Privacy 5th Gear July 14, 2017 Share July 14, 2017 reason i asked is because recently, after returning from a trip in malaysia with full tank of petrol from petronas. my CEL also lid up after travelling about 200km. The mechanic whom i spoke to asked if i have just returned from malaysia and he mentioned it's a common problem if the car has been using malaysia petrol too frequently. He went on to reset the error code and ask me to monitor the car again. I went on to pump singapore petrol for a few tanks and the problem didn't surface again. there maybe some truth that the quality of malaysia petrol will indeed affect the o2 sensor. i will change the mechanic before I change the sensor ↡ Advertisement 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged July 14, 2017 Author Share July 14, 2017 The 02 sensor is wear & tear but it should last at least 5 years or more. You may ask your mechanic to diagnose it with a reader device. Sometime the gasket leak may also caused the 02 sensor failure. My previous car 02 sensor wear-off after 7 years and replaced for $350. Thanks for the Reply,you are nearly 4 Years late,my Camry already scrapped more than 4 Years ago... Link to post Share on other sites More sharing options...
AltisOwner Turbocharged July 16, 2017 Share July 16, 2017 (edited) Thanks for the Reply,you are nearly 4 Years late,my Camry already scrapped more than 4 Years ago... Haha I didn't notice the date of your posting, pai sai :( Have a nice sunny day! Edited July 16, 2017 by AltisOwner Link to post Share on other sites More sharing options...
Hi577 Clutched August 18, 2017 Share August 18, 2017 hi...may I know which workshop did you bring your oxygen sensor to replace? by the way,what are the sign and symptom you encountered with your vios that caused you to replace. thanks. Changed 2 oxygen sensors for my Vios today. Each is $120 and labour charge is $70. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 19, 2017 Share August 19, 2017 hi...may I know which workshop did you bring your oxygen sensor to replace? by the way,what are the sign and symptom you encountered with your vios that caused you to replace. thanks. I went to my regular workshop at AMK. But he does change different price for those that just drive in. Suggest you go to your own. Only the yellow Check Engine Light symbol light up on the dashboard, no other symptom. Still drive normally. But he did tell me the fuel consumption will be slightly higher. Link to post Share on other sites More sharing options...
Hi577 Clutched August 19, 2017 Share August 19, 2017 thanks for the info.... I went to my regular workshop at AMK. But he does change different price for those that just drive in. Suggest you go to your own.Only the yellow Check Engine Light symbol light up on the dashboard, no other symptom. Still drive normally. But he did tell me the fuel consumption will be slightly higher. Link to post Share on other sites More sharing options...
currypuff 5th Gear August 20, 2017 Share August 20, 2017 thanks for the info....If u need to get a new o2, can just pop by any of the parts stockist, especially around serangoon road to check the price, then get your mechanic to install. May be cheaper this way... Link to post Share on other sites More sharing options...
ER-3682 Twincharged August 20, 2017 Author Share August 20, 2017 If your FC is normal & the engine runs fine,just forget it...don't waste $$ to change,this happened in my old Camry,drove the Car with Engine check Light from 8th Year to Scrap,nothing happened. Link to post Share on other sites More sharing options...
Hi577 Clutched August 21, 2017 Share August 21, 2017 If u need to get a new o2, can just pop by any of the parts stockist, especially around serangoon road to check the price, then get your mechanic to install. May be cheaper this way...Noted....since i am mechanical trained,i intend to replace it myself. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 21, 2017 Share August 21, 2017 If your FC is normal & the engine runs fine,just forget it...don't waste $$ to change,this happened in my old Camry,drove the Car with Engine check Light from 8th Year to Scrap,nothing happened. I damn anal, can't stand any warning lights on the dashboard. CEL somemore. You can tahan 2 years somemore...power la bro! Noted....since i am mechanical trained,i intend to replace it myself. Definitely need to hoist the car up bro. That's how I see the workshop does it. Be careful. Your Vios too? Link to post Share on other sites More sharing options...
Hi577 Clutched August 21, 2017 Share August 21, 2017 I damn anal, can't stand any warning lights on the dashboard. CEL somemore. You can tahan 2 years somemore...power la bro! Definitely need to hoist the car up bro. That's how I see the workshop does it. Be careful. Your Vios too? Yeah...mine ncp93.i'll use the hydraulic jack/stand if need to.thanks for the heads up. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 21, 2017 Share August 21, 2017 Yeah...mine ncp93.i'll use the hydraulic jack/stand if need to.thanks for the heads up.I see, same same. Safety first. Link to post Share on other sites More sharing options...
ER-3682 Twincharged August 21, 2017 Author Share August 21, 2017 I damn anal, can't stand any warning lights on the dashboard. CEL somemore. You can tahan 2 years somemore...power la bro! Definitely need to hoist the car up bro. That's how I see the workshop does it. Be careful. Your Vios too? Cannot stand the light,ask someone take out the bulb,case close. Link to post Share on other sites More sharing options...
Hi577 Clutched August 22, 2017 Share August 22, 2017 I see, same same. Safety first. I have a quick look yesterday.the first sensor is accessible from the engine bay.2nd may haf to hoist the car. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 22, 2017 Share August 22, 2017 I have a quick look yesterday.the first sensor is accessible from the engine bay.2nd may haf to hoist the car.Yes there's two. One is upper one is lower. ↡ Advertisement Link to post Share on other sites More sharing options...
Front sensors for big cars...
Parking sensors
Parking sensors
Height sensors go up in Bukit Timah Road
Where to install reverse sensors?
Parking sensors
Parking sensors
Parking Sensors
Parking Sensors
Whose Car Got Not Reverse Sensors and no camera?
