Schell31 1st Gear April 9, 2012 Share April 9, 2012 Hi all, I just did the 60k km servicing and steering was perfectly alright. my new tyres just clocked 8000km. after tyres were balanced and rotated, my steering vibrated although faintly at around 100-110km/hr. i can feel the vibration when i try to change lane at high speed. i balanced my tyre again and all of the were 0-0. any idea what caused the faint vibration? ↡ Advertisement Link to post Share on other sites More sharing options...
Heavenspirit Clutched April 9, 2012 Share April 9, 2012 Hi all, I just did the 60k km servicing and steering was perfectly alright. my new tyres just clocked 8000km. after tyres were balanced and rotated, my steering vibrated although faintly at around 100-110km/hr. i can feel the vibration when i try to change lane at high speed. i balanced my tyre again and all of the were 0-0. any idea what caused the faint vibration? Read somewhere b4, ahh found it. http://forums.evolutionm.net/evo-tires-whe...ml?ref=esp-link Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear April 9, 2012 Share April 9, 2012 No mention the material/brand of the wheels I had this KIA steel wheels on my previous Accent that flexes (and also noisier) at around that speed. It was at least 1mm thinner material than Toyota's of the same size. I exchanged wheels with someone and drove happily ever after. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear April 10, 2012 Share April 10, 2012 Get a mechanic to check your drive shaft, I encounter this and I insist it's not drive shaft but it is, now I'm getting a super smooth ride over 120kph. Link to post Share on other sites More sharing options...
Codynik Clutched April 10, 2012 Share April 10, 2012 It is most likely the wheel balancing is not done correctly or their machine is not calibrated. This happened to me after I changed my wheels. Went back 2 times to balance, but the problem still exist until the head supervisor did the balancing and that solved my problem. Link to post Share on other sites More sharing options...
Fooblack Supercharged April 10, 2012 Share April 10, 2012 Hi all, I just did the 60k km servicing and steering was perfectly alright. my new tyres just clocked 8000km. after tyres were balanced and rotated, my steering vibrated although faintly at around 100-110km/hr. i can feel the vibration when i try to change lane at high speed. i balanced my tyre again and all of the were 0-0. any idea what caused the faint vibration? could it be you feel the vibration when you brake at high speed? one usually brake slightly when changing lane.. if so, it could be your brakes rubbing unevenly on the braking plate of the tyres.. i had that problem and the plate needs to be sanded... Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 10, 2012 Share April 10, 2012 could it be you feel the vibration when you brake at high speed? one usually brake slightly when changing lane.. if so, it could be your brakes rubbing unevenly on the braking plate of the tyres.. i had that problem and the plate needs to be sanded... Braking plate: brake rotor. Link to post Share on other sites More sharing options...
Skyiet27 Clutched April 10, 2012 Share April 10, 2012 there is balancing n high speed balancing if i not remember wrongly balancing is up till speed 80/100 high speed is balancing done at 120 if i not wrong when brake then thats ur rotor, different subject Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 10, 2012 Share April 10, 2012 Maybe the wheel balancer is out of calibration. The other possiblity maybe one of the balancing weigh is loose. ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
ItzJuzCarbon can customise any of your steering wheels, car parts, interior trims, side panels and accessories with Carbon Fiber!
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
ACS boy dies during high adventure course
How problematic is VW's 7 speed DSG?
Are You A Big Spender For A High End Bed Mattress?
