Quantum 5th Gear August 30, 2012 Share August 30, 2012 Hi all Kindly advise how to tell 2nd hand cars' timing changed or not? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
13177 Supersonic August 30, 2012 Share August 30, 2012 Think most car timing belt cannot be seen from outside, and need to dismantle something to take out the belt to check. But if you are buying a used car already 4 year old or more with mileage more than 60K, better to change the timing belt to play safe. Link to post Share on other sites More sharing options...
Kurty Supercharged August 30, 2012 Share August 30, 2012 change, usually based on the manual, you will required to change at 80k. well, it's cheap anyway. for my ride, i will require 3 belt to change at a go. let me know if need help Link to post Share on other sites More sharing options...
Trafficwatch Clutched August 30, 2012 Share August 30, 2012 (edited) 1st of all, what car are you driving ? Was it equipped with timing belt or chain ? If timing belt type around 80K interval must replace. If timing chain then no need. Depends on if you have regular workshop or not, usually around S$ 70 to S$ 90 for timing belt alone and labour charges depends on your car model and nos of items need to remove from engine vary between S$ 50 to S$ 90/-. Edited August 30, 2012 by Trafficwatch Link to post Share on other sites More sharing options...
Fuelsaver Supercharged August 30, 2012 Share August 30, 2012 1st of all, what car are you driving ? Was it equipped with timing belt or chain ? If timing belt type around 80K interval must replace. If timing chain then no need. Depends on if you have regular workshop or not, usually around S$ 70 to S$ 90 for timing belt alone and labour charges depends on your car model and nos of items need to remove from engine vary between S$ 50 to S$ 90/-. bro, i heard fr some AD that timing chain also needs replacement at about 200k to 250k km rite? Link to post Share on other sites More sharing options...
Fuelsaver Supercharged August 30, 2012 Share August 30, 2012 (edited) 1st of all, what car are you driving ? Was it equipped with timing belt or chain ? If timing belt type around 80K interval must replace. If timing chain then no need. Depends on if you have regular workshop or not, usually around S$ 70 to S$ 90 for timing belt alone and labour charges depends on your car model and nos of items need to remove from engine vary between S$ 50 to S$ 90/-. dbl post Edited August 30, 2012 by Fuelsaver Link to post Share on other sites More sharing options...
Fuelsaver Supercharged August 30, 2012 Share August 30, 2012 change, usually based on the manual, you will required to change at 80k. well, it's cheap anyway. for my ride, i will require 3 belt to change at a go. let me know if need help hi bro kurty, need help Link to post Share on other sites More sharing options...
Simpleonly 5th Gear August 30, 2012 Share August 30, 2012 buy used car .... if can afford the belt change just change for peace of mind.. so you can keep track of it in future... Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear September 28, 2012 Share September 28, 2012 is it true that after replacing the timing belt and stuff you need to do some alignment or calibration? Link to post Share on other sites More sharing options...
13177 Supersonic September 28, 2012 Share September 28, 2012 is it true that after replacing the timing belt and stuff you need to do some alignment or calibration? The mechanic changing the timing belt should include doing the alignment and adjusting of the belt for you. Link to post Share on other sites More sharing options...
Creativeshoot Neutral Newbie September 28, 2012 Share September 28, 2012 ur driver handbook got show the allowance of not too tight on the belt....just bring the car manual, then ur mechanic will relax otherwise he tighten until can strum.... Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear September 28, 2012 Share September 28, 2012 The mechanic changing the timing belt should include doing the alignment and adjusting of the belt for you. what happen if its a bad alignment? any symptoms? Link to post Share on other sites More sharing options...
Jamstart 1st Gear September 28, 2012 Share September 28, 2012 Most car now are using chain belt liao. What you see in the engine compartment are fan belts. It will be good to share what type of 2nd car your are looking at and what year of manufacturing. Believe google also can find the answer easily. Link to post Share on other sites More sharing options...
13177 Supersonic September 28, 2012 Share September 28, 2012 what happen if its a bad alignment? any symptoms? Heard that it would give out weird sound?! Or the belt might snap? ↡ Advertisement Link to post Share on other sites More sharing options...
Clean car seat belt
Clean car seat belt
New insurance rules regarding chain collision
Changing of water pump and timing belt.
Remember to wear seat belt
Rear seat belt stuck
Little Nonya - change in timing today
Lancer CS3 timing belt change
Regarding North South Highway
