  • Search this thread
  • Reply to this topic
83 replies to this topic | 104 praises
#1
Posted 20 June 2012 - 03:59 PM
Subutai
  • THREAD STARTER
  • Premium member
    Subutai
    5th Gear
    Author Image
    1,999
Hi Guys,
Need your inputs and thoughts of this product that is micmicking Spoon's Rigid Collar. Do you think this is a good add-on regardless of either Stiff Ring or Rigid Collar?
Quote : Stiff Ring
Stiff Ring, aka anti-vibration washer, is made of special formula aluminium. It is used to correct the car body basic geometry by filling the gap between the subframe bolts, subframe and the car chassis bolt hole. Thus, by correcting the geometry setup with Stiff Ring, the car handling will be improved significantly.
Rigid Collar - Youtube video
Keeping quiet doesn't mean that I agree with you, it means I am evaluating you.
#2
Posted 20 June 2012 - 04:26 PM
Jamesc
  • Premium member
    Jamesc
    2Fast2Furious
    Author Image
    167,291
Oh that kind of stiff ring!
I thot you meant the other kind,
didn't do anything for me but the wife
loves it.
dcb, Marcpodi and Doppel praised this
Say no to harsh artificial chemicals
that pollute the earth
and go natural. [thumbsup]
#3
Posted 20 June 2012 - 04:31 PM
GTR78
  • GTR78
    3rd Gear
    Author Image
    279
Hi
Sounds like a good investment for better handling but I suspect it may result in a harsher ride (more vibration being transmitted into the cabin).
I would suggest getting it installed in a reputable workshop and get your suspension alignment checked again after installation. I forsee it will mess up your suspension geometry if not installed & torqued properly.
Cheers
dcb and Marcpodi praised this
2012 Chery QQ <<Somersault Cloud>> 筋斗云
#4
Posted 20 June 2012 - 04:59 PM
Subutai
  • THREAD STARTER
  • Premium member
    Subutai
    5th Gear
    Author Image
    1,999
loves it.
Bro... wrong forum liao leh
dcb praised this
#5
Posted 03 July 2012 - 03:24 PM
Fannz
  • Fannz
    1st Gear
    Author Image
    52
I installed stiff ring (only front) for my ride a month ago and really love it. Just read the review of other bros at Civic FD forum and I guess it must be quite a good mod so just went for it and never regret. Improved handling a lot and steering is very stable. Still cannot make up my mind if I should also install the rear set since I hardly have any passangers.
In fact supposed to go for wheel alignment after installed the stiff ring but do not have the time for it yet. Guess I will just do it when I change my rims.
if you are keen, can check whether SKM (at first east center) carry the stiff ring for your ride.
#6
Posted 04 July 2012 - 05:21 PM
Subutai
  • THREAD STARTER
  • Premium member
    Subutai
    5th Gear
    Author Image
    1,999
Thanks.. called them and the price is steep. There is a group buy in VOGS and the price is very attractive.
#7
Posted 04 July 2012 - 05:31 PM
Skyiet27
  • Skyiet27
    Banned
Ur ride on coilover or stock shocks?
#8
Posted 04 July 2012 - 08:17 PM
Turboflat4
  • Premium member
    Turboflat4
    2Fast2Furious
    Author Image
    43,342
loves it.
Your DNS must be sumting wong. You keep typing SBF, it keeps redirecting you to MCF tongue.gif
Furrynadz and Jamesc praised this
#9
Posted 04 July 2012 - 08:36 PM
5936
  • Premium member
    5936
    6th Gear
    Author Image
    3,903
Technically it's a SPACER.
Paid video advestiment is highly bias. In Mechanical Stds mounting bolts which are 2 size smaller are not acceptable practice. It could lead to alignment issues between GB and engine. It will take much longer time to complete alignment tasks than putting in correctly sized bolts.
Bi-metallic corrosion effect. Unless all the materials are the same type. Bolting aluminium and steel materials will cause bi-metallic corrosion.
Better keep our hard earn money for uncertainties ahead.
#10
Posted 04 July 2012 - 09:20 PM
Jamesc
  • Premium member
    Jamesc
    2Fast2Furious
    Author Image
    167,291
Very sorry!
I think my computer got too excited!
#11
Posted 05 July 2012 - 02:18 PM
Subutai
  • THREAD STARTER
  • Premium member
    Subutai
    5th Gear
    Author Image
    1,999
Hi... Thanks for inputs. I read as below linked.
Do you know what metal is used to make the car chassis? I know stiff ring is Aluminum.
Quote: "To complete the cell, a conductive liquid must bridge the contact metals.
