Kopites Supersonic April 24, 2012 Share April 24, 2012 Oooh..soli didn't realise this is a tiko thread and not some member seeking advise on how to reduce "wear and tear". ↡ Advertisement Link to post Share on other sites More sharing options...
Nkps 1st Gear April 24, 2012 Share April 24, 2012 (edited) Dont use the car everyday. Use it only when u need to fetch chiobu.Other than that take a public transport. By reducing the use of the vehicle, wear and tear will also reduce according. Err.... 18 year old Honda, fetch Lao Bu better Edited April 24, 2012 by Nkps Link to post Share on other sites More sharing options...
Poker Neutral Newbie April 24, 2012 Author Share April 24, 2012 Beat, 1993. That's what i was told too. Rev till 9k for the 1st 2 gears and subsequently 6.5k i was thinking Link to post Share on other sites More sharing options...
Poker Neutral Newbie April 24, 2012 Author Share April 24, 2012 errr no i really meant it as a serious thread but duno how it became this in the end.. have been getting different words of advice from different parties, also duno who to trust.. my mechanic asks me to whack leh.. i didnt drive it for a short while last yr and the car really went kaput.. so what another bro has mentioned here may be correct, which is the same as what my mech said Link to post Share on other sites More sharing options...
Yuan 6th Gear April 25, 2012 Share April 25, 2012 Driving an old coe Honda currently. Always had these questions in mind so perhaps someone can clarify my doubts. I've tried searching through this forum but to no avail. Please pardon my inexperience or ignorance, if any. 1. Is it true that changing gears too quickly (i.e. at low rpms) will shorten the life of the gearbox? If that's the case, wont I have to rev to higher rpms, so as to preserve the gearbox? 2. If i constantly rev at higher rpms, wont i cause more wear and tear to the engine? 3. What is the definition of 'dragging gear'? to constantly drive at high rpms without changing gear or to drive at a high gear at low speeds and low rpm? Question 3 is due to me reading other forums on this wear and tear issue, and different ppl giving different definitions. Duno which to believe. I used to think that dragging gear means low gear high rpm. I think you worry too much. Just drive normal. Check your oil and fluids regularly and service your engine when it reaches the relevant mileage. That was how I used to maintain my 15 year old COE car (something like yours). Link to post Share on other sites More sharing options...
Yuan 6th Gear April 25, 2012 Share April 25, 2012 thanks bro! guess i'm not doing it wrong then.. got a manual as i was worried abt the gearbox kaput p.s the tiko thing not i start one Modern automatic transmission boxes are pretty sturdy. So they should be fine if regularly maintained. Link to post Share on other sites More sharing options...
Rezorn86 3rd Gear April 25, 2012 Share April 25, 2012 (edited) And dirty as well. Read between the lines. just to add on to more fun.. The smoother and quieter your car runs the less wear and tear. So if you rev to 6k and change up, the engine will be sceaming and the car will jerk forwards when you change gear. If you are doing like 10 kmh and you change to 5th gear and your car shudders and pick up speed very slowly then the shuddering and jerking is also a sign of wear and tear. So when should we change up? At very high revs or very low revs? We should just follow the men and ladies' leg rule. Some men like ladies with long legs and some men like ladies with short legs but most men prefer something in between. Some ladies like "longer gear stick" from men and some ladies like "shorter gear stick" but most ladies would prefer avg ones... So the least wear and tear is to change up smoothly and as noiselessly as possible at about 2 - 3k rpm. Something in between is the sweet spot. Edited April 25, 2012 by Rezorn86 Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 25, 2012 Share April 25, 2012 just to add on to more fun.. Some ladies like "longer gear stick" from men and some ladies like "shorter gear stick" but most ladies would prefer avg ones... Link to post Share on other sites More sharing options...
Poker Neutral Newbie April 25, 2012 Author Share April 25, 2012 I think you worry too much. Just drive normal. Check your oil and fluids regularly and service your engine when it reaches the relevant mileage. That was how I used to maintain my 15 year old COE car (something like yours). Definitely worrying as I dun wana go through the trouble of doing a major maintenance once again. Doing my best to preserve my car. Btw, what was your old coe car a vw as well Link to post Share on other sites More sharing options...
Poker Neutral Newbie April 25, 2012 Author Share April 25, 2012 some ladies like "shorter gear stick" there's a reason why they are called short shifters.. short, fat and efficient Link to post Share on other sites More sharing options...
Roh96 6th Gear April 25, 2012 Share April 25, 2012 there's a reason why they are called short shifters.. short, fat and efficient Short and thick, do the trick. Link to post Share on other sites More sharing options...
Yuan 6th Gear April 25, 2012 Share April 25, 2012 Definitely worrying as I dun wana go through the trouble of doing a major maintenance once again. Doing my best to preserve my car. Btw, what was your old coe car a vw as well Nope. It was a Jap car. A swift. ↡ Advertisement Link to post Share on other sites More sharing options...
How close to wear indicators before changing tires?
What office shoe do you wear?
Does increase in Rim size really reduce FC DRASTICALLY?
New 3D traffic markings on trial to reduce motorists' speed
Tear parking coupon in CBD across 5pm
Remember to wear seat belt
What to wear with max temp 20 degree and minimum 10 degree
