Jj5599 1st Gear July 15, 2012 Share July 15, 2012 (edited) I was quoted by a distributor for a film costing $6 psf and $16 psf respectively for sun control film. The cheaper one has metal content while the latter is metal-free. As my unit has windows all around taking the more expensive option is almost $3k for me, but I worry if i take the cheaper option, the metal containing film might interfere with mobile and wifi signals? I try to save $ when I can... Edited July 15, 2012 by Jj5599 ↡ Advertisement Link to post Share on other sites More sharing options...
Happily1986 5th Gear July 15, 2012 Share July 15, 2012 I was quoted by a distributor for a film costing $6 psf and $16 psf respectively for sun control film. The cheaper one has metal content while the latter is metal-free. As my unit has windows all around taking the more expensive option is almost $3k for me, but I worry if i take the cheaper option, the metal containing film might interfere with mobile and wifi signals? I try to save $ when I can... don't know whats your question but metallic film definitely will result in attenuation of mobile signals. Link to post Share on other sites More sharing options...
Liping24cn Clutched July 15, 2012 Share July 15, 2012 Good to contain your wifi signal in home to avoid others free loaders stealing. But no good to get phone reception. But then hor, unless you whole house is air con and all windows closed every time. Link to post Share on other sites More sharing options...
Liping24cn Clutched July 15, 2012 Share July 15, 2012 Get one A4 sample size metal film from contractor. Wrap it around your phone, walk around your house, and try to call in from another phone. Check the reception. Link to post Share on other sites More sharing options...
5936 1st Gear July 15, 2012 Share July 15, 2012 V cool, huper optics,3M,etc can also be applied ttyo home glass windows. Link to post Share on other sites More sharing options...
Gee 1st Gear July 15, 2012 Share July 15, 2012 Signal strength from operator might decreased if handphone is placed in metal/wire enclosure, depends on how tight is the metal enclosure is and the strength of the signal itself (both transmit and receive). Link to post Share on other sites More sharing options...
Deckbuild 6th Gear July 15, 2012 Share July 15, 2012 I was quoted by a distributor for a film costing $6 psf and $16 psf respectively for sun control film. The cheaper one has metal content while the latter is metal-free. As my unit has windows all around taking the more expensive option is almost $3k for me, but I worry if i take the cheaper option, the metal containing film might interfere with mobile and wifi signals? I try to save $ when I can... I believe the problem with metal is it might get oxidize after some time, turning purplish. I don't believe Hp signal is an issue at all. ↡ Advertisement Link to post Share on other sites More sharing options...
China spends more on controlling its 1.4bn people than on defense
Simple home DIY repairs
Home Aircon
Home Aircon
Electrician lobang?
Electrician lobang?
Top 5 questions to ask every used car dealer
