Satrianeo_2012 Clutched July 29, 2012 Share July 29, 2012 Hi guys, I am planning to install wide body kit to make my Neo looks like this: I know its not LTA friendly but I still want to go for it. Other than looks, what are the benefits of wide body? Does it make the car more stable at corners? ↡ Advertisement Link to post Share on other sites More sharing options...
Lazymayday Neutral Newbie July 29, 2012 Share July 29, 2012 u need push the wheels out to benefit from stable cornering 1 Link to post Share on other sites More sharing options...
Satrianeo_2012 Clutched July 29, 2012 Author Share July 29, 2012 u need push the wheels out to benefit from stable cornering Yes, I will be pushing the wheels out as well. My stock body is 1710mm while the S2000 is 1800mm. This means I need to push the wheels out by 45mm per side....... Link to post Share on other sites More sharing options...
I_RIDE_DEEP 2nd Gear July 29, 2012 Share July 29, 2012 Hi bro. Can you advise if wide body kit will pass LTA inspection? Link to post Share on other sites More sharing options...
Expertz 1st Gear July 29, 2012 Share July 29, 2012 there will be more wear on your suspensions if you push the wheels out then the car's aerodynamics will be affected, expect a slight increase in fuel consumption also bodykits are heavy, if not done properly after a few months the kit will start sagging from the car's body unless good paint is used or you put 2x layers of paint, after a few months there will be a noticeable difference in color between the car's body and bodykit other than that, no problems at all! 1 Link to post Share on other sites More sharing options...
Satrianeo_2012 Clutched July 29, 2012 Author Share July 29, 2012 Hi bro. Can you advise if wide body kit will pass LTA inspection? no will fail. Those mofos will confirm fail it one. Link to post Share on other sites More sharing options...
Grix17 Clutched July 29, 2012 Share July 29, 2012 Just a slight off-tangent question - are there negative effects of using wheel spacers to push the wheels further out? ↡ Advertisement Link to post Share on other sites More sharing options...
Credit cards - benefits
Benefits of having bigger population in our day to day life.
Police investigating after body retrieved in waters off Merlion Park
Body Odour
Body Odour
😥Woman, in her 80s, keeps body of son, 54, in HDB flat for over a week after he passed away😥
DIY cleaning throttle body
Grassroot leader benefits
Throttle body cleaning