The more electrically conductive the liquid is, the greater the danger of corrosion. Seawater or salt laden moist air is more of a risk than contact with rain water or towns water."
Quote " Methods of Reducing Corrosion resulting from Galvanic Corrosion
Where contact between dissimilar metals cannot be avoided the following steps should be considered
-Select metals that are close together in the galvanic series for the relevant environment
-Avoid relatively small areas of the less noble metal and large areas of the more noble metal
-Insulate the metals from each other
-Exclude electrolyte from around the bimetallic junction e.g painting
-Paint both metals where possible: if impractical paint the most noble metal
-Provide additional corrosion allowance on the less noble metal
-Apply compatible metal or sacrificial metal coatings
-If electrical insulation is used to minimise the risk, then test for the insulation quality as part of maintenance regime "
Article on Bi-metallic corrosion 1
Article on Boi-Metallic corrosion 2
#12
Posted 05 July 2012 - 03:15 PM
Bigbadguy
  • Bigbadguy
    4th Gear
    Author Image
    909
Well I've gotten a set for front and rear to try. Will update once I've installed it.
#13
Posted 08 July 2012 - 11:57 AM
Kakabobo
  • Kakabobo
    2nd Gear
    Author Image
    150
it will get loose very often.
u get undercarriage funny sound often.
when installing do get them to apply some heavy duty lock tight and torque back
#14
Posted 08 July 2012 - 12:55 PM
Kianbeng
  • Premium member
    Kianbeng
    6th Gear
    Author Image
    4,029
Am I missing something here? What is the hype about an aluminium spacer? From the diagram, it works the same as a $0.20 spacer and worse still it changes the original designed / intended geometry of the suspension system (albeit not by much).
Also, how can we "correct the car body basic geometry by filling the gap between the subframe bolts.....". does this mean all new cars are not optimally designed and people like you and me (and other farmers) can buy this "stiff ring" to improve the design of the car suspension system? I think most (if not all) of the engineers working in car manufacture/design dept, will be very hurt.
#15
Posted 08 July 2012 - 01:19 PM
Blackyv
  • Premium member
    Blackyv
    2Fast2Furious
    Author Image
    27,444
a
Well, just like a simple magnet Can help you save petrol where all car maker don't think of that after spending mills on r&d...
#16
Posted 09 July 2012 - 11:02 AM
Mockngbrd
  • Mockngbrd
    2Fast2Furious
    Author Image
    53,388
rigid collars are cool. not sure about the imitation ones though
Garage36.com
#17
Posted 09 July 2012 - 01:35 PM
Bigbadguy
  • Bigbadguy
    4th Gear
    Author Image
    909
Well maybe this video will have a better explaination,
Its just a theory on how it works and what is it suppose to do, Whether it works or not is another issue, Only those that have installed it will know.
#18
Posted 09 July 2012 - 01:41 PM
Kianbeng
  • Premium member
    Kianbeng
    6th Gear
    Author Image
    4,029
a
The magnet is a hype. If it's proven, why isn't this built into the fuel pump or the lines right before the injectors?
#19
Posted 09 July 2012 - 01:50 PM
Kianbeng
  • Premium member
    Kianbeng
    6th Gear
    Author Image
    4,029
If the bolts are tightened to specs, the subframes shouldn't be moving (unless flexing). I believe if the subframes are loose, when you steer, you should hear some knocking sound. In the design of some cars, the bolt area is tapered so that it fits in snugly. But anyhow this is my opinion - and thanks for the video.
#20
Posted 09 July 2012 - 01:55 PM
Kianbeng
  • Premium member
    Kianbeng
    6th Gear
    Author Image
    4,029
To test if your car has a sub optimal design and that the subframe moves.... I would suggest you do the front wheel alignment, then go over a hump (or a few) and come back and check the wheel alignment again. If the bolts aren't holding the subframe tightly then it will affect the alignment.
Back to Performance and Tuning  ·  Aftermarket Top Reply to this topic
HKS Hipermax C-Compact Suspension Kit
HKS Hipermax C-Compact Suspension Kit  |  Rating   Submit Review
Reviewed by Peekarppp  |  Neutral Newbie
Comfortable, well built suspension that also gives good handling performance
It was expensive, but it's a very reputable JDM product. The ride is very comfortable and the cornering is good. There's no more body roll when doing hard cornering or u-turning too.
Reviewed by Toothfairy  |  Clutched
My Swift is really comfortable with these coilovers!
My father took my car out to install these after both me and my sister (we share this car) complained that it got very bumpy and uncomfortable after a bit of driving due to the original suspension being spoiled. After my dad came back with ou... » Read More
Related Product Guide search on sgCarMart.com : Suspension
Quick Reply
Tags: stiff, ring, good, have
