inside the engine. Link to post Share on other sites More sharing options...
Carbine- Clutched July 13, 2012 Share July 13, 2012 I only used Liquid Moly "Ceratec",a ceramic coating inside the engine. yea i am using it now...not bad... Link to post Share on other sites More sharing options...
Dllatimer Neutral Newbie July 13, 2012 Share July 13, 2012 Claimed to be Jap made but the packaging looks questionable. Around $90.00 for 4 quartz, saw exotic cars using.... So far, very few reviews on this, exclude for some exceptional pple using, they are also promoting this product. Check if there is any URL on this brand....zero...only singapore website. Link to post Share on other sites More sharing options...
Edfoo Neutral Newbie July 13, 2012 Share July 13, 2012 There is another brand called MSP said to be pure ptroleum based and contains no PTFE, lead, Moly,solid particles..from USA but in Singapore more than 10 years. http://www.singaporebikes.com/forums/showt...-Great-Discount Link to post Share on other sites More sharing options...
Mindbox33 1st Gear July 13, 2012 Share July 13, 2012 i have been using this EO for the last 3 changes at 10k interval. my avante used to be 10plus fc using redline/amsoil/blitz/penzzoil.... after i use for the 1st EO change... smooth pick up / quiet engine is almost immediate feel...fc steadily stay at 11.5km/L range... +/- abit... after 8000km..i drain out as it has this nano ceramic (detergent) purpose... n the oil drained out is quite black.. as it 'clean' our engine.. 2nd EO change...fc maintain at 11.8km/L range... my last 3rd EO change which is current + i regap my denso iridium plugs to 1.1mm (avante specs) = fc is at least 12km/L & above. last petrol tank travel 12.6km/L driven. i am not the merchant...but i also like others...try 1st time for fun as like i tried few brands before. n i really believe it works for my ride. likewise..i intro to few of my korean ride frens...they also assured that its smooth.. thou they fc din improves much..becoz they have been heavy footed since using this EO at same FC last time... Link to post Share on other sites More sharing options...
5936 1st Gear July 13, 2012 Share July 13, 2012 First time hearing it. Cant find much from google. Good to see the technical data sheet. Link to post Share on other sites More sharing options...
Mindbox33 1st Gear July 14, 2012 Share July 14, 2012 (edited) here is their facebook address. boss name is Dennis http://www.facebook.com/#!/pages/Basso...195761357137311 * once again..i am only the end user..not the seller or merchant Edited July 14, 2012 by Mindbox33 Link to post Share on other sites More sharing options...
Edfoo Neutral Newbie July 14, 2012 Share July 14, 2012 (edited) Saw this at the bikers forum. Check this out. It seems incredible! 1. MSP Extreme Test: Sea Water Edited July 14, 2012 by Edfoo Link to post Share on other sites More sharing options...
5936 1st Gear July 14, 2012 Share July 14, 2012 (edited) They could have run the engine without the cooling effects of sea water. What happens to these cars after these tests? Continue for daily road use or scrap yard? Edited July 14, 2012 by 5936 Link to post Share on other sites More sharing options...
ER-3682 Twincharged July 14, 2012 Share July 14, 2012 Agreed,if these oil are this good all major car mfg will factory filled these oil into the car. Link to post Share on other sites More sharing options...
Edfoo Neutral Newbie July 14, 2012 Share July 14, 2012 (edited) I just went to youtube to check and surprise surprise there is a car running without oil and without cooling of the sea water! And here is a car running with water added to engine oil And here is a car running with sand added to engine oil Please be cautioned that one tries at one's car own risk Edited July 14, 2012 by Edfoo Link to post Share on other sites More sharing options...
Escksu Clutched July 15, 2012 Share July 15, 2012 Agreed,if these oil are this good all major car mfg will factory filled these oil into the car. What makes you think car manufacturers will use the best engine oil etc in the market?? Pls remember that car makers are here to make $$$ not give you the best of the best. Why do you think cars are still make of steel instead of lighter CF or aluminum alloys? The answer is cost. Steel is used despite its weight because its cheap. Link to post Share on other sites More sharing options...
Edfoo Neutral Newbie July 15, 2012 Share July 15, 2012 I tend to agree that most manufacturers would not want to make products that last forever because it runs counterintuitive to profit motivation of businesses. The behaviors of some repair workshops pestering or exaggerating problems so that owners would agree to spend more to change or replace parts speak volume of the prevalence of this profit culture. ↡ Advertisement Link to post Share on other sites More sharing options...
Music Concerts
Music Concerts
Ineffective ceramic coating by Ceramic Works
2023 Mercedes-AMG C63 S E Performance
ACS boy dies during high adventure course
Are You A Big Spender For A High End Bed Mattress?
Naisol ZR53 Car Ceramic Coating (DIY)
High-rise littering
High-rise littering
