Kzone 3rd Gear August 1, 2017 Share August 1, 2017 anyone moved on from the Yi (Xiaoyi??) dashcam? I'm looking for 2 ch cam to replace the Yi but cannot find anything in the market that can match or even come close to the 170 degrees recording angle of the xiaoyi. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
AndreTang Neutral Newbie August 2, 2017 Share August 2, 2017 any recommendations? 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic August 2, 2017 Share August 2, 2017 any recommendations? What is ur budget? If no budget, just get Blackvue DR650s. So far so good for me. Coming to one year already and no problem at all. 1 Link to post Share on other sites More sharing options...
Atrecord Supersonic August 2, 2017 Share August 2, 2017 My advice: Don't take HP. Link to post Share on other sites More sharing options...
jcchia 3rd Gear August 2, 2017 Share August 2, 2017 I nvr regret using itronics ITB100 since day 1 4-5yrs ago till now. Only bad is no more agency. Link to post Share on other sites More sharing options...
Carz73 1st Gear August 3, 2017 Share August 3, 2017 Wonder when F800 will be available in SG. http://www.thinkware.com/Products/Dashcam/F800 Link to post Share on other sites More sharing options...
Kzone 3rd Gear August 4, 2017 Share August 4, 2017 Wonder when F800 will be available in SG. http://www.thinkware.com/Products/Dashcam/F800 no firm date but I was told to expect 2-3 mths time 2 Link to post Share on other sites More sharing options...
Dannnn 4th Gear August 4, 2017 Share August 4, 2017 Anyone heard of Urive A5? is it good? 2 Link to post Share on other sites More sharing options...
I_RIDE_DEEP 2nd Gear August 8, 2017 Share August 8, 2017 Due to frequent connection/disconnection of my dc plug from my itronics ITB100, the centre cylinder of the DC male plug is coming loose. Trying to get one DC male plug from Tao Bao now. Can anyone confirm that Itronics DC male plug (which are exactly the same as Blackvue DC male plug) measures 5.1mm (outer) and 2.1mm (inner)? 2 Link to post Share on other sites More sharing options...
jcchia 3rd Gear August 8, 2017 Share August 8, 2017 I spoilt mine too, then install a switch with a new cable. 2 Link to post Share on other sites More sharing options...
Dreamchild72 Clutched September 16, 2017 Share September 16, 2017 Hi, Which is better? Thinkware F770 vs iroad Q9. 2 Link to post Share on other sites More sharing options...
Kennnny 3rd Gear September 17, 2017 Share September 17, 2017 Hi all, can ask for advise, with budget $350, can get which Good car camera with parking mode after engine stop? Which shop with installation. Thanks 2 Link to post Share on other sites More sharing options...
Adrianli Hypersonic September 18, 2017 Share September 18, 2017 Hi all, can ask for advise, with budget $350, can get which Good car camera with parking mode after engine stop? Which shop with installation. Thanks U drive everyday for at least 20mins? Link to post Share on other sites More sharing options...
Kennnny 3rd Gear September 18, 2017 Share September 18, 2017 U drive everyday for at least 20mins? Hi adrain, don't have, not daily driven. But at times I don't drive for maybe 2days, I will still go and start to warmup car. Link to post Share on other sites More sharing options...
Adrianli Hypersonic September 18, 2017 Share September 18, 2017 Hi adrain, don't have, not daily driven. But at times I don't drive for maybe 2days, I will still go and start to warmup car. Then u will have to consider battery into your setup. Go with the korean brands of car camera. Link to post Share on other sites More sharing options...
Kennnny 3rd Gear September 18, 2017 Share September 18, 2017 Then u will have to consider battery into your setup. Go with the korean brands of car camera. Just fix a fuse will do right? I read somwehere, battery volt fall below a PRE-SET figure, car camera will deactivate itself. Link to post Share on other sites More sharing options...
Adrianli Hypersonic September 18, 2017 Share September 18, 2017 Just fix a fuse will do right? I read somwehere, battery volt fall below a PRE-SET figure, car camera will deactivate itself. Not so simple. Even if you have a device to have a pre-set value to prevent draining the car battery, you must then drive sufficient time to recharge the car battery. To depend on the car battery, one day you will not able to start ur car if you do not drive everyday. So for parking mode to work properly, you will need a big capacity battery and a second one to be charged at home so that you can swap batteries when the other is low. 1 Link to post Share on other sites More sharing options...
Kennnny 3rd Gear September 18, 2017 Share September 18, 2017 Not so simple. Even if you have a device to have a pre-set value to prevent draining the car battery, you must then drive sufficient time to recharge the car battery. To depend on the car battery, one day you will not able to start ur car if you do not drive everyday. So for parking mode to work properly, you will need a big capacity battery and a second one to be charged at home so that you can swap batteries when the other is low. Oh, ok noted, thanks alot. Than I think I just stick to current pluck in to the cigarette port. No need to worry abt draining the battery's. ↡ Advertisement Link to post Share on other sites More sharing options...
Dashcam with GPS
Dashcam with GPS
Blackvue users - please come in AGAIN 2
IRoad X9 drains battery until it is flat
WIN attractive prizes worth $4,440! Submit reviews on any car tyres, lubricant or accessories now.
Cam Camera System that can store multiple days of recording
