Kwanheng 1st Gear December 26, 2012 Share December 26, 2012 hi guys, wanna check Toyota long life coolant can last how long? my mechanic says must change every 20k servicing. is that true? every 40k drain and flush. ↡ Advertisement Link to post Share on other sites More sharing options...
Eliter Neutral Newbie April 2, 2013 Share April 2, 2013 Anyone can advise where to get Mit Grandis radiator? Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear April 2, 2013 Share April 2, 2013 I all alOng know is , never to pop the rad cap to let it water fountain??? M I wrong? I know Its a old thread Tks Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear April 2, 2013 Share April 2, 2013 Anyone can advise where to get Mit Grandis radiator? Can try ming ghee or Fong tat Link to post Share on other sites More sharing options...
Eliter Neutral Newbie April 2, 2013 Share April 2, 2013 Not sure! Temp raise high only at 160km/hr leh! Any comment? Any other stockist u know beside Ming Ghee or Fong Tat? Thks..! Link to post Share on other sites More sharing options...
Jansonchua 2nd Gear October 23, 2013 Share October 23, 2013 Can anyone advise what is the price range of a radiator for toyota axio? Is there a need to change the radiator along with something else attached to the radiator? (Example: fan...) Link to post Share on other sites More sharing options...
TVT Supercharged October 24, 2013 Share October 24, 2013 Can anyone advise what is the price range of a radiator for toyota axio? Is there a need to change the radiator along with something else attached to the radiator? (Example: fan...) Call a aircon specialist workshop to ask lah. Eg. Markcool.... If radiator kaput, just change the radiator. Other attachment if working well, no need to change. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear October 24, 2013 Share October 24, 2013 QUOTE (Edca @ Sep 19 2012, 12:41 AM) <{POST_SNAPBACK}> hi guys, wanna check Toyota long life coolant can last how long? my mechanic says must change every 20k servicing. is that true? every 40k drain and flush. i never change in my camry since jan 2005 110k liao Link to post Share on other sites More sharing options...
Picanto 3rd Gear October 24, 2013 Share October 24, 2013 time to change? i never change in my camry since jan 2005 110k liao Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 26, 2013 Share October 26, 2013 i never change in my camry since jan 2005 110k liao I wud think LONG LIFE COOLANT sud last abt 3-4 yrs (60-80K km). Normal coolant usually change every 1-2 yrs(20-40K km) I use long life coolant (OWS) n use fr abt 3-4 yrs then flush n replace. Link to post Share on other sites More sharing options...
Kengheng450 2nd Gear October 27, 2013 Share October 27, 2013 Can anyone advise what is the price range of a radiator for toyota axio? Is there a need to change the radiator along with something else attached to the radiator? (Example: fan...)Should be lest than $300 Link to post Share on other sites More sharing options...
Jansonchua 2nd Gear October 27, 2013 Share October 27, 2013 Should be lest than $300 Thanks I was quoted around 300+ for an aftermarket radiator. Mechanic told me that the difference with the original one is that aftermarket radiators are lighter in weight and can only use toyota original coolant which is red in colour. Call a aircon specialist workshop to ask lah. Eg. Markcool.... If radiator kaput, just change the radiator. Other attachment if working well, no need to change. Thanks man. I think no need to change too if it is still working like mine, considering that the cost is really high. 700+ for an original radiator. I was told some workshops actually weld the affected areas so as not to change the whole radiator. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 27, 2013 Share October 27, 2013 Thanks I was quoted around 300+ for an aftermarket radiator. Mechanic told me that the difference with the original one is that aftermarket radiators are lighter in weight and can only use toyota original coolant which is red in colour. Thanks man. I think no need to change too if it is still working like mine, considering that the cost is really high. 700+ for an original radiator. I was told some workshops actually weld the affected areas so as not to change the whole radiator. But remember that with the aftermarket lighter radiator, yr cooling wil not b as good as the original one. Prob less rows of pipe so coolant cannot b cooled as well as the original one. It might affect the temp especially when it is older n maybe stuck in a jam on a hot day. Link to post Share on other sites More sharing options...
Jansonchua 2nd Gear October 27, 2013 Share October 27, 2013 But remember that with the aftermarket lighter radiator, yr cooling wil not b as good as the original one. Prob less rows of pipe so coolant cannot b cooled as well as the original one. It might affect the temp especially when it is older n maybe stuck in a jam on a hot day. I wasn't informed on that but I guess it's true. Every cent counts. You pay for what you get. Anyway, will stick with current one since there is no problem this far... Touch wood!!! Link to post Share on other sites More sharing options...
NezanaSaad Neutral Newbie April 12, 2016 Share April 12, 2016 If you have problem with your car radiator or buying a car radiator, you can contact EVERCOOL TRADING COMPANY for advise. You can call them at 6453 3744 or 9747 6115 They are the local distributor for KOYORAD radiator which are made in Japan. Link to post Share on other sites More sharing options...
UbErZoNe Neutral Newbie April 20, 2016 Share April 20, 2016 (edited) If you have problem with your car radiator or buying a car radiator, you can contact EVERCOOL TRADING COMPANY for advise. You can call them at 6453 3744 or 9747 6115 They are the local distributor for KOYORAD radiator which are made in Japan. seems, you're advertising it haha Edited April 20, 2016 by UbErZoNe Link to post Share on other sites More sharing options...
NezanaSaad Neutral Newbie April 20, 2016 Share April 20, 2016 seems, you're advertising it haha seems like advertising but people tend to go to workshop to repair or replace a radiator, they will mark up up to 50%-100% for the service. So if you can save money by $100-$300 why not go directly to them. Get what i mean. Link to post Share on other sites More sharing options...
csf 2nd Gear April 20, 2016 Share April 20, 2016 Anyone ever did a heater core by-pass? Where did you do or where can you buy a by-pass tube? In our climate, the heater is redundant and when it corrodes, gives problem. ↡ Advertisement Link to post Share on other sites More sharing options...
Do officials still check the 3/4 tank rule at causeway?
Patch Fuel Tank,use what type of Epoxy.?
What car has the largest fuel tank?
Radiator slight crack
Leopard 2 tank upgrade
Coolant overflowing from expansion tank
How useful is higher pressure radiator cap?
