  • Search this thread
  • Reply to this topic
67 replies to this topic | 0 praises
#1
Posted 14 May 2012 - 09:40 PM
Godfinger
  • THREAD STARTER
  • Premium member
    Godfinger
    5th Gear
    Author Image
    1,106
Recently, I discover that my engine will tremble and Vibrate before
I shut off. Problem is, this issue doesnt occurs everytime. More likely
to happen when I turn-Off the Aircon and engine still running. Gear in 'P' and it will
trembles and Vibrates, RPM drops for that few seconds before it
suddenly rev up again to prevent engine stalling.
What could be the problem?
I have my Plugs changed, Engine Oil renewed and Filiter change
as well. Problem still persist. Could it be the sensors issue or
Idling problems? Nothing of this sort happens when Gear is in 'D'
#2
Posted 14 May 2012 - 09:42 PM
Kelpie
  • Kelpie
    NOS-ed
    Author Image
    10,175
Can consider changing engine mounting.
Regards,
Disclaimer:
The above comments are solely my perspectives. You may disagree with it for I shall not be liable for whatever I may have input. You may feel displeased which in this case, my sincere apologies and do kindly seek moderator's advice if need be. Any obscene & threatening comments on me is a reflection of your personality. My motto is we agree to disagree. No profanity or obscenities of any kind. No personal attacks on other users. Thank you.
#3
Posted 14 May 2012 - 10:00 PM
Trafficwatch
  • Trafficwatch
    2nd Gear
    Author Image
    200
Ya, engine mounting might be due for replacement. If you have experience mechanic, he'll use his hydraulic jack & jack up your whole engine to determine which mounting spoil.
Engine mounting replacement costs around S$ 120 to S$ 500 or more depends on how problematic for the replacement & usually each engine having 3 mountings.
Edited by Trafficwatch, 14 May 2012 - 10:00 PM.
#4
Posted 14 May 2012 - 10:08 PM
Godfinger
  • THREAD STARTER
  • Premium member
    Godfinger
    5th Gear
    Author Image
    1,106
huh, Engine mounting will cause engine to trembles and Vibrate before shuting off?
Problem is, this issue is not always happening. Sometimes it doent happen at all.
#5
Posted 14 May 2012 - 10:17 PM
5936
  • Premium member
    5936
    6th Gear
    Author Image
    3,901
For me I will check idling controller and A/C choke.
#6
Posted 14 May 2012 - 10:21 PM
ER-3682
  • Premium member
    ER-3682
    Author Image
    8,821
T/B dirty.??Or too much carbon deposit on the piston top.?What is your car mileage.?
Fairlady.
#7
Posted 14 May 2012 - 10:33 PM
Phang
  • Premium member
    Phang
    6th Gear
    Author Image
    2,999
Shooting in the dark.
I bet the ICV (idling control valve) not functioning well.
#8
Posted 14 May 2012 - 10:36 PM
Godfinger
  • THREAD STARTER
  • Premium member
    Godfinger
    5th Gear
    Author Image
    1,106
Alot of advice to clean the TB and Idling Controller.
My Mileage is high 260K and its a 7years old Stream running on D17A
engine. Just recently that I had this problem. Not everytime before
I shut down it will vibrate. High possibility when my Gear Position in 'P'
and A/C just turned off. The engine will trembles like its going to stall
and moments later, the Rev will build up and save the stalling engine.
#9
Posted 14 May 2012 - 10:38 PM
Godfinger
  • THREAD STARTER
  • Premium member
    Godfinger
    5th Gear
    Author Image
    1,106
I will try to locate this Idling Control Valve location and
maybe I can DIY to replace it.
#10
Posted 14 May 2012 - 10:48 PM
Phang
  • Premium member
    Phang
    6th Gear
    Author Image
    2,999
Did you try switching on the head light, put them to high beam and turn them off to see if the same symptom appear?
The idea is to load your engine with the alternator and remove the load suddenly to see if the ICV will adjust the engine speed smoothly.
#11
Posted 14 May 2012 - 10:49 PM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    48,014
7 years and 260K?!
Have you changed engine mountings before? Maybe it's time.
#12
Posted 14 May 2012 - 10:54 PM
Lanevomax
  • Lanevomax
    4th Gear
    Author Image
    997
Air Flow Sensor ?
#13
Posted 14 May 2012 - 11:12 PM
Godfinger
  • THREAD STARTER
  • Premium member
    Godfinger
    5th Gear
    Author Image
    1,106
Engine Mounting Changed 160K. These Mountings are still fine. Except that the Engine Trembles and Vibrates
before shuting down. That's the problem which I am facing now.
I will try to load the Alternator and see if it loads the ICV.
Talking about Loading, think should be the relating root cause as when
I off the A/C with the Gear in 'P', possibility of the vibrating is there.
What I felt is the RPM doesnt compensate the easing of load at that moment
thus creating the problem. It will rev up seconds later.
#14
Posted 14 May 2012 - 11:16 PM
5936
  • Premium member
    5936
    6th Gear
    Author Image
    3,901
My I ask what car model and year?
#15
Posted 14 May 2012 - 11:36 PM
Xcen
  • Premium member
    Xcen
    Author Image
    24
did u pump in malaysia?
#16
Posted 14 May 2012 - 11:59 PM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    48,014
He mentioned it's a 7 years old Honda Stream.
#17
Posted 15 May 2012 - 12:17 AM
2BDriver
  • Premium member
    2BDriver
    2Fast2Furious
    Author Image
    135,073
Hi, Bro Godfinger,
Sounds to me the air-con compressor relay might causes these problem ? Please let the air-con mechanic to look into it before replacing any parts that may be wasteful.
Worrying is like a rocking chair,  keeps moving you forward and backward forever wasting your time and gets you to nowhere.
#18
Posted 15 May 2012 - 12:22 AM
Sei_fei_loh
  • Premium member
    Sei_fei_loh
    4th Gear
    Author Image
    808
Has similar experience now. Chked and told its one of my engine mounting for my case. Mine not only slight vibration but abit of knocking sound.
Mechanice told me dun bother to change until my car vibrates when idlng. Haha
Hope it helps
#19
Posted 15 May 2012 - 08:21 AM
Godfinger
  • THREAD STARTER
  • Premium member
    Godfinger
    5th Gear
    Author Image
    1,106
Mounting checked and is still
Useable. Only suspect now could
Be the ICA or TB. Shall rule out
TB since idling when waiting at
The lights or more specific, when
Gear is in 'D' is perfectly normal.
Could b relating problems with
Loading since problem only happens
When A/C is shut off.
#20
Posted 15 May 2012 - 08:23 AM
Godfinger
  • THREAD STARTER
  • Premium member
    Godfinger
    5th Gear
    Author Image
    1,106
Dirty fuel filter or choked injectors?
Dont think these are the culprits since
My engine is able to rev willing.
Dynamics Mechanic Pte Ltd
Quick Reply
Tags: Engine, trembles, Vibrates and 3 more...
