Hamburger Hypersonic December 25, 2017 Share December 25, 2017 Then get ready for engine leak. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
minyoro January 1, 2018 Share January 1, 2018 I am a believer in engine flushing. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear January 1, 2018 Share January 1, 2018 I am a believer in engine flushing. can share why engine flushing is good? curious to know also. Link to post Share on other sites More sharing options...
Kippei 3rd Gear January 4, 2018 Share January 4, 2018 (edited) I diy engine flush 2 times and it work great. The key to engine flush is the type of product used. Some tech saying, engine flush is to keep your new engine cleaner not for cleaning old and dirty engine. So when engine flush create problem, it usually the latter. Even with regular oil change, when you open up the valve cover there bound to have varnish. I use additive because i believe in it. Same goes to the people who dont believe in it Edited January 4, 2018 by Kippei Link to post Share on other sites More sharing options...
Kklee 6th Gear January 5, 2018 Share January 5, 2018 (edited) I diy engine flush 2 times and it work great. The key to engine flush is the type of product used. Some tech saying, engine flush is to keep your new engine cleaner not for cleaning old and dirty engine. So when engine flush create problem, it usually the latter. Even with regular oil change, when you open up the valve cover there bound to have varnish. I use additive because i believe in it. Same goes to the people who dont believe in it My previous car. I knew a driver whose car had an engine which I think was the same as mine. He used a very popular engine oil and added an engine oil additive. He had very good FC. He also had a "golden" engine caused by varnish. I had used the same popular engine oil before. I had mild varnish which was detected from my "golden" dipstick. It eventually went away. I used to have varnish, slight sludging, dirty throttle body (every 30-40k) and leaky engine top cover. . I contemplated to use engine flush to do some cleaning. Eventually, after much experiment, I did not need to. This is what I did :- Every tank I use a fuel with PEA. Every 5000km, I use a PEA based fuel system cleaner. Evert 10,000km, I use an ester based engine oil which has good cleaning properties. Just to add, I recall any driver who also had a "golden" dipstick. The issue went away because he used a pureplus engine oil which has good cleaning properties. Edited January 5, 2018 by Kklee 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear January 5, 2018 Share January 5, 2018 My previous car. I knew a driver whose car had an engine which I think was the same as mine. He used a very popular engine oil and added an engine oil additive. He had very good FC. He also had a "golden" engine caused by varnish. I had used the same popular engine oil before. I had mild varnish which was detected from my "golden" dipstick. It eventually went away. I used to have varnish, slight sludging, dirty throttle body (every 30-40k) and leaky engine top cover. . I contemplated to use engine flush to do some cleaning. Eventually, after much experiment, I did not need to. This is what I did :- Every tank I use a fuel with PEA. Every 5000km, I use a PEA based fuel system cleaner. Evert 10,000km, I use an ester based engine oil which has good cleaning properties. Just to add, I recall any driver who also had a "golden" dipstick. The issue went away because he used a pureplus engine oil which has good cleaning properties. what engine oil did you use can share? and what addictive you use for your engine? Link to post Share on other sites More sharing options...
Mkl22 Twincharged January 5, 2018 Share January 5, 2018 what engine oil did you use can share? and what addictive you use for your engine?He pumped caltex, used either Techron or redline fuel injector cleaner and pennzoil engine oil. Link to post Share on other sites More sharing options...
Ivan_06 5th Gear January 5, 2018 Share January 5, 2018 I am a believer in engine flushing.You are a workshop boss lah. Flush your head.. Haha 1 Link to post Share on other sites More sharing options...
Friendstar Supercharged January 6, 2018 Share January 6, 2018 Hahahaha Ivan. Yes agree. Flush Ur head! 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear January 6, 2018 Share January 6, 2018 (edited) what engine oil did you use can share? and what addictive you use for your engine? Petrol - Caltex95 ( historic reasons. Now most brand will have some form PEA ) Fuel System Cleaner - Caltex Techron Concentrate or Redline SI-1 Engine Oil - Redline mix ( alternative can be Motul and those with PurePlus ) He pumped caltex, used either Techron or redline fuel injector cleaner and pennzoil engine oil. Eh... u very close except for the engine oil. Edited January 6, 2018 by Kklee Link to post Share on other sites More sharing options...
Mkl22 Twincharged January 6, 2018 Share January 6, 2018 Petrol - Caltex95 ( historic reasons. Now most brand will have some form PEA ) Fuel System Cleaner - Caltex Techron Concentrate or Redline SI-1 Engine Oil - Redline mix ( alternative can be Motul and those with PurePlus ) Eh... u very close except for the engine oil. Ah I misread it was your friend that used pure plus which comes from pennzoil Link to post Share on other sites More sharing options...
inlinesix Supersonic January 6, 2018 Share January 6, 2018 (edited) I use 100ml of Mobil 1 racing 2T whenever i do long drive. I will see a lot of carbon on tailpipe after using it. Edited January 6, 2018 by Davidtch Link to post Share on other sites More sharing options...
Gnahp Supercharged January 6, 2018 Share January 6, 2018 I use 100ml of Mobil 1 racing 2T whenever i do long drive. I will see a lot of carbon on tailpipe after using it. seriously? Link to post Share on other sites More sharing options...
Kklee 6th Gear January 6, 2018 Share January 6, 2018 Ah I misread it was your friend that used pure plus which comes from pennzoil Eh.... not my friend, cos I also dunno that person. Anyway, ester and Pureplus is the right way to go. Link to post Share on other sites More sharing options...
inlinesix Supersonic January 7, 2018 Share January 7, 2018 seriously?Legit. It has to be synthetic 2T fulfilling JASO FC/FD std. With Mini Copper S sports mode, I will get tailpipe popping sound when foot off throttle. With 2T in petrol tank, no popping sound. Link to post Share on other sites More sharing options...
Gnahp Supercharged January 7, 2018 Share January 7, 2018 Legit. It has to be synthetic 2T fulfilling JASO FC/FD std. With Mini Copper S sports mode, I will get tailpipe popping sound when foot off throttle. With 2T in petrol tank, no popping sound. I tried that on motorcycle when I was a teenager for the sake of fun. The four strokes bike felt smoother (maybe placebo effect) and it gave a little smoke at the exhaust pipe, didn't foul the spark plug though. what is the 2T mixing ratio for your car? Link to post Share on other sites More sharing options...
inlinesix Supersonic January 7, 2018 Share January 7, 2018 I tried that on motorcycle when I was a teenager for the sake of fun. The four strokes bike felt smoother (maybe placebo effect) and it gave a little smoke at the exhaust pipe, didn't foul the spark plug though. what is the 2T mixing ratio for your car? 100ml 2T to 45L petrol I use it during long drive on NSH Link to post Share on other sites More sharing options...
Gnahp Supercharged January 7, 2018 Share January 7, 2018 100ml 2T to 45L petrol I use it during long drive on NSH that's 1:450 very far from getting a smoking/wet pipe ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
My engine after 150,000 kms
Why aren't there any Formula 1 Wiki in here? Just merge all the threads.
